| Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING |
no cold fast idle
went to dealer to get fast idle flashed into ecm. they said i didnt have a stock calibration. 34312e30_9 is what they got. the E and the_ arent stock. dodge tech help didnt know what it is either. any one know what it is? the edge ez was unplugged. PLEASE HELP!!!
98.5 24 valve dtt trans. 4" exh. guages edge ez afe filter bd exh. brake |
#2 (permalink) | |
If you've not already had this addressed, here's what I know. I took my new '08 6.7 in to the dealer today to enable the high idle feature. Tech spends an hour updating the ecu. They tried to tell me that the 6.7 doesn't have the high idle feature...only the 5.9's. I called BS and pulled out the manual. Once they saw it, the tech opened his laptop and got back into the system. I noticed a tab called *enable/disable*. I asked him to click on that tab. Once he did it, voila...PTO High Idle enable/disable pops up. Two seconds later, it was enabled on my truck. We tested and it works perfectly. I'm assuming that you're talking about the method to bump your idle with the cruise control, right? HTH
'08 3500 Laramie Mega Cab 4x4 Dually light Khaki with tan leather stock....stock....stock lol |
#4 (permalink) | |
TECH SPECIALIST
TSB 18-019-01
98.5 2500 4x4 Reg Cab, 6" GrandRock Stacks, Adrenaline w/ Pulse, FASS 150, Isspro egt/boost/fuel, silencer ring MIA, Auto to NV4500 swap, 2.5" level w/ 315 Cooper ST's 07.5 3500 6.7L G56 Manual 4x4 Quad Cab Dually -dpf delete in garage |
#5 (permalink) |
I read somewhere that the manual transmission trucks dont have the high idle?? Does anyone know if this is correct? Guess they are afraid someone will forget to apply the parking brake and let there truck roll off!!
2007 6.7l Dodge Dually 6 speed 4X4 |
#8 (permalink) |
What do you have to press to activate it on the 98.5 to 02 models? or does it do it on its own???
2002 Ram 2500 4x4, QC, LB, 3.55 grs, Full 4" Flow pro, Edge Juice w/Attitude. Billet driple disc conv with transgo shift kit, Tows the case 580 Super E dandy but needs some work on the shift kit.... advice would be nice |
#9 (permalink) | |
TECH SPECIALIST
If you do, it idles up on its own when it needs to. There is no manual control.
#10 (permalink) |
I had it enabled when I bought mine new...then went to the dealer for that alternator thing and he disconnected it. I haven't re done it as the truck seems to idle up on it's own anyway and the mecheanic said not to leave it idling for more than a few minutes with the common rail system so that's where i'm at on that one... do miss the feature though.
2005 Dodge diesel |
