Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 11-25-2007, 01:51 PM   #1 (permalink)
Little Driller Boy
Riley5.9's Avatar
Exclamation DEATH WOBBLE! Please check this out!
I have been havin big problems with this, and my offroad dealer sent this TSB to me. The Dealership i go to freaked out when i brought this to them, calling me ignorant and rude. why i dont kno. They claim they dont know anything about it. They also say that its at the customers expense to try and fix. What do you guys think? Anyone else have these issues?
05' 3500 SRW QC SLT 4x4, II Silver 62,II 85's, II Stg 3 CP3,II Dual feed,ATS Pulse Flow,ARP studs,FASS,Dypricol Optix (x4),PPE Hot,Dr.p stg 2,Banks Technicooler,AFE Stg 2,4" dual,NADP Race trans,Triple Disk TC,Billet Flex plate,MagHytech pan,GDP Ladder Bars,Superlift 4",BDS dual steering stabilizers,DT profab control arms,Smoked LED cab lights/3rd brake light,Line-X,20x10 Driv Blitz,35/13.50 stt's,Bushwacker Flares
Built and Sponsored By Smoke Em' Diesel Performance -->1/4 mile, 13.22 @ 98.7mph
Riley5.9 is offline   Reply With Quote
Old 11-25-2007, 02:20 PM   #2 (permalink)
white ramhead's Avatar
ive had the same problem.when i put the 6" lift in i noticed the shake got worse (had the leveling kit in before this).i took it back to shop,they readjusted the camber in the front but didnt fix the problem.then i took it to the tire store and they said i had a bent rim(stock rim) so bought new rims and tires, it helped but still have a little shake at 70.i also replaced the front stabilizer shock and it help the sway back and forth out alot.just my 2 cents!
04.5 QC SLT BULLEY DOG, MUFFLER GONE 6" REVTEK 35"TOYO MKW 17"
white ramhead is offline   Reply With Quote
Old 11-25-2007, 02:25 PM   #3 (permalink)
Derekj's Avatar
Check your warranty. Seems like you have 51 875 miles on her. The TSB is a guide to help the tech resolve the problem.
2007 3500 Dually 4x4 Laramie 2FH package,6.7L,68RFE, limited slip, 3.73, sunroof, kicker amp and 2x10", 2500 watt inverter,tint, back up camera,B&W G/N, Edge Juice W/attitude all over a MP-8....,BADP'S 5" TBE ,S&B Air,.....
Derekj is offline   Reply With Quote
Old 11-25-2007, 02:25 PM   #4 (permalink)
Little Driller Boy
Riley5.9's Avatar
i just dont really understand.. I only get the wobble on the highway/freeway when i hit any bump or rut. It shakes retardedly until i come to a slow crawl or complete stop. It started happening to me out of no-where one day, and now does it every time. Anywhere i go, i have to stick to side roads. Cant go over 70kph.
Old 11-25-2007, 03:54 PM   #5 (permalink)
Rockwerx's Avatar
I would think that this problem should be covered under your warranty. Maybe you could ask another dealership if they will warranty the problem?
2008 Ram 3500 Laramie Quad Cab 4x4 LB DRW 6.7 CTD 6Auto 3.73 LSD
15K 5th Wheel Hitch 12K Trailer Hitch Parts keep falling off my truck...The latest in Blacktec technology added
Rockwerx is offline   Reply With Quote
Old 11-25-2007, 04:44 PM   #6 (permalink)
Little Driller Boy
Riley5.9's Avatar
i talked to the only 2 dealerships that are here. One said they wont forsure, and the other said that dodge would only warranty it up to 60K,.. wcic i dont really understand why.. I have the "Gold" warranty package up to 160k.. its stupid, ill see what they say this week.
Have any of you guys ever had this wobble crap happen to you or anyone u kno?
Old 11-25-2007, 05:30 PM   #7 (permalink)
Derekj's Avatar
That sounds like a shock that's gone bad.
Old 11-25-2007, 07:38 PM   #8 (permalink)
Little Driller Boy
Riley5.9's Avatar
thats what i thought too, but i got brand new dual steering stabilizers..?
Old 11-26-2007, 06:39 AM   #9 (permalink)
Derekj's Avatar
What about shocks? Not stabilizers.
Old 11-26-2007, 08:57 AM   #10 (permalink)
You got yourself a classic case of deathwobble. From your sig., it looks like you have enough mods to void any warranty on your suspension.
Sorry.
In the long run , you will probably have to pony up for the repairs outlined in the TSB.
These trucks are close to deathwobble stock and every fraction of a degree you change the geometry of the suspension components,the closer you come to the threshold of dynamic instability. Normal wear of the component also shrinks the zone of stability
07 2500 M-cab, 4x4, 5.9L, G-56, 3.73,
silencer and muffler MIA,tint 20/5, AEM Workhorse, CFM+ intake,PML diff cover,
DREDnot is offline   Reply With Quote
Old 11-26-2007, 09:26 AM   #11 (permalink)
SlopeIron's Avatar
Not close, they have it. At least my truck does. I have had this happen a number of times and I have no suspension mods and stock tires. I am just under 20k miles right now.
The bum deal is that my tires are good for maybe another 10-15k miles, and after that I thought I would put some 285 Toyo M/Ts or something like that on it. I was thinking that I would also do a leveling kit at the same time just to make sure they don't rub, but if that is going to make this problem even worse, then there is no way.
06 2500 Quad Cab SLT 4x4 Longbed 48RE Juice w/Attitude Silencer Ring 86'd
SlopeIron is offline   Reply With Quote
Old 11-26-2007, 09:50 AM   #12 (permalink)
I must be lucky, I have a 2" leveling kit running 285/75R17 (33") even at 90-100 It's silky smooth
06 QD. cab. 4x4 Auto....Full banks sys./with PDA,ATS 5 star, input shaft & valve body, ATS pulse flow exhaust manifold. 33" TOYO's, 3.73, 2" leveling kit
Jackson1 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
