Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 06-06-2009, 07:01 AM   #13 (permalink)
Originally Posted by Retrocars1 View Post
OK...do you know why it was suspended and what the recall involves now? Thanks.
Hi
The reason the H46 recall was suspended was to make an addition to the inspection/repair procedure. Which is to add the inspection of the orientation of the left outer tie rod end. Potentially the damper bracket u bolts could have been tightened with the ballsocket/stud not perpendicular (straight up & down).
From the beginning "Why/whom for the recall".
Certain 2003 to 2009 vehicles
On March 1st 2008 a new steering linkage was introduced into the replacement parts system. (Production changes are addressed in recall H36).
The new parts were a linkage assembly as a kit , which included 3 tie rod ends, connecting tubes, thread clamps and a modified mounting bracket for the damper.
The damper is available seperately and the old one will not fit the new linkage.
There is some mismatch issues with the pitman arm that matches up with the new inner tie rod link , and parts notes and the recall instructions illustrate the required stamped part number , if unreadable , it needs a new one.
So here's the deal. Chrysler does not know who bought the new packages after March 1, 2008. About 34,000 were sold.
So part 1 of the procedure, inspect the linkage, if it's old style, you're done. The rest of the recall does'nt apply to you.
The next part:to check the nut size on the revised damper bracket. There were some with a smaller size u-bolt/nut combo and the could loosen. 13mm bad, 15 mm good.
Every body from there gets the new inner drag link tie rod end. And steering wheel recenter procedure (NOT and alignment).
Then they check the pitman arm number if it is NOT 68039930AA or is unreadable, it must be replaced. (2003 to 2008,) (2009 have a different number and identification procedure).
The last procedure was the reason for the temporary suspension, which added the left outer tie rod end orientation and readjustment to the procedure, as it could have been installed with the socket orientation on an offset angle. Readjustment could result in needing the toe-in to be readjusted in rare cases.
The H36 recall is essentially the same repair procedures for 2008 & 2009 vehicles except the factory knows which vehicles they are and who owns them.
That the short version.
Charlie
RegenerationCompleted is offline   Reply With Quote
Old 06-06-2009, 06:08 PM   #14 (permalink)
Thanks Charlie....you rock! BTW my truck is an 07.5 and has the original setup.
Retrocars1 is offline   Reply With Quote
Old 06-11-2009, 09:08 PM   #15 (permalink)
Originally Posted by RegenerationCompleted View Post
Hi
Charlie
So how do I find out if my trucks need this??? one is 07 c&c
one is a quad cab p/u both 3500 4x4
2007 3500, c&c single rear wheel. 2" HBS, Truck Craft Alumium Flat Bed Dump, MEYER 8.5 LOT PRO Plow,
2008 3500, 4X4, Black, Quad cab,
Plow Man is offline   Reply With Quote
Old 06-18-2009, 09:14 PM   #16 (permalink)
Hi
To see if you need any thing done.
1/ look at your linkage where the damper mounts to the link.
2/ If it's a stud through tie bar. No action is required.
The dealer is having the service advisors do this step so most vehicles won't even get to the shop.
3/ If the damper mount is a bracket with 2 u bolts to the tie bar, then it needs to at a minimum get a new inner drag link tie rod end. possibly the full monty (bracket, too).
Thats it.
Charlie
Old 06-19-2009, 06:46 PM   #17 (permalink)
04SSHD's Avatar
I got that one too...
07.5 Dodge Ram 3500HD SLT 6.7L,11/06 build,5/08 delivery,PMT,DPF & EGR fell off,G56,4.10 (3.73 soon),C&C,HBS,5000k HID Solutions lights & fogs,14,000 miles to date,37" M/T,22.5's soon,Dyno at 445hp/907tq
04SSHD is offline   Reply With Quote
Old 06-25-2009, 05:02 PM   #18 (permalink)
15 Digger's Avatar
H 46 recall
My 06 with 11000 miles had click when turning and a noise from rear shaft. Also had left upper ball joint worn.I learned from forums about death wobble and heard you should tell them you have violent shake in suspension on certain road conditions. I told them this and they came up with the H 46 recall. They changed the inner links and pitman arm. Mine were original. They also changed all 4 ball joints and did complete rear drive shaft. Good dealer,http://www.cumminsforum.com/forum/im...ilies/lol2.gif
15 Digger is offline   Reply With Quote
Old 07-04-2009, 04:10 PM   #19 (permalink)
Same recall
I got the recall notice from Dodge Canada when I was phoning to find out if my US imported truck had any warranty. Now that I have the info before I take my truck to the dealer, I'm curious to see what will get fixed.
Garrett49 is offline   Reply With Quote
Old 07-05-2009, 07:49 PM   #20 (permalink)
so what is the story on the import into canada. they cover it?
2005 Dodge Ram 3500 SRW 4x4 - Hell bent 2" leveling blocks, 35x12.50x17 Toyo open country MT, Heavy Hauler race trans, Smarty, FBD 5",ADII,Arson III,F1 injectors
Revolution is offline   Reply With Quote
Old 07-07-2009, 06:36 AM   #21 (permalink)
Iwas told by Dodge Canada that they would honor the safety recall under warranty but other than that I am SOL.
Old 07-07-2009, 09:18 PM   #22 (permalink)
gunsammo2's Avatar
Took mine in didn't even go in the shop, the guy came out ,stuck his head under the bumper and said everything ok I could go. Wasn't there 5 minutes
gunsammo2 is online now   Reply With Quote
Old 07-09-2009, 11:48 AM   #23 (permalink)
soflo2500's Avatar
Can anyone confirm that this H46 only applys to 4wd trucks, not 2wd? I took a look at my front end and it didn't look anything like the linkage pics I've seen showing the affected parts.
Todd
2008 SLT Quad Cab 2500 leftover (bought 6/09), 4x2, 6.7L, LSD, Auto6speed, EGR unplugged
Tow lots of boats for www.epowermarine.com
Located in South Florida
soflo2500 is offline   Reply With Quote
Old 07-09-2009, 12:36 PM   #24 (permalink)
MODERATOR
JWH_03_Dodge's Avatar
correct, only 4wd trucks
edit... looks like cab/chassis might be affected too
John - 03 QC/LB 4x4 5sp
Before you post, ask yourself if this is going to add to the value of the thread?
Check out some nice lifted 3rd gens in this months Rig of the Month Vote here
JWH_03_Dodge is offline   Reply With Quote
