code p2509 - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 12-14-2008, 09:09 PM   #1 (permalink)
gixxerjay's Avatar
code p2509
Check engine light came on. Scanned it and it said that I had 1 code.(p2509 powerdowndata lost error)
Anyone have any ideas what this is?
gixxerjay is offline   Reply With Quote
The Following User Says Thank You to gixxerjay For This Useful Post:
broadline (06-29-2010)
Old 12-15-2008, 06:09 AM   #2 (permalink)
Administrator
JWH_03_Dodge's Avatar
what year and engine truck do you have? Take a minute and fill out your signature, and we can help you out :thumbsup
John
Before you post, ask yourself if this is going to add to the value of the thread?
04 F350 CCLB Cummins swap in progress
SOLD-08 Megacab longbed dually
SOLD-03 QC/LB 4x4 5sp
Originally Posted by Winkles View Post
The problem is that common sense isn't so common anymore...
JWH_03_Dodge is offline   Reply With Quote
Old 12-16-2008, 12:20 AM   #3 (permalink)
gixxerjay's Avatar
2007 cummins 5.9
2007 cummins 5.9 2500
Old 12-16-2008, 07:40 AM   #4 (permalink)
Administrator
check your battery terminals, and make sure they are tight and not corroded. :thumbsup
John
Old 12-16-2008, 07:58 AM   #5 (permalink)
Mr. Vehicle Destroyer
Shibbyutman's Avatar
iTrader Score: 7 reviews
Did you recently add any equipment that required grounding on the fender ground bolt? That ground in particular is sensitive to alteration and can cause that code if not tightened enough when reinstalled.
2001 QCLB 3500 Dually 4X4, Stock, FOR SALE 8000 OBO
2003 QCLB 2500 640 HP / 1125 ft/lbs SOLD!
Parts for sale Van Aken SmartBox, Stage II Monster Pump, Twins, and FASS 95, 03-05 Banks 6Gun, TST PMCR w/R37 remote also have another full one w/R49. Parting out 08 3500. http://www.cumminsforum.com/forum/07...-part-out.html.
Shibbyutman is offline   Reply With Quote
Old 12-24-2008, 12:08 AM   #6 (permalink)
Tech Specialist
TSB 18-001-07
Flash: Check Gauges Lamp Illuminates For Alternator Charging With DTC P2502, P2503,
or P2509
OVERVIEW:
This bulletin involves selectively erasing and reprogramming the Powertrain Control
Module (Cummins PCM) with new software.
Ramtech is offline   Reply With Quote
Old 01-07-2009, 07:58 AM   #7 (permalink)
stewajw's Avatar
where is the fender ground bolt located? (besides on the fender
my 07 6.7 shows the p2509 code as well, but the TSB mentioned only says it is for the 5.9 cummins. any thoughts?
INSANITY: doing the same thing over and over again expecting different results - Albert Einstein
stewajw is offline   Reply With Quote
Old 01-07-2009, 08:05 AM   #8 (permalink)
TNdeerhunter928's Avatar
mine threw the same code 3 times already ... i think my batts are going bad ... optima ...have me some waiting at oreillys
2006 6.3L CTD ... 2011 DirtyMaxx 2500 ()
FTE Diesel (216) 496 3600 & TJ's Diesel (731) 453 4483
TNdeerhunter928 is offline   Reply With Quote
Old 01-07-2009, 09:47 AM   #9 (permalink)
I am not sure if the 6.7 has it in the same spot, but it is pretty much right in the middle of the battery on the drivers side fender. It bolts right through with a 10 or 12mm bolt I think. For that matter, I don't know if that is the same place the ECM is grounded for the 6.7 vs 5.9 either.
Old 12-05-2010, 08:33 AM   #10 (permalink)
BoostLee's Avatar
Mine just popped this code up this morning. I put the truck in high idle to warm up and it shut off maybe 3 minutes later. I go outside and it fires right back up but this code is present. Any ideas?
'09 6.7L Mega Laramie : CARLI 2.65 Suspension/Sway Bar/Hydro Bumps/Control Arms/U&L Stabalizers/Diff. Cover, GARMON Transmission, Arson III, 37" KM2's, 4:10's, Walker Evan's, AD165, EFILive, 5"TBE, ISSPRO's, MagHytec's, H&S Deletes/Railplug, AFE Mega
BoostLee is offline   Reply With Quote
Old 12-09-2010, 09:25 PM   #11 (permalink)
Deezel Guy's Avatar
Same here! Mine popped up this morning too along with P0489, it cranked VERY slow and then fired up (made a funny noise in the engine compartment) but that code won't go away. I'm really thinking batteries are going bad and the cold is making it noticable...I'm still running the stock batteries from 07
Anyone any ideas?
2012 F-250 4X4 6.7 Powerstroke Diesel
SOLD 07.5 Dodge 2500 4X4 6.7,Thuren Suspended, HS Tuning
Deezel Guy is offline   Reply With Quote
Old 12-09-2010, 10:50 PM   #12 (permalink)
TRig's Avatar
This just happened to me this morning. I went out to crank the truck and warm her up and nothing. Ultimately it was the batteries, but I get a CEL and the codes are P2509 and 0513.
Not sure what the deal is, but I'm thinking it has something to do when the truck loses power since we're all getting this with bad batteries. I'm driving it tomorrow and getting it reset at parts store and we'll see what happens.
TRig is offline   Reply With Quote
The Following User Says Thank You to TRig For This Useful Post:
grizz7318 (01-11-2011)
