oil leak/oil breather or crankcase vent tube? - Dodge Cummins Diesel Forum
Go Back   Dodge Cummins Diesel Forum > General Forums > Technical Service Bulletins & Recall Support
Technical Service Bulletins & Recall Support Specific discussion of New and Old TSB's For the Cummins Powered Dodge Rams ...NO ADVERTISING
Old 12-04-2008, 10:49 AM   #1 (permalink)
oil leak/oil breather?
Hi guys I`m really new to diesels but agood mechanic when it comes to gas engines.
I just bought an 04 dodge ram 2500 5.9 L last week and have a question or two.
1. there is a plastic blow tube that runs down the side of the engine that blows oil all over the tranny.Is this common? is there a fix? is it indicative of a greater problem? what is that tube? is it like a PVC breather on a gas job?
LENNY H is offline   Reply With Quote
Old 12-09-2008, 10:37 PM   #2 (permalink)
Tech Specialist
that is your crankcase breather - if it's blowing oil bad that could be a problem - does your engine have a lot of blowby with the oil cap off?
Ramtech is offline   Reply With Quote
Old 12-09-2008, 10:58 PM   #3 (permalink)
flatbed fred's Avatar
I have a 98.5 that has this same problem. It is pretty bad actually. Never knew what the real reason for it was. It probably blows a gallon of oil total out of a 3-5k mile oil change. And I do not have a lot of blowby with the oil cap off.
So what exactly does this mean, or what is causing this problem?
98.5 3500 5sp, tst pm3, superchips, bosch 300 inj., afe intake, triple a pillar pod (FP, Boost, EGT), 245k miles
99 2500 auto, k&n, DC-1's with 305/70/16, 4" turbo back w/5" tip, 65k miles
flatbed fred is offline   Reply With Quote
Old 12-10-2008, 09:33 AM   #4 (permalink)
danh63's Avatar
I just noticed a little drip out of mine this last weekend
2005 2500 QC 4X4, Edge Juice w/Attitude, 6" BDS lift, Pro Comp Extreme A/T 37/12.5/17
danh63 is offline   Reply With Quote
Old 06-16-2009, 08:21 PM   #5 (permalink)
yeah my friend just bought a 2005 3500 and same problem seems pretty common but there shouldnt have oil dripping everywhere you go thats not right
hajovskymatthew is offline   Reply With Quote
Old 06-16-2009, 09:14 PM   #6 (permalink)
i just found a interesting website about this problem visit the sit to read more
Modification 3
1999 Dodge Ram 2500 Cummins Diesel - Custom Air Intake - Four Wheeler
Old 06-17-2009, 12:18 AM   #7 (permalink)
Construction Hillbilly's Avatar
i've got a 99 that drips oil out the blow by tube sometiem and sometiems it dont so i jsut extented it till its botu 4 inchs off the ground but it blows white smoke out like a SOB and its been doing that for probaly over 2 years still runs strong the only probalem i have is if its kinda cool in the day its hard to start. and now with the hose that long everyone has to stop me to tell me i have something lose. but i jsut deal with it till i have the time and money to rebuild it.
99 dually 5 speed, 2wd ,edge Juice/Att.,scheid 100 hp sticks, BHAF ,silencer ring Mia , 4" str8 pipe, FASS 150 , Pacbrake, Valair single disk, upgraded mainshaft and 5th gear.
Construction Hillbilly is offline   Reply With Quote
Old 07-21-2009, 09:39 PM   #8 (permalink)
hangtown12v's Avatar
it takes very little oil coming out that tube to make a GIANT mess under your truck
'97 2500 12v XCLB 4x4, 215 injectors, no plate, afc done, Banks big head, Banks gauges, ATO PowerMaster trans, 4" turbo back, aFe Pro5r, Pusher intake, KDP gone, NO SMOG!!
hangtown12v is offline   Reply With Quote
Old 10-21-2009, 05:46 PM   #9 (permalink)
Tayl0r's Avatar
should their be white smoke coming out of this tube?
98.5 24v extended cab, edge comp, striaght stock exhaust, afe cold air intake, 20 inch rims with 27.5 75s. Just painted and new front bumper. 101k miles
Dodge makes it Cummins SHAKES IT!!
Tayl0r is offline   Reply With Quote
Old 10-22-2009, 08:31 AM   #10 (permalink)
danh63's Avatar
I forgot to add back to the thread. I switched out my Edge Juice and my problem went away
Old 11-17-2009, 03:51 PM   #11 (permalink)
I have the same problem, most likely rings or piston...bad news
lildave127 is offline   Reply With Quote
Old 12-20-2009, 07:55 PM   #12 (permalink)
bigorange's Avatar
its an old but nobody mention bad injectors and if theres white smoke coming out too it most likly mean bad injectors , any oil coming out is bad , good luck
05.3500 hamliton push rod,colt cams stage 4, flux 5.1,htt 64-s480,p/p head,zz fab side intake, polish&blance crank and rods,12v rods, fire ring block&head,ats twincp3,twin AD150,opie bypass,valair triple disk,arp 625's, bd intercooler 855HP FUEL ONLY
bigorange is offline   Reply With Quote
