CTD 2-Stage 2 Micron Absolute Fuel Filtration: Baldwin/CAT under truck - Dodge Cummins Diesel Forum
post #1 of 82 (permalink) Old 03-14-2011, 11:51 AM Thread Starter
Dan @ Carli
OCVeloMan's Avatar
Hey Guys. Wanted additional filtration for my CTD so I looked to a very informative thread:
Installing additional fuel filters, GDP w/ Cat 2 Micron, and a Fuel/Water Sep....
If you have any install questions, check/post in there or here.
Parts List:
- (2-3) Favorite local Microbrews: Pizza Port Oatmeal Stout
- (2) Bolts for the seat: M8X25 flange bolt
- (2) Filter base Fleetguard 014278400-S
- (1) Cat Filter 1R-0750
- (1) Baldwin water/sep BF1212
- (1) Fitting between both filter bases: Boss Male X Boss Male #10 = BRE3474-10-10
- (2) Fitting out of the ends of the Filter bases: Male tube X male tube O-ring #10 to a #6 Jic = BRE6400-6-10
- (4) You can use 90degs or 45degs: #6 push- lock 90 deg fem JIC = PAR33982-6-6
- (2) Compression fitting: (2) 3/8 compression to a #6 JIC
OR you use
- (2) 3/8 compression fitting to a 3/8 barb and do with out the 90*
First, as seen in the pictures attach the filters together with the piggy-back O-Ring fitting and attach the bases to your mount. (BRE3474-10-10)
Then, Install (2) 90* push lock fittings onto the bases (inlet and outlet). These fittings should be facing the frame-rail once installed. (PAR33982-6-6)
Remove your rear two seat retaining bolts and replace them with the longer bolts/washers. (M8X25 flange bolt)
Then, attach your mount to the extended threads from the seat bolts under the truck:
Using a small hard line cutter (can be found at home depot for about $6-7), cut your fuel line adjacent to your filter heads and install the 3/8” compression to -6 fitting, followed by the -6 90 (PAR33982-6-6) onto the compression fitting facing the other:
Do the same on the other side:
Install your push-lock hose:
Install your Filters: (Cat Filter 1R-0750 & Baldwin water/sep BF1212)
If you’ll notice in the last picture, my compression fitting is rubbing my return line. To fix this, I ran a zip tie around the fitting and line, then wrapped a zip tie between them to space them out, tightened and clipped.
Once you’ve reached this stage, you’re going to need to prime your fuel system for a couple minutes to fill the filters and restore pressure. I primed my system (Key ON but not started) for one minute, then bumped the motor to reset my fuel pressure gauge which still read 1psi. I primed the system for another minute and bumped it again, fuel pressure read 9psi so I started the truck and let it run for a couple minutes while I Inspected for leaks.
If no leaks are found, you’re done!
I also installed a Baldwin PF7977 in the stock location and, after a full day of driving on the system, recheck for leaks. I have no leaks in mine and, using my STOCK lift pump, am still running 10 psi through the three filters.
OCVeloMan is offline
The Following 9 Users Say Thank You to OCVeloMan For This Useful Post:
10.5stang (03-31-2011), AH64ID (03-15-2011), gholifield (08-28-2011), Mudman1 (12-08-2012), rgsauger (04-05-2011), rufushusky (03-14-2011), scotchwhiskey (10-21-2011), SmokinTheHippies (10-19-2011), tdi2cummins (04-08-2011)
post #2 of 82 (permalink) Old 03-14-2011, 02:35 PM
rufushusky's Avatar
Great looking set up and write up!
2002 Ford F-350 ECLB 7.3 4R100 4X4, 6637 intake, 203* T-stat, 08 diff cover, HPX, Stancor Relay, 6.0 trans cooler
Gone:
04.5 Ram 2500 Reg Cab 48re 205k miles
rufushusky is offline
post #3 of 82 (permalink) Old 03-14-2011, 07:01 PM
CF Chapter President
dieselenthusiast's Avatar
X 2
SOLD - 2006/5.9 Cummins/Big Horn/2500/QCSB/4X4/48RE
2015/3.0 Ecodiesel/Big Horn/1500/QCSB/4x4/8HP70
2016/Travel Trailer/Arctic Fox 22G/LP Cummins Onan Generator/160 Watt Solar Panel
dieselenthusiast is offline
post #4 of 82 (permalink) Old 03-14-2011, 11:34 PM
Quilbilly Brian's Avatar
I have the two baldwin filter bases but dont have the fittings, Hose or hanger. Its a two hour trip for me to get to a place that has all the parts and that is if there are no major tie ups and its not rush hour.. Can you put me in touch with the person who got you your parts and hanger. If the price is right I would give him my business and save me the hassle of driving two hours one way and getting home with the wrong stuff.
2006 2500 Quad cab 4x4, Auto, short box SLT Big Horn inferno red with black rhino liner bed and side panels. Dynatrac Free spin kit with Dynaloc hubs
Amsoil BMK-21 bypass.2" leveling kit Baldwin 12/12
F/W separator under cab, Cat 2 micron fuel filter under hood
Custom Diesel steering box brace.
Quilbilly Brian is offline
post #5 of 82 (permalink) Old 03-15-2011, 12:51 AM
Nice idea putting it under the cab and using the seat bolts to attach it. I need to install a second filter (2 mic absolute) since mine is just a 2 mic not absolute
2004.5 2500 auto 4x4, 35x12.5-20, Smarty S06, afe intake, 4in Superlift, FASS platinum 150, Industrial Injectors and nozzles, 08.5 steering, steering brace
shaggy88 is offline
post #6 of 82 (permalink) Old 03-15-2011, 10:27 AM
NW05cummins's Avatar
iTrader Score: 8 reviews
Nice write up
Jason, 05 3500 4x4 Dually 6sp, Jacobs Exhaust brake, 5" TBE, 2nd gen intake horn, stock air box modified, 50Hp DDP injectors, Home made(2micron cat, Baldwin water/sep w/High flow Banjo bolts) firestone airbags, B&W turnover ball, Buckstop bumper,
NW05cummins is offline
post #7 of 82 (permalink) Old 03-15-2011, 11:09 AM
COFFMAN CUSTOMS
AH64ID's Avatar
Great install! Glad you got it on.
AH64ID is offline
post #8 of 82 (permalink) Old 03-18-2011, 11:47 AM
so since these filters are before the stock w/f separator do you still use the stock filter as well?
2005 Dodge Ram SLT QCSB, 4x4, manual transfer case, 48RE with TransGo shift kit and billet goodies, 4.10's, BW Solenoid, Raptor 150, CAT 2 micron filter, 4" Silverline 304SS turbo back exhaust
BoonDoc is offline
post #9 of 82 (permalink) Old 03-18-2011, 12:15 PM Thread Starter
Dan @ Carli
OCVeloMan's Avatar
see above from my original post...
post #10 of 82 (permalink) Old 03-18-2011, 12:21 PM
I guess I was wondering the point of using the stock filter (5-7um) if you've already filtered to 2um. Seems pointless to me unless your using it mostly for a water separator in which case use a cheaper filter.
BoonDoc is offline
post #11 of 82 (permalink) Old 03-18-2011, 12:25 PM Thread Starter
Dan @ Carli
OCVeloMan's Avatar
Mostly cheap insurance. It will be changed with the other two filters every 30K. I think I can afford the extra $3 for the Baldwin unit if i only have to do it once every 3 years. and it's 5um
post #12 of 82 (permalink) Old 03-18-2011, 12:38 PM
Sounds reasonable. It's there may as well use it. If nothing else it acts as another water separator.
BoonDoc is offline
