Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 08-21-2008, 12:42 PM   #13 (permalink)
TheBigDeOGE's Avatar
Originally Posted by TheNatural31 View Post
I am running 315-75's (35-12.5) on AR 16's.......have a little rubbing and had to trim a little bit back on the fender with a 2" leveling spacers!!
u got pics of were you cut the fender? just wanna see how much and if its worth puttin 35's over 33's
2000 2500 Cummins, billet tranny(switching to 5speed DD), isspro gauges, HOT ROD VP44. 240 ddp'sREDLINE BOX with van akin, HX35,custon intake.6" bullhorn stacks. 2'' coil spacers. Track Bars
TheBigDeOGE is offline   Reply With Quote
Old 08-21-2008, 01:11 PM   #14 (permalink)
Mud Guppy's Avatar
yea, hurricanes mean work for me. but i was thinking. 31" is stock tire, 4 inches difference. maybe a 4in kit will clear them. More PICS!!!
2002 Ram 2500 4by Auto SB
Autometer gauges, Edge Comp, BD Stealth cover, silencer ring mia, no muffler or cat
Mud Guppy is offline   Reply With Quote
Old 08-23-2008, 09:13 PM   #15 (permalink)
bigblue24v's Avatar
Originally Posted by TheBigDeOGE View Post
how bad is it down there? i don't no where you located in florida.
its not so much the winds this round, its the steady rain...we ended up with about 11 inches total, and then trees gave from the ground being so saturated
bigblue24v is online now   Reply With Quote
Old 08-23-2008, 09:14 PM   #16 (permalink)
bigblue24v's Avatar
the smallest kit they offer is 4.5"
before the lift at sttock height, the top of the wheel well was at 39.5 inches
its at 48.5 wight now
somehow I ended up with 7 inches of lift from a 5" kit
the back is only up 4 though which explains the 1 inch lean from front to back
Old 08-24-2008, 08:19 AM   #17 (permalink)
IABountyHunter's Avatar
This is my 99 with 305/17 I need a leveling kit cuz it barely rubs the inner fender other wise they fit great.
Here is the offset.
99 Dodge,ext cab long box,5.9 of course, mostly stock for now, silencer ring MIA, I have so much to learn
IABountyHunter is offline   Reply With Quote
Old 08-24-2008, 08:42 AM   #18 (permalink)
scottd53's Avatar
the reason you got 7 inches of lift you have to added the new tire size in to. so if you went for 31's to 35's you gain 2 inches of height right there. i have 35 ons stock wheels and a level and i rub at full lock.
01 2500 auto w/Edge Comp, Edge Jammer 125hp nozzles, Super B Special, DTT TC and VB, FASS 150/150, 5in straight exhaust w/6in tip, 6in AMSOIL filter , Level kit w/ 35x12.5 STT's, Autometer Gauges EGT,Boost,Fuel Pressure,Tranny Temp. FarmBoysDiesel Powered
scottd53 is offline   Reply With Quote
Old 08-24-2008, 08:54 AM   #19 (permalink)
bigblue24v's Avatar
no...total height gained was 9 inches, 2 inches fromt eh increased radius of tire and 7 inches of lift
I gained 6 inches in the back 2 from tire radius and 4 from the kit
Old 08-25-2008, 10:19 AM   #20 (permalink)
So i guess i'd better stick with 33's then if i don't wanna rub. DANG!
Old 08-25-2008, 12:29 PM   #21 (permalink)
bigblue24v's Avatar
i guess it has to do with the offset, and tire width
like i could and probably will try to squeeze some 37s under there in a year or two, but i would hav to have some taller spring made for the back to get the cali lean out of it
Old 08-25-2008, 01:01 PM   #22 (permalink)
my set out alot. there 17x9 and i have no idea the off set but they stick out pretty good. my myspace pics show how much.
Old 08-25-2008, 05:04 PM   #23 (permalink)
bigblue24v's Avatar
these are 20x10 with either 4.5 or 5.5 of backspacing..but they stick out about 6 inches
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
