Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 08-02-2008, 02:10 AM   #1 (permalink)
SH0RTYS463's Avatar
Death Wobble
So I just replaced Sway Bar End Links, Track Bar, Steering Stabilizer, and got the new heavy duty steering kit from Dodge. Now I can't drive over 50 mph without having the wheel ripped out of my hand the front end slamming all over the place. I rotated the tires about a week ago and feel that they need to be re-balanced, I also desperately need to get my alignment done. Anyone have any ideas?
I think I am going to need to replace the upper ball joints because after lifting they couldn't possibly be at the correct angles...Could they?
If any of you guys have experienced this or have knowledge in this field could chime in I would really appreciate it. I need to be able to get on the freeway! Thanks in advance...
2005 Dodge 2500 Laramie 4x4 Edge Juice w/Attitude, Kenwood DNX-8120 2-DIN, AFE Stage 2 ProGuard, 5" FBD Exhaust, Silencer Ring MIA, 5.5" Lift, Kore Full Race Pack, 35/12.5/18 Xtreme A/T's. Mag-Hytec Front/Rear/Trans. More to Come...
SH0RTYS463 is offline   Reply With Quote
Old 08-02-2008, 03:32 PM   #2 (permalink)
Get an alignment and go from there. Make sure stuff is tighten down especially the trac bar (really tight). You can check for ball joint play by lifting the front wheels off the ground by the pumpkin and push up and down at 12 & 6 o'clock on each tire. Should have no more than a tad of play.
The new Dodge steering is supposed to be the cure for death wobble. So I think something is just coming loose.
2005 SLT Quad 4x4 CTD
Carli Suspension protected by HRC Truss.
firemansdiesel is offline   Reply With Quote
Old 08-02-2008, 04:53 PM   #3 (permalink)
I have had mine in the shop twice for the wobble and about to put it back in again. I have a 2" leveling kit and the dealer is going to remove it, saying that it may be causing the problem, i call BS on that. Anyone else out there with a 07 or 08 with the wobble problem? Dealer told me that they have had NO 07and 08's with the problem. I told them I was going to post and see if i can turn up others with the problem.
White 2007.5 3500 Dually 4x4 6.7 Cummins Megacab. Stock
kwbunton is offline   Reply With Quote
Old 08-03-2008, 12:39 PM   #4 (permalink)
spankdog's Avatar
Well, did you have the wobble before you installed the leveling kit? I hear of a lot of people having the wobble after installing a spacer type leveling kit. Did you check you track bar for looseness or bushing wear? Do a good search on here. You will find plenty of info on death wobble and different cures.
06 2500 QC SB 6SPD AEM AFE MBRP ATS Smarty Diprocols Suspended by Thuren, Carli, Kore, and Lorenz King 2.5s 35" XTerrains, chrome H2s, and a bunch of other stuff
spankdog is offline   Reply With Quote
Old 08-03-2008, 12:42 PM   #5 (permalink)
06ramcummins's Avatar
Check the bolts on the power stering pump. they could be ever so slightly loose. Also check out the bd sterring support. I put one on my truck and could diff. tell the difference.
06 3/4 4x4, Stage 3 ATS tranny w/ five star convertor, auto meter phantom II,aurora 3000, 3% tint all around black beauty, AFE stage II, Smarty TNT, air dog 100, camo seat covers, kicks ystem, 18's moto metal ,33x12.50 baja atz
06ramcummins is offline   Reply With Quote
Old 08-04-2008, 03:10 PM   #6 (permalink)
SH0RTYS463's Avatar
So looks like I need to have my steering box rebuilt. There is 1.5 in. of wheel play in the steering.
Old 08-04-2008, 03:53 PM   #7 (permalink)
r_anderson65's Avatar
There goes 500 hundy. Just had that done about a year ago.
Robert Anderson-04.5 Qc/Sb 4x4 9" Lift, 37's on 18's, Mag Hytec Covers,Full Synthetics Everywhere, S&B CAI, 4" Banks Exhaust, Banks 6 Gun w/PDA
r_anderson65 is offline   Reply With Quote
Old 08-04-2008, 04:13 PM   #8 (permalink)
kupecda's Avatar
I have the HBS 2" leveling kit on mine and I have had absolutely no problems. I drove it for about 1500 miles before I have the alignment checked. When I took it in to have the alignment checked the toe was out a little but not much at all. Everything else was still good.
2008 Ram 3500 SLT QuadCab LB SRW 4x4 6.7L G56 Light Khaki
DiPricol Optix(Pyro/Boost/Diff Temp), S&B CAI, Line-X, B&W Turnover Ball, ProTech, PacBrake Air Springs, HBS 2" leveling kit, MagHytec Rear, Willmore Wheel-to-Wheels, High Idle enabled, JakeBrake EB switch, 276hp 510ft-lb
kupecda is offline   Reply With Quote
Old 08-04-2008, 05:36 PM   #9 (permalink)
CUMMINS114's Avatar
another thing i have found that was a preventable death wobble with leveling kits/ lift kits is if you replace the shocks they need to be a high pressure gas style not oil filled like you find free with most lift kits.
*FOR SALE* 2002 SPORT 2500 4x4 AUTO cummins 5.9 ISB, K&N CAI, HX-40, edge comp, BD-RAD, 150/150 FASS, bd stealth plate, TC switch, Ultra LiteIIgauges, leveled, 03-05 badges, 6"single mitre.
CUMMINS114 is offline   Reply With Quote
Old 08-04-2008, 05:38 PM   #10 (permalink)
One of my company trucks had been having trouble with the death wobble. We took it in to the dealer last week and they replaced the entire tie rod arms, ends, and had it aligned. The driver had been getting the death wobble three times each direction on one particular 110 mile (one way) trip. No problems since!
VTGrad is offline   Reply With Quote
Old 08-28-2008, 04:24 PM   #11 (permalink)
If I want to buy the new steering from my dealer - does anyone have a part number or Dodge's "official" name for this replacement system? It replaced the drag link and both tie rod ends, correct?
cmoschip is offline   Reply With Quote
Old 08-28-2008, 04:38 PM   #12 (permalink)
My truck is at the dealer getting that fixed under warrenty. I will let ya know tommorow.
06 Crew Cab, 4x4, Goerend Full Billet 48RE, 6.5' bed, level kit, 5" T.B Magnaflow, K&N big tube intake,Silver 64,Studded (625's), Big Stick(s),G.D.P belt L.P,Smarty Revo/tnt., Gauges, 3:73 ratio diffs., non-slip rear diff. Lead Foot.
2-2009 Silver Q.C 6.7 3:73 4x4 6.5' bed Stock .....
Laser Tech is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
