Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 11-06-2009, 01:28 AM   #1 (permalink)
BigTime's Avatar
pin top 2.5 system from carli is in my future
Okay im really considering the carli pin top system in the near future. Seems like the best bang for the buck they offer from what i can tell.
My question is how hard is it going to be to install? Im pretty well rounded with nuts and bolts ive done everything from dropping trannys to rebuilding motors. I dont consider myself a welder by any means though. Am i going to have to do any welding with this? How much modification to the truck if any is this kit going to require? Also wondering if this system will take care of any "death wobble" symptoms that may or may not occur in the future.
Im thinking about running 35's on 20's possibly 13.50 wide...for some reason i like the tires sticking out look.
Never been one to cheap out on anything. Just dont want to spend a yearly salary on suspension components...
Carli seems like they make a decent product. they sure as hell make it look pretty on their website anyway...
Thanks, Nick
2004.5 2500 quad cab Laramie. Banks Power catback, AEM intake, Edge Juice w/ Attitude. More Coming!
BigTime is offline   Reply With Quote
Old 11-06-2009, 01:35 AM   #2 (permalink)
Dirt Merchant
67cummins's Avatar
No welding except for the the limit strap lower mount (frame) if you get that option.
This is a great choice and the install should be very straight forward. Your setup will blow your stock suspension out of the water. Now you can build off of this lift down the road i.e. control arms, full leafs King 3inch bomber shocks, billet shock tower etc. All you need is a second set of hands a good jack and some beefy jack stands. Impact gun and some wrenches and you are set!
One other thing is to make sure that you go back nd put a wrench on everything after a couple hundred miles or so!
07.5 6.7L 68rfe Suspended by Kore Tech Series Springs Thuren Valved 2.5 Kings Carli Custom Ca's VH Truss 37 Yoko A/T's Hella 4k's
67cummins is offline   Reply With Quote
The Following User Says Thank You to 67cummins For This Useful Post:
BigTime (11-06-2009)
Old 11-06-2009, 01:46 AM   #3 (permalink)
BigTime's Avatar
thank you for the swift response my good sir.
Old 11-06-2009, 02:53 AM   #4 (permalink)
Dirt Merchant
67cummins's Avatar
Any time man! Keep the questions comin!
Old 11-06-2009, 08:50 AM   #5 (permalink)
07 MegaCummins
Skyd Ram's Avatar
If you don't have the equipment for welding you can still put the whole kit on in your driveway. Then take it to someone to do the small amount of welding that is required for the limit strap tabs.
Depending on the backspace on the rims you are looking at, you may need to add control arms to your wish list to avoid rubbing the back on the fenders.
Your 3rd Gen source for products from:
Carli/Bilstein/Pure Performance/RIZE/Lightforce
BMF Wheels/Edge/SMARTY/Snow Performance/MBRP
AFE/Randy Ellis Designs/H&S/Dynatrac/Shibby Engineering
Addictive Desert Designs/S&B
888-886-2480
Skyd Ram is offline   Reply With Quote
Old 11-06-2009, 11:16 AM   #6 (permalink)
Yeah without control arms you rub the fenders off with 13.50 wide wheels. You need like a 9" wide wheel with like a 5" backspacing. Thats what i run Motometal 20x9 with a 5.71 bs with no rub. I know with CAs you can run 37"s with the right backspacing but not sure how wide you can go if you get the CAs and 35's here is my truck with the starter kit.
Carli Starter Kit with 20"s installed finally
2006 Mega SLT - Carli Starter - Carli trackbar - Fox SS - Magnaflow custom dual 4" - K&N Intake - Magtec tran pan rear diff. - PacBrake airbags - Moto Metal w/ 35x12.5x20 Toyo M/T - Smarty Jr.
titan0454 is offline   Reply With Quote
Old 11-06-2009, 01:02 PM   #7 (permalink)
BigTime's Avatar
i know the pin top is about 3500...does anyone know how much thier control arms run?
Old 11-06-2009, 02:20 PM   #8 (permalink)
BigTime's Avatar
im thinking about going with mickey thompson classic 2's in 20's...not sure which tire to go with though...id like somthing thatll perform in the snow/mud but isnt going to wine like hell like the bfg mud terrains i had on my last truck...any suggestions? The truck also gets used for some light to medium towing (i.e. car trailer) and ive heard mud terrains arent the best for towing. haha
Old 11-06-2009, 02:54 PM   #9 (permalink)
07 MegaCummins
Skyd Ram's Avatar
Those rims are actually not too bad. They are 9" wide with a 5" backspace. If you plan to run 35x13.5 Toyos you may still hit the fender as those are bigger/wider than most 35's.
888-886-2480
Old 11-06-2009, 03:26 PM   #10 (permalink)
It's Only Money!
firemansdiesel's Avatar
Mild Steel Arms= $750
Chromoly Arms= $900 or $950
W/ the Carli Suspension you want, go w/ the mild steel arms. The install is pretty straight up w/ the right tools (jack, stands & required size wrench/sockets) & a buddy to help.
Personally I would stick to a 17" wheel ( 5.5"-6" of BS & no wider than 9") & a 35"/37" tire. Especially if your going off road, more tire sidewall & flex= better ride, even on road.
2009 SLT Quad 4x4 CTD G56
Some Carli Suspension loving coming soon!
firemansdiesel is offline   Reply With Quote
