Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 11-06-2009, 12:23 AM   #1 (permalink)
Overkill 5.9's Avatar
how big is my lift
ok I have had my truck over a year and a half now and it was lifted when I got it. I know it's around 8 inches but I want to make sure. I have 37" tires right now and they look odd almost because they r so small. so here's what I need. anyone with an 8" lift to 10" lift to measure from the bottom of their door to the ground and tell me what u measure
Bully Dog PMT, 8inch lift, 37" Toyo open country m/t's w/ 22" eagles, 5inch straight pipe, Volant cold air, King Coil Overs, King Shocks, silencer ring MIA , Quadzilla Boost Fooler, Thuren Crossover Steering, Thuren Track Bar
Overkill 5.9 is offline   Reply With Quote
Old 11-06-2009, 12:41 AM   #2 (permalink)
i meassured 27 inches but i have a 6 inch lift on 37's (80% tread) so a 8 inch should have 29 and a 10 inch lift should have 31
2003 3500 QC LB 4x4, Laramie, 6 inch revtech lift, 37 inch toyo mt, 18 inch black KMC XD series hoss wheels, S&B cold air intake, AFE 4" stainless steel cat back exhaust with a 5 inch stainless tip, BD power X programmer......and much more to come....
steve2wheeler is offline   Reply With Quote
Old 11-06-2009, 12:50 AM   #3 (permalink)
The easiest way i'd think is measure your coils, then get the stock coil measurement, if on oneven ground etc, your measurment could flaw an inch or 2 pretty easy. Depending on what you mean small, 37's can look small on 6" lift.
2004.5 3500 Quad Cab 4x4 CTD Laramie 6 spd std A few mods
Mocho is offline   Reply With Quote
Old 11-06-2009, 01:21 AM   #4 (permalink)
ok is this measured when your door is open or shut? front or back of door
Old 11-06-2009, 01:44 AM   #5 (permalink)
Mega Blue's Avatar
I have 31.5 and I'm running rize coils up front and 7 inch ouo traction blocks out back this is measured to where the metal rolls to go into the floor board
6.7 Megacab, XRT175/Edge Juice W/Att, Banks CAI, 5" TBE, EGR/cooler MIA, 8" lift OUO, BDS, Rize mutt, Thuren Steering and track bar, Indexed TXVR case, 20" BMF's 37" Toyo's, 2.5 Kings to come!
Mega Blue is offline   Reply With Quote
Old 11-06-2009, 03:26 AM   #6 (permalink)
Ramanian's Avatar
Just take a pic! Weve seen alot of lifted pics on here to be able to narrow down the lift sizes.
02 2500 LB CTD, Auto, AFE Intake, 4" Turbo back, w/6" CAT Stack, T/C Switch, , 11" Off Road Components Lift, 40'' Maxxis Trepadors, PSC Steering Brace, Superchips, Much more to come
Ramanian is offline   Reply With Quote
Old 11-06-2009, 02:40 PM   #7 (permalink)
your not going to be able to tell the difference between 8 or 9 inches from a picture very easily.... a measurment from ppl with a true 8 inch lift and 37's will give me a good idea. basically I'm thinking about going 40's after these tires wear out.
Old 11-06-2009, 02:45 PM   #8 (permalink)
BDGibson4's Avatar
Location: Punxsutawney or Pittsburgh, Pa depending on the part of the week
Just check your clearence at full cock and see if you can clear the bigger tires.
04 2500 HO (Vin C) Quad Cab Short Bed, NV5600, Southbend DD3600 w/ hydros, Tuff Country 4.5" lift with 37x12.50 Geolander A/T, Edge EZ, stacked on Bully Dog Triple Dog W/ Larry CT, Raptor 15094 CR500
BDGibson4 is offline   Reply With Quote
Old 11-06-2009, 08:22 PM   #9 (permalink)
Mega Blue's Avatar
I wouldn't be able to fit 40's. But my wheels hang way out
Old 11-06-2009, 08:56 PM   #10 (permalink)
It's Only Money!
firemansdiesel's Avatar
If you have stock springs in the rear, measure the block (most off the shelf lifts use blocks for the rear lift). That will be your rear height and if there is no front rake stance on your truck. Add 2" to the blocks to get your front height. It will atleast get you in a ball park figure (very close).
Alot of lifts out there call it a 6" lift, 6" in the front and 4" in the rear for a level stance. There is roughly a 2" (maybe a tad more) difference in the rake on a stock truck.
2009 SLT Quad 4x4 CTD G56
Some Carli Suspension loving coming soon!
firemansdiesel is offline   Reply With Quote
Old 11-06-2009, 09:15 PM   #11 (permalink)
It's Only Money!
Also see if there is a spacer in the front on top of the springs. You'll need to add that on top of the front height.
Old 11-06-2009, 10:23 PM   #12 (permalink)
you took this measurment with the door open and where the body rolls into the floor of the cab correct? if so I measure 34" on the dot
