Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 11-01-2009, 09:57 PM   #1 (permalink)
Pure performance 8" questions
I am running the pure performance 8" coilover kit on the truck in my sig. Anyway, i started to get a little play in what i thought were the heim joints in the sway bar end links, and in the track bar. Started making a rattling noise. I ordered new heims for the sway bar links, and a heim and bushing for the track bar. Last night i tore into it to replace everything and found that the heims were just fine, but that the brackets for both the track bar and the sway bar have been ovaled out to the point of letting things move around, and make alot of noise.
Is this normal for this kit? It only has about 17,000 miles on it. Is it something that would be covered under their "abuse proof lifetime guarantee"? I'm a little dissapointed right now.
2007.5 6.7 mega cab. laramie. 68RFE. "screw al gore" deletes. Black Maxx. 8" Pure Performance coilover. 22" badlands. 37" toyos.
2005 Quad 4x4. sport yellow. 6 speed. bone stock.
bad magic is offline   Reply With Quote
Old 11-01-2009, 10:45 PM   #2 (permalink)
um rock krawler makes that lift its junk as the come i had rock krawler on my jeep took it off
timmys 03 cummins is offline   Reply With Quote
Old 11-01-2009, 10:48 PM   #3 (permalink)
i know the dodge is diffrent than a jeep wrangler but they use the same arms and all of my springs and arms where coming apart. find out whats braking take it off call rock krawler and ask for the owner his name is matt nice guy chilled with him in moab he will take care of you
Old 11-01-2009, 11:13 PM   #4 (permalink)
I wouldn't call the lift junk. The components (control arms, track bar, etc.) are very stout pieces. Much, much beefier than stock. The only issue i am having is what is stated above, and i am looking for someone else who has had real world experience with this particular lift to see if they have seen the same.
Old 11-01-2009, 11:25 PM   #5 (permalink)
I only have their track bar but 1 year and 9,000 miles and i've having issues with it to. From the day I installed the track bar it has been nothing but problems....and they are less then eager to help.
2004.5 3500 Quad Cab 4x4 CTD Laramie 6 spd std A few mods
Mocho is offline   Reply With Quote
Old 11-01-2009, 11:49 PM   #6 (permalink)
what kind of problems are you having?
Old 11-02-2009, 10:07 AM   #7 (permalink)
07 MegaCummins
Skyd Ram's Avatar
This is a common problem with many track bar drop brackets when the bolts are not torqued down. Even the slightest movement can allow the bolt to start moving back and forth thus eventually ovaling the hole out.
There is ton's of force exerted against the track bar. That is why the factory one wear out so quickly as well.
Your 3rd Gen source for products from:
Carli/Bilstein/Pure Performance/Black Ops Diesel/DiPricol
ISSPRO/Edge/SMARTY/Snow Performance/MBRP
AFE/Randy Ellis Designs/H&S/Dynatrac/Shibby Engineering
888-886-2480
Skyd Ram is offline   Reply With Quote
Old 11-02-2009, 12:19 PM   #8 (permalink)
Satan's Chariot's Avatar
I welded my track bar bracket, and I haven't had any other problems with the arms or track bar.
2006 Reg Cab 4x4, Suncoast, 7" Long arm, Thuren Shackles, 40" MT/R's, Engine Stuff
1984 Chevy K10, D44 Welded, 14FF, 4" Lift, 38.5x15.5 PJ's
Satan's Chariot is offline   Reply With Quote
Old 11-02-2009, 05:06 PM   #9 (permalink)
ur right its not junk i just wasnt happy with my lift but it flexes like crazy i just hated road manners it had
Old 11-02-2009, 05:28 PM   #10 (permalink)
mudslinger's Avatar
My end links have a little bit of slop, but there is no noise while driving and no noticed change in function.
'03, 3500, 4x4, built auto, PDR Twins, Cool duals, TST,EZ, Smarty, FASS150,DDP 90's, Arson3, HID, 12" Rock Krawler Desert Race lift, 20* indexing ring, OUO drop kit, DSS, 14.5r Michelin XL's on 20" Black Widows, Thuren HD steering kit, Fox steering stabilizer
mudslinger is offline   Reply With Quote
Old 11-02-2009, 05:32 PM   #11 (permalink)
New Mexico Chapter President
sofakingbad's Avatar
i beg to differ...i have had several of there 6" long arm kits on my TJ an Rubicon an never had any problems with ther product.....
2010 CCSB 4x4 Laramie
Previous Cummins:
(2)05's,04,03,02,(2)01's,97,95,93 12v's. 11 total
forsale: 100% stock 03 qclb 4x4 auto. $16,800 obo
sofakingbad is offline   Reply With Quote
Old 11-02-2009, 08:33 PM   #12 (permalink)
DustinB's Avatar
sounds like you shoulda went with a thuren bar!!
2012 Chrysler Town and Kuntry
Twanky Fo's wrapped in wide white walls
lifted 18"s by Two Up Offroad
DustinB is offline   Reply With Quote
