Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 11-03-2009, 09:10 PM   #25 (permalink)
DustinB's Avatar
Originally Posted by ram tuff96 View Post
ok right then so my 2nd gen never spins with the t-case in 2 wheel drive but if i am in 2 low i know for a fact it does so these newer trucks the front dirve shaft is always spining??
that seems like it would be a little rough on parts
oops, i didn't realize we were talking about a 2nd gen... and yes it can be rough on parts
2012 Chrysler Town and Kuntry
Twanky Fo's wrapped in wide white walls
lifted 18"s by Two Up Offroad
DustinB is offline   Reply With Quote
Old 11-03-2009, 09:52 PM   #26 (permalink)
It is an absolutely retarded design. 2nd gens were a TON better.
2004.5 3500 Quad Cab 4x4 CTD Laramie 6 spd std A few mods
Mocho is offline   Reply With Quote
Old 11-03-2009, 10:40 PM   #27 (permalink)
mudslinger's Avatar
That CAD system had issues of it's own though...
'03, 3500, 4x4, built auto, PDR Twins, Cool duals, TST,EZ, Smarty, FASS150,DDP 90's, Arson3, HID, 12" Rock Krawler Desert Race lift, 20* indexing ring, OUO drop kit, DSS, 14.5r Michelin XL's on 20" Black Widows, Thuren HD steering kit, Fox steering stabilizer
mudslinger is offline   Reply With Quote
Old 11-04-2009, 03:43 AM   #28 (permalink)
ram tuff96's Avatar
but there is easy fixes to it as well like home made posi-lock
r those new truck push button 4x4 or what
so the t-case is in 4 hi all the time the axle just isn't locked or what?
96 12v, Driftwood, all orginal47re (even the fluid and filter), 188k, 4x4, 3.54's limited slip, 285/75/16 nitto terra graplers on poished alumin 16's, starwheel tunning, k&n, stright piped out b4 rear tire!
ram tuff96 is offline   Reply With Quote
Old 11-04-2009, 11:08 AM   #29 (permalink)
07 MegaCummins
Skyd Ram's Avatar
Even with the Posi-lock it is still a weak design to have a two piece axle shaft. But it does lessen the wear on the front driveshaft.
The 3rd Gens regardless if they have the manual shift or the electronic shift t/c are in 2wd in normal operation but since there is no unlocking hub or axle disconnect like on the 2nds gens, whenever the wheels move it in then turns everything in the front driveline up to the t.c output shaft.
Your 3rd Gen source for products from:
Carli/Bilstein/Pure Performance/RIZE/Lightforce
BMF Wheels/Edge/SMARTY/Snow Performance/MBRP
AFE/Randy Ellis Designs/H&S/Dynatrac/Shibby Engineering
Addictive Desert Designs/S&B
888-886-2480
Skyd Ram is offline   Reply With Quote
Old 11-05-2009, 10:30 PM   #30 (permalink)
DieselMachine's Avatar
And better than that was the old first gens. I had a '93 before my truck now. Np205 gear driven t-case, bulletproof Dana 60 front end with ball joints that didn't wear out after 20,000, locking front hubs. It sucks that the newer trucks regressed in terms of quality parts on the truck itself.
OH, and damn near EVERYTHING was greaseable!!!
2006 Cummins Quad 3500, LWB, Smarty, Muffler mia, AEM Brute Force HD, Revtek 6" front, 5" rear w/ 35x12.50's on 18's...soon to be 37x13.50s
hp:413 tq:773
DieselMachine is offline   Reply With Quote
Old 11-05-2009, 10:56 PM   #31 (permalink)
Greaseable lasts to long you can't have that! Non greaseable just lasts long enough to make it off warranty. My u-joints lasted the perfect time, just at 80k miles and they are droping like flies, tie rods are sneaking up to.
And yea, locking front hubs is such a great thing from the factory, those 1st gens would plow threw so much stock! Now unless you got a locker you never got a real 4wd, because only 2 frickening tires spin!
If I had to do it again, this 3rd gen wouldn't be in my driveway, I would of got smart and bought a 1st gen 12V
Old 11-06-2009, 08:46 PM   #32 (permalink)
Mega Blue's Avatar
Lol. I guess it would be cheaper and much louder..... Lol
I love my 08. to me all the factory issues are just excuses to upgrade
6.7 Megacab, XRT175/Edge Juice W/Att, Banks CAI, 5" TBE, EGR/cooler MIA, 8" lift OUO, BDS, Rize mutt, Thuren Steering and track bar, Indexed TXVR case, 20" BMF's 37" Toyo's, 2.5 Kings to come!
Mega Blue is offline   Reply With Quote
Old 11-06-2009, 09:28 PM   #33 (permalink)
A bit louder, but a lot more relieable. $1000 and a weekends work and a 1st gen will be just as quiet as your truck. These 3rd gens ain't very good, even the Cummins sure doesn't hold up like it use to. Can't believe how many people you here loosing motors under 100k miles on completely stock trucks. Even in 2nd gens that was unheard of. Don't even get me started on the relieability of the 6.7.......
Yea you can upgrade it, it's just there are SO many things to correct.
Old 11-06-2009, 09:39 PM   #34 (permalink)
DustinB's Avatar
come on man...how many STOCK 5.9's have you heard of blowing up??
not saying it hasn't happened, but i'd bet they're few and far between...
the problems with the 6.7's weren't the engines themselves, but all the emission crap that was added to them.
