Go Back   Dodge Cummins Diesel Forum > General Forums > Suspension Discussion
Suspension Discussion Suspension Systems, Shocks, Springs, and More!
Old 11-01-2009, 06:37 PM   #13 (permalink)
Originally Posted by bthanks View Post
How would dropping your cross member leave you with issues later? All its doing is lowerng the main support, then it just has higher blocks that the tranny bolts 2.... I dont understand why your worried about that but you want to use high angle joints? The only reason for dropping the tranny crossmember so you can clock the tcase 20* instead of 10*
The crossmember is there to support your frame etc, and lowering it will allow things to twist more I am thinking, as I have seen some people complain about it after lower the crossmember. High angle u-joints wouldn't affect anything.
2004.5 3500 Quad Cab 4x4 CTD Laramie 6 spd std A few mods
Mocho is offline   Reply With Quote
Old 11-01-2009, 07:00 PM   #14 (permalink)
ban89's Avatar
Originally Posted by mudslinger View Post
The problem is that those high angle jobs aren't meant to be run on the freeway everyday. I was told that I would burn up a high angle by the shaft shop because of the full time hubs keeping the front spinning 100% of the time. They would be fine with a dynatrac kit though.
Exactly
I ran a dual CV high angle unit on my superduty because of the huge lift. It worked fine on the street because the hubs allow the front drive shaft to stay stationary. If it was rotating all the time like it would on our dodges it would wear out too fast. I also still had a pretty bad vibration around 30 mph when the hubs were locked and in 4x4 because of the excessive movement/angle of the joints.
a free spin hub kit and high angle drive shaft to do what you want is going to get expensive quick.
If you have to lift it 8''+ t-case indexing/cross member drops are just part of the game.
2007.5 w/ 6.7l, auto, XRT 175hp, Suspended by Carli Bilstein 2.65'' and some Carli extras
Class 7 Prerunner 520HP Ford, equal length i-beams/3 link w/ King Coilovers/Bypasses/bumps
ban89 is offline   Reply With Quote
Old 11-01-2009, 07:17 PM   #15 (permalink)
Ramanian's Avatar
Im going thru this same deal with my 11" lift, unless you have a front hub kit that makes it a free floating front axle(non-Spinning unless engaged) you would not be able to just put a high angle joint and/or just lenghten the front shaft. It would brake and send money down the drain. My setup will be adjustable indexing ring, with a lenghtened front shaft and good night. it will be around the $400 dollar mark by the end of the week and ready to roll. Just a lil heads up from my experiance, and many others.
02 2500 LB CTD, Auto, AFE Intake, 4" Turbo back, w/6" CAT Stack, T/C Switch, , 11" Off Road Components Lift, 40'' Maxxis Trepadors, PSC Steering Brace, Superchips, Much more to come
Ramanian is offline   Reply With Quote
Old 11-01-2009, 08:37 PM   #16 (permalink)
Mega Blue's Avatar
Get the ouo kit and you will have zero issues dropping the x-member
6.7 Megacab, XRT175/Edge Juice W/Att, Banks CAI, 5" TBE, EGR/cooler MIA, 8" lift OUO, BDS, Rize mutt, Thuren Steering and track bar, Indexed TXVR case, 20" BMF's 37" Toyo's, 2.5 Kings to come!
Mega Blue is offline   Reply With Quote
Old 11-02-2009, 11:03 PM   #17 (permalink)
DieselMachine's Avatar
I second that, attitude performance ring for the adjustability and OUO crossmember drop to keep things from hitting each other. I'm running this setup on a 6 inch lift but due to the tire and wheel combination I want to run I will have to go bigger. I can do that with this setup and not have to worry about drive line issues.
2006 Cummins Quad 3500, LWB, Smarty, Muffler mia, AEM Brute Force HD, Revtek 6" front, 5" rear w/ 35x12.50's on 18's...soon to be 37x13.50s
hp:413 tq:773
DieselMachine is offline   Reply With Quote
Old 11-02-2009, 11:21 PM   #18 (permalink)
07 MegaCummins
Skyd Ram's Avatar
I've got a couple of customers that now have this setup and are problem free!
Your 3rd Gen source for products from:
Carli/Bilstein/Pure Performance/RIZE/Lightforce
BMF Wheels/Edge/SMARTY/Snow Performance/MBRP
AFE/Randy Ellis Designs/H&S/Dynatrac/Shibby Engineering
Addictive Desert Designs/S&B
888-886-2480
Skyd Ram is offline   Reply With Quote
Old 11-03-2009, 02:40 AM   #19 (permalink)
ram tuff96's Avatar
thats weird i know for a fact my front drive line does not spin in 2 high i don't see y it would the axle is un locked
96 12v, Driftwood, all orginal47re (even the fluid and filter), 188k, 4x4, 3.54's limited slip, 285/75/16 nitto terra graplers on poished alumin 16's, starwheel tunning, k&n, stright piped out b4 rear tire!
ram tuff96 is offline   Reply With Quote
Old 11-03-2009, 09:30 AM   #20 (permalink)
Mega Blue's Avatar
?? 2 g's might be different I don't know
Old 11-03-2009, 12:44 PM   #21 (permalink)
DustinB's Avatar
if your front driveline is stock, it spins the shaft...guaranteed!!
2012 Chrysler Town and Kuntry
Twanky Fo's wrapped in wide white walls
lifted 18"s by Two Up Offroad
DustinB is offline   Reply With Quote
Old 11-03-2009, 02:24 PM   #22 (permalink)
07 MegaCummins
Skyd Ram's Avatar
2nd gens have the front axle disconnect on the passenger axle shaft. Assuming that he has an open diff, it probably won't spin.
888-886-2480
Old 11-03-2009, 02:52 PM   #23 (permalink)
Almost positive 2nd gens all don't spin right from the factory.
Old 11-03-2009, 02:59 PM   #24 (permalink)
ram tuff96's Avatar
ok right then so my 2nd gen never spins with the t-case in 2 wheel drive but if i am in 2 low i know for a fact it does so these newer trucks the front dirve shaft is always spining??
that seems like it would be a little rough on parts
