Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > South Carolina
Old 02-09-2008, 01:24 PM   #13 (permalink)
DIESELDAVIS23's Avatar
sbc is deff. a good company they did the same for me except i put one of there pressure plates to shreads
2001 3500 5SPD SBC CON FE W/SIX SPEED INPUT SHAFT, FASS,240 HORSE DDP INJ. ,IND INJ. HOT ROD PUMP , S300 TURBO WITH CLOSED WASTE GATE ,NOS NITROUS SYSTEM, BD ST SHIFTER,EDGE DRAG COMP,SCORPION SHUT DOWN TIMER,4 INCH TO 5 INCH STACKS,2.5 INCH LIFT WITH 33 IN NITTO TG.
DIESELDAVIS23 is offline   Reply With Quote
Old 02-09-2008, 03:14 PM   #14 (permalink)
HARRISDIESEL's Avatar
Originally Posted by kuntryboy369 View Post
hey man, what SBC did you get? after what i read on their web page, and seeing what your saying about them im sold! i know i want one, i just dont know how much is too much. oh i have an '02 2500, 5 speed, 5'' silverline, fass 95 and edge comp. box, (with some big dreams down the road.) ANY insite would be awsome!
I have a double disc 3600 6 button clutch with billet flywheel If you want a single disc-I would go with a Con OFE for daily driven!! If you want to get dirty i like my 3600 6 DD!! its just whatever you prefer!! Call peter a SBC at 800-988-4345 and ask him what he thinks you need!!! make sure you tell him I sent you!! thanks!! O which kyle is this??
02 2500 4x4 6spd 4.10 tst comp t-bars ddp240s FBDs2monster44 scottyair .093 lines bored tubes IIsilverbullet66/74/14 htt manifold fass150 6in miters watermeth oringed studs spearco sbc dd 20s 35in mudgrapplers 240k 10/4/08 537hp 1050t
HARRISDIESEL is offline   Reply With Quote
Old 02-09-2008, 03:23 PM   #15 (permalink)
Posting Suspended
I just go the con FE and cant wait to get it put in I did install the new hydro's
GETERDID is offline   Reply With Quote
Old 02-09-2008, 05:14 PM   #16 (permalink)
The FE is great but it shakes like my DD in reverse bad!! Ive had 2 Con FEs and loved them!!
Old 02-11-2008, 06:16 PM   #17 (permalink)
ryans01's Avatar
ah come on now Will, that's what 4 low is for
Ryan
2001 4 X 4, 3500, 2nd NV4500, II SO VP, NEW VALAIR CERAMIC CLUTCH AND HD HYDRAULICS, TSTPM3, Edge EZ, AFE, FASS 95, free 5" straight pipe minus down pipe, gauges
399/1116 2/2/08 before EZ IF IT CAN BREAK, CHANCES ARE I WILL BREAK IT
ryans01 is offline   Reply With Quote
Old 02-11-2008, 06:30 PM   #18 (permalink)
dieselpower7.3's Avatar
Originally Posted by Texas Diesel View Post
This is why we use SBC's in both trucks.
Had a problem once and Peter sent a new clutch overnight at his expense.
I sent the old clutch back and he emailed back the dampener springs were not tempered as they should have been.
thats prolly why they make such good clutches. cuz when ever one breaks they get it back and see why it broke and then make it better so it doesnt break anymore. i wish everyone would do this with everything.... wouldnt that be great
06 qc 4x4 6 speed juice with att. hot unlock, sbc dual disk. aem intake.
441hp 920tq
dieselpower7.3 is offline   Reply With Quote
Old 02-11-2008, 07:11 PM   #19 (permalink)
joe.acton's Avatar
Was the clutch not working at all or what were the symptoms? I just put a dual disk in and it rattles like hell until I get a load on it and then it quites down. Not sure if the rattling is normal. The guys at south bend said it was, but It sounds like crap at idle. Driving down the road I don't get any noise out of it.
edge 160h.p. bd twins cam 120h.p. nozzles, fass150,sbc dd3600,4" dual mbrp,cfm+,fluidampr,arp,mag hytec,cfm+,fire rings, springs,8"bds lift,36 1550 mickeys on 20"mickeys,custom ram air hood,amp research power steps,mtx audio,3 tv's
joe.acton is offline   Reply With Quote
Old 02-11-2008, 07:18 PM   #20 (permalink)
blacksmoke5.9's Avatar
is the con fe and 3600 dd both ceramic i heard they make a lot of noise
My 01 ctd 6spd SLT laramie /MBRP tb 4" /285/16 BF a/t's /Granitelli motorsports chip FOR SALE
Dads 02 ctd 6spd /Holley blue/ boost elbow/ TB4"/Quadzilla Chip
blacksmoke5.9 is offline   Reply With Quote
Old 02-11-2008, 07:48 PM   #21 (permalink)
TEXAS SOUTH CHAPTER VP
Jesparza300's Avatar
i want a south bend cluth now evrybody likes them was thinking about BD or goerend
TEXAS COAL ROLLERS SOUTH VP
07.5 dodge ram 2500 4x4 6.7 diesel
68RFE 3.73 gears all stock for now
http://www.cumminsforum.com/forum/texas/
Jesparza300 is offline   Reply With Quote
Old 02-11-2008, 10:46 PM   #22 (permalink)
SmokingFords's Avatar
I like mine con fe. I havent slipped it yet but im going to try
2001 Dodge 2500 Black sport 6 speed Adrenaline/pulse Smoke switch SmartyRevo, F1 Mach3, HTb2 64/14 turbo, 'southbend DD 3250 , glacier pusher system,pyro boost fuel Snow water/ meth ''Soon To Come a 7in DCS Stack''
SmokingFords is offline   Reply With Quote
Old 02-12-2008, 09:43 PM   #23 (permalink)
The fe is feramic on both sides!!! On the DD the noise you hear is the floater plate between the two clutch plates that rattles!! It is normal and yes it sound like a hand full of s with hammers tryin to beat your apart but I works great!!
Old 02-12-2008, 09:47 PM   #24 (permalink)
jd_2001's Avatar
i had the samr great service less then a month ago they replaced averything for free they even paid trhe shipping for the old one and the new one
all i can say is
SOUTHBEND CLUTCH:w oot:
2001 2500 white ext cab /edge comp /edge jammer 5's/nitrous/II silver62/hot rod vp44/fass150/studs-orings/ ported polished/valve springs/fluid dampr/southbend fe.
jd_2001 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
