Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Pure Flow Technologies
Pure Flow Technologies Pure Flow Technologies
Old 09-04-2009, 05:37 PM   #1 (permalink)
PureFlow Technologies
2Tone12V's Avatar
AirDog Filter questions
There has been a thread started with some questions on filter we have on the units. I took it off as it was a link to a site we do not support. So I will chat with you on this thread. The filter ratings are correct you have seen. THOUGH, compared to others aren't near as bad as someone has made it seem. I will have to get my micron ratings and things and put them all together to be 100% accurate. Both filters are being "reworked" at this time. We do have samples in and are VERY please with the filtration and water seperation results. I hope to have these available very soon.
2Tone12V is offline   Reply With Quote
Old 09-04-2009, 06:01 PM   #2 (permalink)
AdamRRT's Avatar
Okay that's respectable that you admit that the numbers are accurate, and that the AirDog isn't really filtering anywhere near the normally used Baldwin that we use in our stock canisters. I will be installing my AirDog2 very soon. Can you link me to or describe the process in detail of running the AirDog to the stock filter canister, please? That would allow me to have acceptable filtration while waiting on the improved filters from PFT. Thank you.
2006 Mega 2500. Smarty, XZII, HOT J/A (gauges), HTS trans, Edge TC, GM gov sol, AirDog II, Silverline muffler, 35's on 18's, 4" lift, -cat, -baffles, -silencer.
2001 Corvette C5. Tuned by BLUECAT.
AdamRRT is offline   Reply With Quote
Old 09-04-2009, 06:32 PM   #3 (permalink)
2Tone12V's Avatar
Well what I need to do is put together x micron filtration @ x gph and compare it to the stock one. ah??? username may have it. I have to search and find it and I just don't have the time today. I will however do it first thing Tuesday.
Old 09-04-2009, 06:33 PM   #4 (permalink)
AdamRRT's Avatar
ah64id I think.
Old 09-09-2009, 01:09 PM   #5 (permalink)
Local Rotor Head....
ah64id's Avatar
3rd Gen Popular Fuel Filter Data
and the TSB... I know is say 06+, but what is different on the HPCRs from 03+? Nothing.. and all the dealerships I have called only sell the new filter.
TSB 14-007-06
ah64id is offline   Reply With Quote
Old 09-27-2009, 07:45 PM   #6 (permalink)
kjpcummins's Avatar
Anthony have you guys gotton anywhere on the new filters yet?
2002 2500 4x4 6 speed
Please provide physical proof to back this up.....or refrain from posting it.
Engineered Diesel Turbos/Southern Diesel Extreme Injectors
kjpcummins is offline   Reply With Quote
Old 10-06-2009, 02:37 AM   #7 (permalink)
any updates. needing new filters like yesterday, have my spare one on but if i can get better ones all the better
MINE:2003 3500 cummins SO,auto 4x4 QCLB,4"MPRB,edge ez,Smarty POD,AirDog 100,75 horse Jammer injectors(gone),Goerend TC,VB,Input,Suncoast clutches/steels
DADS:2008,2500 SLT 68rfe 4X4 QCSB,BONE STOCK
'91cummins6gun is offline   Reply With Quote
Old 10-06-2009, 09:36 AM   #8 (permalink)
2Tone12V's Avatar
We do have them. All is well with them but don't have enough to start shipping yet. I will check the status on them and let you know.
Old 10-19-2009, 08:16 PM   #9 (permalink)
ah64id's Avatar
What are the specs?
Old 10-23-2009, 10:33 AM   #10 (permalink)
hot rod4's Avatar
Looking for a status update. I will need filters here real soon as well.
2003 2500 4x4, S.O., 5 speed, QCSB, Magnaflow duals, 325/60's Pro Comp XAT on Gear Alloy's, leveled, Isspro on pillar, Air Dog 100, Valair Clutch, SMARTY, F 1.8s, 6.7 cp3, Homebrew stocker over A5K
hot rod4 is online now   Reply With Quote
Old 10-28-2009, 08:26 PM   #11 (permalink)
New Air Dog Fuel Filter Specs
The pdf attached is the specs emailed from Toby for the FF1000 fuel filter
blackpoint is offline   Reply With Quote
Old 10-28-2009, 08:31 PM   #12 (permalink)
Air Dog water seperator specs
and the water seperator specs ....WS100
I guess the pdf file is too large
the specs are
efficiency ... 99% @ 20 micron
efficiency ... 85% @ 10 micron
capacity ... 9 grams
element collapse ... 100 psid
hydrostatic burst ... 300 psi
impulse fatigue .. 0-100 psi, 25,000 cycles
