Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > North Dakota
Old 08-27-2007, 06:32 PM   #1 (permalink)
pedal dies
i've got a 01 ram 3500 cummin ho six speed. i just bought it. when i left work today the check engine light came on and i lost pedal. i limped it off to the side of the road and shut the engine off and started it again seemed to work fine i went to o-riellys and checked fault codes i had 2 codes throttle pedal switch a performance problem and an over boost condition. i cleared the codes drove almost all the way home and it did it again. its stock except for straight pipe exhaust. wondering if there are seperate idle validation switchs or if its all part of the throttle position potentiometer.
Dieselboys is offline   Reply With Quote
Old 08-27-2007, 06:48 PM   #2 (permalink)
CumminsFan04's Avatar
Dead pedal....sounds like a injection pump to me?
'01.5 Ram 2500 Sport Q/C S/B 6spd Cummins 4x4
-Few things...
CumminsFan04 is offline   Reply With Quote
Old 08-27-2007, 07:06 PM   #3 (permalink)
dobienut's Avatar
I'd check lift pump pressure before I did anymore driving with it! Maybe you'll be lucky enough to catch a failing lift pump instead of a VP
2002 245Hp HO CTD,6 Spd 4x4 quad cab short box ,Glacier Fuel BOSS mechanical lift pump! Shake, Rattle and Roll...Cummins! http://img145.imageshack.us/img145/6...lmediumsp2.jpg
dobienut is offline   Reply With Quote
Old 08-28-2007, 09:16 PM   #4 (permalink)
lift pump checks out diesel tech at dealer said it was more than likely the throttle position sensor told me i really didn't need to watch pressure more concerned with pump flow so i checked pump flow and pressure. after doing so check engine light went out and hasn't acted up sense drove 10 miles or so.
Old 10-27-2007, 08:48 AM   #5 (permalink)
jr22's Avatar
what codes where set??. Usually you dont get dead pedal on stick shift trucks because of the tps. I started to have same issues with mine and the vp44 was shot after replacemment my issues went away. jr
1997 F-350 reg cab 7.3l at 270k For sale, 2008 dodge ram 3500 qc lb 6.7l 6spd
jr22 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
