Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > North Carolina
Old 12-12-2007, 06:36 AM   #1 (permalink)
cummins2001man's Avatar
Thumbs down fuel pressure checking
i checked the fp on my stock truck yesterday at the test port fitting. i used one of the fp gauges from autozone thats liquidfilled with the truck running it was about 10 psi when i reved it would drop to 0 or 2 psi is this normal or is transfer pump going going gone, also i bought ne buypass lift pump from bd diesel should i stop driving the truck untill i put the new pump on or am i ok thanks any help would be nice...
2001 2500 4/4 straight piped 410's 6spd K&N, Silencer ring MIA, 4 in. new holley lp and edge juice with a2\hot/, taped 'pump wire'
cummins2001man is offline   Reply With Quote
Old 12-12-2007, 06:53 AM   #2 (permalink)
Super Moderator
rbmchief's Avatar
at that low a pressure your harming your injection pump. if you have something else to drive untill you get your bd on i would do that.
02 2500 slt 4x4,auto,icebox cai,silencer ring mia, Quad xzt+,jhook, Pinnacle 4" turbo back exhaust,westach elec fuel guage, isspro transtemp,boost,egt guages in pillar, line x in bed, runnin 2 stroke.
rbmchief is offline   Reply With Quote
Old 12-12-2007, 06:57 AM   #3 (permalink)
so the way i checked it that sound right.
Old 12-14-2007, 05:51 PM   #4 (permalink)
Cummins crazy
bway1341's Avatar
Call Gus and buy a fass
I got a gasser for now.
http://www.farmboysdiesel.com/
Wifes 05 2500 Afe Stage 2 South Bend DD-Clutch Air Dog 150, Smarty, Edge Juice with Att. And some more stuff
bway1341 is offline   Reply With Quote
Old 12-15-2007, 09:30 AM   #5 (permalink)
Farmboy's Diesel
farmboysdiesel's Avatar
Let me know if I can answer any questions.
Farmboy's Diesel Performance
FBD BUDGET EXHAUST
Products By: FBD, AirDog, Blue Chip, DDP, Smarty, TS, MaxSpool, HaloMax Springs, Grand Rock, Fluidampr, AFE, Edge, TST, MBRP, Industrial Injection, ARP, Auto Meter and More
704-290-2289
1999 Dodge 2500 4x4 II 66/FBD2 TWINS, 7in Stack, HTS/FBD Tranny, DDP Inj's, FBD Trik 3VP, HaloMax Springs, MaxSpool, NX SD2, Fluidampr, DragTST
Check out www.farmboysdiesel.com
farmboysdiesel is offline   Reply With Quote
Old 12-16-2007, 09:06 AM   #6 (permalink)
just got new bd oem buypass pump on it only reads 8-10 at idel and 5-7 at wot is this normal.does anyone else have this pump,or am i in the dark on this .any help ....
Old 12-16-2007, 09:11 AM   #7 (permalink)
Ontario Chapter President
CumminThru's Avatar
You NEED a minimum 8 - 10 at WOT, my FASS wont drop below 13 at WOT and I'm not running any comps or fuel boxes.
Dan - Ontario Cummins Crew President Ontario Chapter
GONE but never forgotten - 2001.5 24V QC SLT Laramie 2wd 47RE/3.55, LB, ICEBOX w/4510, FBD 4" turbo back w 5x18 SS tip, silencer ring MIA, FASS 150, IIS HRVP, DiPricol 30 psi FP guage, 1 qt 2 stroke EVERY tank!! 16.5481 @83.29mph on 7/7/07
My new ride .... for now - 06 JEEP LIBERTY CRD. NO MODS, its a lease...
CumminThru is offline   Reply With Quote
Old 12-16-2007, 10:56 AM   #8 (permalink)
Smokin 5.9's Avatar
I ran the auxiallary pump for awhile with a new pump at the block and had 32psi at idle and 28 at wide open throttle, you should see about 15psi at idle
00 QCSB, AFE, 5" Miters, Injs., HRVP44, Edge Drag, Redline, Gauges, SB DD, S400 w/ Manifold, & Hose & Clamp Kit, CD Timer, Head Fireringed, Port & Polished, HD Valve Springs, A-1 studs, Haisley Street Grind Cam, Fluidampr, Water/Meth, PSI fuelsys.
Smokin 5.9 is offline   Reply With Quote
Old 12-16-2007, 11:06 PM   #9 (permalink)
I have seen 7psi on mine sometimes if I'm not mistaken the flow rateing is more important than psi the stock pomp is rated at appox 40-50 gpm bd pump is rate at 100 or 120 cant remember
2001 HO 215k 6 speed juice w/att, 100hp jammers, 4in exh, s&b intake, bd lift pump, south bend ofe, 3in spacer, pro comp s9000 shocks, 35 nitto terra grapplers
mopar440 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
