Go Back   Dodge Cummins Diesel Forum > Community Hall > Chapter Forums > New Jersey
Old 01-06-2009, 05:36 PM   #37 (permalink)
Cummins FTW's Avatar
There is no right way of doing the swap and getting it inspected... Self Inspection is a Diesel thing only.. You still have a EPA tag and Vin of a Gas truck
.... The Self Inspection thing in itself isnt really right.. Just cuz your registration says 10,001 and Tag on the door has the trucks GVW...
O well tho... My vehicles will never be legal and I dont really care..
05 BLK'd Out 2500 CTD 4x4 Auto,.. Full Dipricol's 4' TBE AFE Stg.2 Intake CFM Smarty@Revo #3 398/747 @ Spring Fling '09
97
BLK 2500 CTD 4x4 5pd, 4'TBE, Pump Mods w/ 0 plate, Haisley Puller w/billet input
Cummins FTW is offline   Reply With Quote
Old 03-26-2009, 11:09 PM   #38 (permalink)
anotherrepoman's Avatar
that happens to me all of the time and i always go in and talk to the prosacutor and get it drop everythime and i tell them to pay for the court cost lol everyone of of my trucks
anotherrepoman is offline   Reply With Quote
Old 03-27-2009, 10:52 AM   #39 (permalink)
blk90s13's Avatar
ok lets get this thing clear
if your door tag say you have a GVWR of 10,001 + and diesel powered you are not required to be inspected
if you had a 5.4l and now its diesel powered and your GVWR is higher than the 10,000 mark you will not be inspected ( even tho I doubt a gas crew cab dually 5.4l have a GVWR of 10,000 or higher ) so u are stuck inspecting it but now that its diesel u would only get safety and brakes no emissions
just make sure they put it in the system as diesel some inspectors tend to just go with the reg scan bar info which would reflect a gas powerd truck
the truck must be higher than the standard factory height by 4 inch lift and every truck and car out there have a measure from the bottom of the door to the ground if you exceed that you will get a tilt test
your tires should not stick out the fenders by more than 2 inches and if you get busted for less you are cool just fight it
you can get a copy of the rules from the main DMV office in Trenton if you walk in or mail them asking for inspection requirement and rules
good luck all
2002 QC SB 2500 CTD/auto 4x4 :thumbsup
Edge / diesel dynamic gauges ( egt/boost/trans ) /BD oem bybass lift pump /4 inch exhaust / k&n filter and shield / 4.10 rear / 2 inch leveling kit/pricol 30psi fuel pressure gauge on the column
Help Support CumminsForum.com by upgrading to Premium Membership
blk90s13 is offline   Reply With Quote
Old 04-02-2009, 03:51 PM   #40 (permalink)
what forms do I need?
I am going to register my truck, do I fill out the regular registration, or is there a commercial one I need to fill out? I want to be sure to register the 10001 lbs. What is the cost difference for plates/reg in NJ of you are in the 10k+ weight class, and do you require special insurance, or is insurance more expensive on a higher weight class vehicle?
rkaiser is offline   Reply With Quote
Old 04-02-2009, 05:43 PM   #41 (permalink)
you dont need a commercial reg all you have to do is go to the dmv and put the gvwr on the white paper it is alot more for reg i just renewed mine and it was about $200 but you should carry the self inspection papers with you
Old 04-02-2009, 05:43 PM   #42 (permalink)
oh and also you dont need special insurance
Old 06-24-2009, 12:58 PM   #43 (permalink)
I am about to register my truck in NJ. After I fill out the form 10,xxx GVWR at DMV will they provide me with the self inspection forms?
Also, Do you guys modify your door stickers too?
Peto is offline   Reply With Quote
Old 06-24-2009, 02:26 PM   #44 (permalink)
I registered my truck
I registered my truck as 10001 lbs. The DMV office said, "diesel, 10,001 lbs, you qualify for self inspection". They didn't have any other information to offer me. I read online you have to keep maintenance records, but not a specific checklist of what is supposed to be inspected. Not to jinx myself, but I haven't been pulled over yet. I did not modify the door plate. Hope this helps.
Old 06-24-2009, 02:28 PM   #45 (permalink)
What DMV did you go to?
Old 06-25-2009, 10:52 AM   #46 (permalink)
Right on 202/31 in flemington, near the home depot.
Old 06-25-2009, 01:30 PM   #47 (permalink)
Thanks.
I'm about 40 minutes from Flemington. I'll make the trip there though so I don't have any problems.
Not commercial, right?
You just filled out the form?
Old 06-25-2009, 04:25 PM   #48 (permalink)
its not commercial, and I didn't register or insure it as such. I walked into the DMV to register and title, title already had 10001 lbs. on it. So not sure if that made the process easier. Though they didn't even compare the weight from the title, to what I wrote. So you should be fine. The DMV there is pretty quick at getting people in and out so it should be fine.
