Go Back   Dodge Cummins Diesel Forum > The Market Place > Site Sponsors > Holland Court Diesel Performance
Holland Court Diesel Performance Holland Court Diesel Performance
Old 01-09-2009, 11:58 AM   #13 (permalink)
Danderson's Avatar
Sounds like you might have a money maker with a complete canister mod kit for the aftermarket pump customers. Sure does beat driving around sourcing out all this stuff. Nice work!
'07 2500 SLT,5.9,reg.cab.,G-56, 4wd,8' Northstar popup 24/7. Carli,Defiant,Thuren,King.
Danderson is online now   Reply With Quote
Old 01-09-2009, 12:26 PM   #14 (permalink)
Colorado Chapter Pres
jbarker's Avatar
thanks. all we need now is a few canister here so we can mod them up and send them out
John
99, QC short bed running the best of the best and proven to perform. 715 h/p 1400ftlbs 4-18-09
Give us a call for the best of the best. Quality brand names with service you can trust all backed by nation wide warranties. Pureflow, Valair, BD power, DDP, HTT, Industrial injection, Dipricol, Quadzilla, S&B, Snow performance, Edge, Diamond eye, MBRP, PDR and more. We install what we sell
jbarker is offline   Reply With Quote
Old 01-09-2009, 12:29 PM   #15 (permalink)
snackpack's Avatar
um, i'll be on the list for one of those
02 QCLB 6 spd quad adrenaline/ pulse.. arp 425's.. silver 62 (62/14/74) .. s&b intake.. 150 sticks.. southbend DD 3600.. airdog 150.. ats arc flow.. silverline dual 4" .. CUSTOM ram air intake... rollin 285 70 17's .. waiting for warmer weather to go in II SOVP
snackpack is offline   Reply With Quote
Old 01-09-2009, 01:39 PM   #16 (permalink)
btolenti's Avatar
John can you PM me a price on all the parts needed to do this? All my extra fittings from my airdog kit are long gone, so I will need to buy them all new.
06 Silver Quad Cab 4x4 Automatic
-4" Rancho Lift w/Superlift Traction Bars & Defiant Steering Support, 315 MTZ's on H2's
-Smarty, AFE Intake, Muffler Delete, Airdog100/Liberty Setup, ISSPRO Gauges, Amsoil BMK-11
btolenti is offline   Reply With Quote
Old 01-09-2009, 05:46 PM   #17 (permalink)
Need more money 4 habit!
Talon4u2nv's Avatar
John
you can put me on that list for sure....i would be nice to not have to worry about it on the road trips
keep me posted John...I just got my daily put back together so i may be giving you a ring about one of these set ups
2000 Ram 2500 QC Sport
K&N Intake with Amsoil filter, 5" soot pipe, Autometer boost/egt/fuel/trans temp, 100hp sticks, Airdog150, Full Billet DTT (with 48RE valve body), Adrenaline with Pulse, Stealth Plate, 285/70R17 Rubber
Waiting for: HTT 62/71/13ss, ARP Studs and hopeing for some O-rings
Talon4u2nv is offline   Reply With Quote
Old 01-11-2009, 07:07 PM   #18 (permalink)
dfairchild19's Avatar
i pulled my bed to open her up again to see if i could rid of this 1/4 tank issue and went to my hardware store and all they had was brass gas line fittings. does anyone know if i can use brass gas line fittings in place of the original fittings?? it was all my hardware store had and it being a sunday, there isnt anywhere else open to get any of the actual hydraulic fittings. everything on them matches up, the push loc and the flares as well are all the same. im just worried about the diesel eating at the brass??? anyone know for sure about this??
2001 4x4 QC short bed, afe, 5" FBD straight, Edge J/A, Airdog 150, Goerend tranny, FBD injectors, o-rings, arp studs, htt 62/71/13ss
OHIO COAL ROLLERS
dfairchild19 is offline   Reply With Quote
Old 01-12-2009, 10:39 AM   #19 (permalink)
jbarker's Avatar
brass is no issue we use it all the time and gas is more corrosive then diesel
Old 02-18-2009, 03:32 PM   #20 (permalink)
Banned
Got it John Thanks
I have questions.
Can this be done without disabling the factory pump? I was kind of trying to keep it in there as a back up.
Steve
Polaraco is offline   Reply With Quote
Old 02-18-2009, 03:50 PM   #21 (permalink)
jbarker's Avatar
its pretty tight in there and we have never tried that. you will have to disconnect the power to the oem pump also and this can be done from outside the unit by cutting and using a spade terminal to reconnect later if needed. i am sure you can make it work
John
Old 02-18-2009, 04:03 PM   #22 (permalink)
Banned
John
DUHHHHHHHHHHHHHHH How do I do dat?
Yep and I use Vasoline on every electrical connection not soldered. I also put shielded spades on with the Vasoline and heat shrink over the shanks. Have not seen corrosion on any connections, even after years. I got some pretty old custom cars laying around here.
Can't I just pull the factory fuel relay?
Old 02-18-2009, 04:31 PM   #23 (permalink)
jbarker's Avatar
sure as long as it dosent run anything else
Old 02-18-2009, 09:17 PM   #24 (permalink)
Shagginwagon's Avatar
Is the 05 canister the same as my 07? I have a spare canister but it came off an 05. I have an 07 and was wondering. I'm thinking of doin the DSV along with the AD150.
'07 2500 5.9L Mega, Black, Laramie, 4X4, 48re
Isspro's, AFE Pro Dry, BMK-11, AMSOIL fluids, Debadged, CFM+
S-06, Mag-Hytec Covers
IAFF Local 1159
Shagginwagon is offline   Reply With Quote
