Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 12-29-2005, 05:21 PM   #1 (permalink)
Guest
Posts: n/a
*After Market Exhaust
Tech articles are in the process of being restored, please bear with us during this process
Cummins Forum Staff
Old 12-30-2005, 03:11 AM   #2 (permalink)
Wyoming Chapter President
Perfect timing Kev. I ordered Rip's 4" kit for $279 last night. I'm all pumped now.
'98 12 valve QC SB 5 speed Laramie SLT 4x4. PDR 11 plate, 3k GSK, 4" Pac Brake, SBC, II Phat Shaft 62/80, Rip's 4" exh.
TPCDrafting is offline   Reply With Quote
Old 12-30-2005, 07:35 AM   #3 (permalink)
Guest
Posts: n/a
I Beleave this Is rips 4" Going On
http://www.dodgedieseldatabase.com/4_&_magnaflow.htm
DM
Old 12-30-2005, 09:19 AM   #4 (permalink)
Tech Specialist
AZBLACKSMOKE's Avatar
Man, I wish I would have seen this earlier. I just ordered my 4 in. system from Warp Speed Performance. $308 shipped from Arkansas to AZ. I hope its a good system. Anybody heard of them? They have excellent feedback on Ebay.
2001 Chevy Xcab,4x4,LB7/Allison, Straight4in, predator.
Previously a 12valver...
AZBLACKSMOKE is offline   Reply With Quote
Old 12-30-2005, 02:09 PM   #5 (permalink)
Guest
Posts: n/a
Reading out of my latest Diesel Power Magazine they have an article called "Pipe Dreams" it has some good points especially toward sizing.........read on
Pipe Dreams
Diesel enthusiasts already know the great power potential and more efficient fuel consumption offered by a diesel truck.All that power and economy doesnt come without picking the right parts though. An after market high flow exhaust system has to do more than simply make your truck sound better. Point in case with a 4" vs. 5 or 6 inch system, how big do you need to go? To answer that first we need to go over a few basics.
On most contemporary turbodiesel engines, the exhaust comes right off the exit of the turbo and after market exhaust manufacturers offer more than one tubing size to vent the exhaust more quickly.
One advantage of moving exhaust gasses quickly and efficiently is to reduce buildup of heat. Turbo diesel engines generate alot of heat, especially when the engine is under a heavy load. A high flow exhaust actually allows your diesel engine to run cooler and adds the potential for more boost when towing.
Large diameter tubing also reduces backpressure, making it easier for the pistons to shove that exhaust out of the cylenders and resulting inmore horsepower. Less backpressure allows the turbin to spin more efficiently, therefore it will build boost quicker and run cooler.
Interestingly enough however there is a point where bigger isnt necessarly better. While engine testing indicates that going from 3-1/2" to 4" can reduce backpressure by as much as 98%, ther can be less than 2% reduction above 4" exhaust. SO while a 5 or 6" exhaust looks cool it wont give you much more than just a coolness factor.
Old 12-30-2005, 08:00 PM   #6 (permalink)
Tech Specialist/Super Moderator
TrueValue Truck's Avatar
After reading that article, does it make sence that the slugish low end I thought I was feeling with the cat and muffler removed was real or not?
It almost felt like it needed something there.
With the high performance exhaust on it now , it just feels more responsive starting off.
Caldwellfire.com
06 3500 SRW MC ,Smarty REVO,X2 Race stack, Commander,CFM, Monster Air COI,AFE Torque tube,FASS 150 HPFP LP,Muffler delete,Tipple disc Converter and VB ,ProComp 2" leveling kit,Timbren's,Reese Class V Tow Beast
Ohio Coal Rollers
Cumminsforum.com
TrueValue Truck is offline   Reply With Quote
Old 12-30-2005, 08:08 PM   #7 (permalink)
Guest
Posts: n/a
It prolly is more responsive as the lesser back pressure is allowing for quicker spoolup .......kinna like a slingshot yaknow
Old 12-30-2005, 08:44 PM   #8 (permalink)
I put a JJardine "Pinnacle Power Exhaust"4" system on mine and it fits nice! And its lifetime warr!
96 3500 6x6 excab,6sp,410LSD,200k,4"JJardine,KDP tabed,S&W Gages,#11 plate and bhaf,4k gsk,SBC,HTT stage 3 charger
GWest is offline   Reply With Quote
Old 12-30-2005, 11:55 PM   #9 (permalink)
Tech Specialist
Pipe Dreams
Interestingly enough however there is a point where bigger isnt necessarly better. While engine testing indicates that going from 3-2/2" to 4" can reduce backpressure by as much as 98%, ther can be less than 2% reduction above 4" exhaust. SO while a 5 or 6" exhaust looks cool it wont give you much more than just a coolness factor.
That is a great article. I would love to read it all. You would not believe how many people I know that actually think that too big of an exhaust will kill performance. I have spent a lot of time contemplating this. I do know for a fact and from personal experience, that this is true for gas engines. When you factor in high compression, turbo, and the sheer fact that diesels have no throttle plates or butterflies to regulate the air, it just makes sence. The more air you can get in and the quicker you can get it out is a diesel engines key.
It has even got to the point with my diesel buddys that I was kinda thinkin they were right. Thus the reason for my backpressure thread somewhere on this site.
Anyway, great article and great post Whit.
Old 12-31-2005, 02:47 AM   #10 (permalink)
BigD's Avatar
What about MBRP? Any good? I know it's a little expensive, but does anyone have any feedback on their exhaust? I really like their "cool duals."
D
2007 Ram2500 Laramie Mega Cab 6.7 auto 4X4. N-Fab nerf bars, pre-runner, rear runner 2" level kit, 20's XD795 Hoss - Black. BFG's 305/55/20 Hella 4000 lights. Smoked cab lenses. I'm done with the outside!
BigD is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
