Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 11-03-2005, 06:33 PM   #1 (permalink)
Guest
Posts: n/a
*Power stearing pump in the winter - NS
How many times have you started up yer truck in the cold months and wondered what that growl sound was? Its the power stearing pump trying to turn thru that dino oil, I switched mine over to synthetic automatic tranny oil,I am sure there are many other brands of synthetic oil that would do the job but that is what I run in my transfer case and I had some on hand , The power stearing pump sounds much better now and the growl is gone on cold starts. The job was simple, I jacked the front of the truck up and pulled the lower hose off the pump and let it drain out into a bucket, then I turned the stearing wheel lock to lock to get all the fluid out possible, put the new fluid in and run wheel lock to lock several times to purge all air out of system and all is well now.
Cheers, Kevin
Old 11-28-2005, 03:54 PM   #2 (permalink)
Moderator
I used to recommend switching over to synthetic to eliminate the winter squeal but have found that Lube-Gard power steering additive works just as well and is a lot easier. Just remove the amount of ps fluid equal to the Lube-Gard and add the LG.
Neighbor has an old Ford beater that you could hear coming from two miles away, winter and summer for years. Added some LG and it went totally quiet in less than a minute and has remained so for a couple of years.
Most Napas carry LG.
Old 01-12-2007, 06:48 PM   #3 (permalink)
Guest
Posts: n/a
Its cold out there.........bumping this to the top
Old 02-08-2007, 04:21 PM   #4 (permalink)
Do you have a link for the lube guard?
broncofreak2000 is offline   Reply With Quote
Old 02-11-2007, 07:34 AM   #5 (permalink)
BSouth's Avatar
I have this problem and its driving me crazy. Guess I'll go get me some lube gaurd.
05 3500 Yellow 6 speed, Mega cab dually fenders, Rumble Bee Scoop, Edge Juice w/ A2, Striker 2, 5" Silverline exhaust, Icebox with torque tube, Rokkteck, Brite Box w/ Fogzilla
BSouth is offline   Reply With Quote
Old 02-11-2007, 12:26 PM   #6 (permalink)
BSouth's Avatar
Just went to the auto parts store and all they had was lubegard transmission additive. Guess I'm gonna order it off line. heres a link Power Steering Fluid Protectant by LUBEGARD (4 oz.)
Old 02-11-2007, 02:00 PM   #7 (permalink)
guroo987's Avatar
i just found the lube guard powerstearing additive at napa today, best 7$ i have spent so far. it works great!!
http://www.cumminsforum.com/images/cf_premium_promo.jpg
99 4x4 2500 longbed extra cab, 24 valve ctd, bhaf with outerwear and heat shield, edge juice with attitude , vulcan big line pump relocate kit with holley blue , mechanical fuel pres guage ,straight piped, automatic overdrive, 2 inch leveler lift, 17x10 ion rims with 315/70-17 bf goodrich at's ,bug shield, nerf bars, and other misc.
guroo987 is offline   Reply With Quote
Old 02-11-2007, 06:08 PM   #8 (permalink)
I checked all the parts stores here in town, found the trans additive but not the power steering. I ordered some from the link above. Thanks
Old 02-17-2007, 05:45 PM   #9 (permalink)
I got my Lube Gard yesterday, now I just need to drain out some old and put it in.
Old 02-20-2007, 01:56 AM   #10 (permalink)
john in montana's Avatar
That lube guard sounds good.I am going to try some.Thanks for the tip illflem
1998.5*24 valve*2500HD*4W.D.* 4 Speed Auto* LB* Q.C.* Two Tone Paint*Trailer Tow *Adj Boost Elbow* 5in.Straight Exhaust* AFS Big Dog Fuel System * Custom Powder Coated Grill Guard with KC lights* 285/75/16* 4 wheel anti-lock brakes*Anti Spin Diff.*109K miles +counting
john in montana is offline   Reply With Quote
Old 03-22-2007, 08:52 PM   #11 (permalink)
Super Duper Moderator & Ontario Chapter VP
Ruckuz's Avatar
i'll be checking this out next winter
power steering sucked this year
1996 2500 4X4 Auto CC LB Banks Power Pack, Boost, Pyro & Oil Temp, 3k GSK, BHAF, #0 Plate Full Forward, Low Stall Triple Disc TC, TST Valve Body, Mystery Switch, Rancho RS9000's, MTX MZS1204'2/Alpine MRD M501, Viper Alarm & Remote Start, Dual 5" Grand Rock Turnouts, Rickson 19.5"s, and lots of stuff to make her look good.
Ruckuz is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
