Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 11-01-2005, 08:34 PM   #1 (permalink)
Guest
Posts: n/a
*Valve adjustment
Tech articles are in the process of being restored, please bear with us during this process
Cummins Forum Staff
Old 11-01-2005, 08:39 PM   #2 (permalink)
dieselgearhead's Avatar
What are some of the common signs of mis-adjusted rockers? Also how often SHOULD this be checked?
05' Crew Cab dually 4X4 cummins w/ 6 spd.
4.11's w/limited slip
EDGE JUICE W/ ATTITUDE, AFE TORQUE TUBE, TURBO SILENCER RING REMOVED, FIA WINTERFRONT/BUGSCREEN COMBO, BULLET STEP BARS, DEEZEE 5TH WHEEL ALUM. TOOL BOX, VENTVISOR WINDOW VENTS, AERO-TURBINE 4040L MUFFLER
05' Jayco Eagle 305BHS 5er
Son's truck 84 Chevy S10 w/ 355 V8 & TH350 trans
dieselgearhead is offline   Reply With Quote
Old 11-03-2005, 07:24 PM   #3 (permalink)
Guest
Posts: n/a
The 24 valvers require adjustment at 100k, If I remember right the 12 valvers need attention every 30K, You can hear the rockers rattlin when adjustment is needed, you dont want to set the valves to tight, set them to spec and if they are so tight that the valves wont completly close you will burn the valves and ruin them. has some excellent info on his website about this. Check it out Here And a big thank you to .
Cheers, Kevin
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
