Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 10-16-2006, 08:07 PM   #61 (permalink)
Sea01Cummer's Avatar
Chris , what filter would you recomend? When i put my BD sticks back in I should be around 470hp ish??? I do alot of street driving with about 20% of the time off road??
Steve
2001.5 Dodge 2500 CTD, 6 Speed, Leather,Headache Rack, Edge HOT Juice with Attitude,BD 130 HP Pulse Injectors, 4 inch Exhaust, FE Clutch,Vulcan Big Line Kit, IIS Super Phat Shaft 62/14, Swanker Intake Manifold,ATS Exhaust Manifold,ARP 12 MM Head Studs, HB High Idle Kit, 12v Marine .020 Headgasket. .
PICTURES
www.industrialinjection.com
Dynoed 505/1085 on 8/26/06 :woot2 with water-meth
Guns don't kill people.... Husbands that come home early kill people....
Don't Forget To Vote For ROTM
Sea01Cummer is offline   Reply With Quote
Old 10-17-2006, 02:53 PM   #62 (permalink)
got...DIESEL?'s Avatar
After using several, I like the AEM dryflows. They're about $40 standalone, or ou can get the brute force intake kit if you like for several hundred more. The filter byt itself will clamp on to your intake hose using a short piece of 4" pipe to make the union. I clamped mine right to the turbo inlet...but i have the room for that where the primary is mounted. If you look at my garage don't let it confuse you. That one is a K&N I had temporarily on there while I was waiting for the AEM. I haven't taken any pictures of that one yet, but it has the right size outlet, unlike the K&N did.
In NW Florida? Get a hold of me...it's time Dodge makes it statement in these parts!!
'95 2500 Std Cab 4X4...
DTT billet trans and billet triple disc, billet flexplate, compound turbos, AEM Dryflow, 160 pump, custom plate, 191's, EDM370's, peaked and tweaked AFC, rack control plug, 20*, 3K, head studs, marine +.020 HG, Water/meth
got...DIESEL? is offline   Reply With Quote
Old 10-19-2006, 05:40 PM   #63 (permalink)
JMP'S PERFORMANCE's Avatar
Swiss Cheesed Airbox
Will some one please post a pic of this? What size holes did you drill? Was it substantial enough to feel the extra power or no? Thanks, Justin
96 Ram 2500 Cummins; #10 TST fuel plate, star wheel adj,17* timing, headstuds, 3k gsk washer, 0.020 Marine Headgasket,O ringed head, 5spd, South Bend clutch.
FARMBOYS DIESEL @ farmboysdiesel.com
JMP'S PERFORMANCE is offline   Reply With Quote
Old 10-19-2006, 06:31 PM   #64 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
Here's a pic of mine - can't say much about power increase, but those holes and the K&N prevented any more pulling down of the filter minder - and got me 327 RWHP and 900+ torque at 2003 May Madness, with only the Comp...
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline   Reply With Quote
Old 10-19-2006, 08:24 PM   #65 (permalink)
bbraden's Avatar
hey guys just put my BHAF in today. I like it so far. Haven't gotten to make any MPG tests yet but it sounds pretty good! Anyways, what did ya'll do about the bolts sticking up through the fenderwell that are gonna poke through my new filter?? I stuck some peices of cardboard on top of them for just long enough to try out the BHAF but it can't stay that way... lol
bbraden is offline   Reply With Quote
Old 10-19-2006, 09:32 PM   #66 (permalink)
Tech Specialist
Cut some short pieces of rubber fuel line or similar hose of a size that will fit the bolts, and use them for anti-wear standoffs...
Old 10-22-2006, 03:06 PM   #67 (permalink)
Guest
Posts: n/a
I did similar to Gary, but used a 1" drill...I also out in about 15 holes (three sides and the bottom)...
I wouldn't say there was any power increase, but it definately improved mileage...I still got to clean my Amsoil TruFlow foam filter so I can reinstall it...
steved
Old 10-23-2006, 07:33 PM   #68 (permalink)
I just got my Blackstone report back. I used the standard media filter for 6000 miles, ended up with 8ppm silicon. The 15 ppm that was analyzed may be from using that filter in an area where the dust was very high. The PG7 is recommended for off road and dusty areas. I used mine as I normally would at any other time of the year. So to all who use the standard media filter AFE, don't be afraid to use it due to one person's results. You have to use it and find out for yourself.
Derek
D-Roc is offline   Reply With Quote
Old 10-23-2006, 08:05 PM   #69 (permalink)
Administrator
Graphic Man's Avatar
i am in need of a better air system....does anyone have flow rates on filters??
i am running a BHAF now and i know it's not enough cfm,
i am looking at the proguard 7 with a t-tube, anyone put a t-tube in and seen any difference?
Scott
2001 4X4 Q-cab Sport black, full billet DTT trans, billet F-plate Mach 7's, B1-B2 twins, Blue Chip Special X VP, Adrenaline, studded & O-ringed, BD-RAD,Flex-A-Lite electric fans, Autometer Gages, Egt, Boost,Fuel, Oil &,drive pressure, trans temp, RASP, Big line kit, Track bars 2" leveling kit, 271 T-case, DSS, 3rd gen trac bar 623 HP 1175tq with old set-up
Graphic Man is offline   Reply With Quote
Old 10-26-2006, 12:13 AM   #70 (permalink)
monsterB's Avatar
Originally Posted by Mopar1973Man View Post
Dude... You really do play in the dust and dirt! Wow! You need to power wash that beast!
thats a fresh coat of high temp not dirt, but your right it does need a blast
i think i have washed her once since ownin' her. it's no beauty queen!
94' 3500, 5sp., straight axle, single cab, dually - Marine Injectors, No Cam Plate, No Filter Or Piping, No Gauges, No Thermastat, 4to5in. Side Shot Exaust, Modified Schwitzer Turbo, Timing Adj., Modified Valve Adj., And A Few Other, TRICKS OF THE TRADE!
monsterB is offline   Reply With Quote
Old 02-17-2007, 06:41 AM   #71 (permalink)
[quote=NEOREGON Bomber;48571]Was running a Fleetguard BHAF (part number AH19037) with an Outerwares prefilter before I recently installed the AEM Dryflow synthetic. Was getting 3-4 PPM for silicon on 8500-9000 oil changes with Schaeffers 15W-40. QUOTE]
"If it ain't broke, don't fix it!"
Also, I was running 15-20ppm Si on my 7500 mi intervals with the Airraid Drop in. It's gone, replaced with Amsoil Ea filter. Anxious now to do a UOA on it and see how it looks.
Black 2004.5 Ram 2500 SWB SLT 4x4 Quad Cab "600" CTD, 48RE, sig doesn't have enough room for all the fun stuff.
Strjock81 is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
