| General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING |
#37 (permalink) | |
Tech Specialist
Switching to a K&N, and drilling the stock airbox for improved airflow volume eliminated that problem completely. Later additional engine mods motivated the move to the BHAF for even more airflow, mixed with better filtration. No regrets to date... ![]() ACTUALLY, I suspect the above 2 examples to be the biggest single reason some owners are impressed with some of the aftermarket air intake/filter setups - they are swapping out a sick STOCK intake setup for a setup with an improved air filter combined with some outside air capabilities, and assume that much of the improvement is because of that "special" air filter and greatly assisted by the fresh air intake. When in fact, the improved filter is quite likely the single greatest improver of performance, and the rest is pretty much useless as far as improved efficiency is concerned. Let's face it, some guys THINK they are feeling "greatly improved performance" when they install fuel line magnets on their vehicles - "Seat-of-Pants" impressions more often than not, are WAYYyyyy off base from tested reality! ![]() Further, the only reliable method *I* can think of to properly test some of these aftermarket intake setups, is with a Dynamometer installed inside a wind tunnel to fully simulate down-the-road conditions of vehicle airflow... And I SERIOUSLY doubt ANY of the makers of the aftermarket stuff have ever done and documented that - at least I have never seen any such documentation. And anything LESS is meaningless
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er. Last edited by Gary - K7GLD : 10-12-2006 at 01:43 PM. |
#38 (permalink) | |
Posts: n/a
I agree...I find the aftermarket funny...you can make numbers say anything...I could easily picture an aftermarket intake maker comparing their new/clean system to a factory system with a completely plugged filter...it is all a marketing strategy. As to the stock box...my first major mod to it was to simply change the element...it took a few runs to pull the filterminder in any after just swapping the filter. I then swiss-cheesed the airbox...to date I haven't moved the filterminder since (but that has been four filters ago too). I don't think it is working...but maybe it is and it's just not pulling in? I talked to one 04 owner right after I bought mine (he hotshoted 5vr RV trailers, met him in OK getting fuel...it was a dark blue 3500DRW)...he told me he had been through 6 or 7 OE revamps of the factory system as he kept sucking the filter into the inlet...I'm not sure why HE would have been the DCX guinea pig, but the system under his hood was FACTORY (had mopar PNs) and looked nothing like the current production 04+ trucks...it was actually a large cone filter (maybe a BHAF?) with a heat shield...it's been several years since that meeting...can't really remember too many details of the system other than it was more like an aftermarket system than a factory airbox. I believe that simply doing the airbox mod netted me some significant mileage gains...I can't remember anymore how much...so far with all my mods I have went from averaging 15-17mpg to averaging 18-23mpg...but I doubt I will ever recoup the cost of the mods in fuel savings... steved |
#39 (permalink) | |
Tech Specialist
The difference between 17 and 23 MPG amounts to 15 gallons of fuel in 1000 miles - and at the $3+ a gallon many of us have been paying for diesel, that's about $45 bucks worth of savings - nothing to sneeze at! We're too used to thinking of fuel costs back at a little over $1 a gallon - and haven't adjusted our thinking to the reality of what fuel is costing TODAY - not to mention what it might be TOMORROW!
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er. |
#40 (permalink) | |
Tech Specialist
03, 4X4, QUAD, LWB, Standard Output, 47RE, 3.73, ATS TC/VB, DTT Trans/Billet, Flex Plate, TorqLoc, RAD, Twins, Snow, Hot Cp3, Injectors, Cam, 315s, 8,200 lbs wet. 12.32 @ 109 Videos: Vid 1 & Vid 2 Add yourself to the Cummins Forum Map. |
#41 (permalink) |
Great Posts!!! Much knowledge. I went to my local Kenworth service shop a couple of hours ago (after my previous post) and bought a Fleetguard BHAF. Now, I'm loggin' on to good 'ol eBay, and buying an AFE Torque Tube.....I'm still going to eventually fabricate a box around the filter, if there's enuff room....
#42 (permalink) |
Well after the first tank after my BHAF, I have a 1 mpg increase, well worth the 20 bucks I have into it.
'05 2500 4X4 610 6Spd Big Horn. Bully Dog Downloader, Silencer Ring MIA, Intake Tube Silencer MIA, BHAF, 6" Tuff Country, straight thru exhaust (Kept kitty), 37' Pro Comps, Nerf Bars, Custom front 3 place light bar, Pop-Up Goose Neck Hitch,
#43 (permalink) |
Just curious here, if I put a ram air on my truck and made it go say from the grill to a cone filter in a straight line and then straight to the front of the turbo, would rain or any water that got past the filter hurt the turbo? I wasn't sure if it would rust or if since the only chance of it sucking water in is when it is running that the turbo would dissipate the water too quickly to make half a crap??
1990 F250 7.3 IDI NA auto 4x4 250k 1997 2500 12V Cummins 5spd 2wd 295k miles #100 plate, SB Con O 26mpg O/D 1850RPM Cruise C.. |
#45 (permalink) | |
Tech Specialist
About how much "ram air effect" (increase in air pressure as measured at the turbo inlet) do you expect to get, and at what road speed? How large a cone do you think it will take to provide that boost - and what size ducting do you think it will take to properly channel the air to the turbo inlet? And finally, what is your HP goal after all this is done? My guess is it will take a cone the size of a barrel, a duct at least 4 inches in diameter, and a road speed of at least 60 MPH to gain about a 2 psi boost and about a 10 HP gain as long as the speed is maintained... I'd sure like to see a picture of the finished project...
#46 (permalink) | |
Posts: n/a
Actually, the OE filter was the large panel filter from DCX...I would hope it was NOT a fleetguard because they had glued the ends of the pleats together so that ALL the air was sucked through the "prefilter" guaze...this "glueing" had reduced the actual opening in the filter down to a 6 inch by 6 inch hole in the middle of the filter...by simply replacing THAT filter with a NapaGold (the closest parts house in Grants, NM), the filterminder didn't pull in as fast... While the air box was restrictive, that filter was more restrictive... steved |
#47 (permalink) | |
Posts: n/a
Hmmm... $550 for the FASS, $80 for the RockTech, $1650 for the DT Kit... That's a grand total of $2280...$2280/$45=50.7...50.7*1000=50,700 miles for payoff...assuming I can keep getting that kind of mileage...That's 1/3 of the mileage that I figured it would take to pay for the DT kit alone... steved |
#48 (permalink) | |
Tech Specialist
![]() Let's face it, MANY of the mods we do MIGHT create some form of operational "savings" - but MOST are probably for the they put on our faces!
