Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 01-08-2008, 01:19 PM   #1 (permalink)
Tech Specialist
Dodge Wheel Interchange
YEAR___TYPE___DIAxW______LUG______CIRCLE____HUB DIA____OFFSET____O\S______NUT
'94-'00__DRW___16"x6"____8@9/16-18 on 6.5"_______4.77"______5.35"____1 13/16"____15/16"
'01-'07__DRW___17"x6"____8@9/16-18 on 6.5"_______4.77"______5.35"____1 13/16"_____7/8"
'94-'02__SRW___16"x6"____8@9/16-18 on 6.5"_______4.77"______
'00-'02__SRW___16x7.5"___8@9/16-18 on 6.5"_______4.77"______
'00-'02__SRW___16"x8"____8@9/16-18 on 6.5"_______4.77"______6.25"____
'03-'07__SRW___17"x7"____8@ on 6.5"_____4.77"______
'03-'07__SRW___17"xX"____8@ on 6.5"_____4.77"______
'03-'07__SRW___18"xX"____8@ on 6.5"_____4.77"______
NOTE: speedometer errors will result when swapping wheels\tires if any difference in overall diameter
Example: 2.35/80x17" tire is over 2" taller than 2.15/85-16" tire - taller = larger circumference
Larger circumference = longer distance travelled per each full rotation = fewer rotations per mile = speedometer error = vehicle will be travelling faster than indicated by speedometer
17" wheels are usually downward compatible - check for 2nd gen body interference with larger wider tire sizes
Example: 3rd gen dually 17" with larger 2.35/80's will fit 2nd gen dually with no interference
2nd gen 16" wheels are not fully upward compatible due to the change from rear drums to dual-caliper rear disc brakes for '01
Late 2nd gen alloy 16" may have slight interference with '94-'00 larger rear drums
2nd gen front brakes were single-caliper to '00, then dual caliper - 16" wheels fit either type
to be continued................
If it's a Diesel thing, I do understand..................
96 Dodge 3500 CC 2wd drw 3.54\6sp 5.9\12v TST#10 SBC13" '05-17"whls Buckstop
DODGE makes it - CUMMINS shakes it; 6 in a row makes it go
gmctd is offline   Reply With Quote
Old 01-14-2008, 08:52 AM   #2 (permalink)
what is drw and srw
'07 Big Horn 6.7 AT,,,,,,,,,,,more to come
271.6 rwhp, 623 rwtq, Bone Stock 3000 mi
GreyMatter is offline   Reply With Quote
Old 01-14-2008, 08:58 AM   #3 (permalink)
Cummins Whisperer
mojo1578's Avatar
I think it's dual rear wheel and single rear wheel...:thumbsup
2k2 QC 4x4 Graphite:Auto, Phat Shaft 62, Icebox, Eliminator, Firestorm 150'sHOT Juice w/ Attitude 518/1008
mojo1578 is offline   Reply With Quote
Old 01-15-2008, 09:35 PM   #4 (permalink)
Super Administrator
BBRam's Avatar
Another fine job gmctd!!!!!! Let me know when your done with this and I will move it into the Tech Articles. :thumbsup
Thank you, BRIAN
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
Old 01-16-2008, 01:15 AM   #5 (permalink)
Tech Specialist
Wilco, roger and out
Old 01-31-2008, 08:25 PM   #6 (permalink)
SC Chapter Co-President
carolinarednek's Avatar
You are correct sir!!
1996 Dually 4x4, 315/75R16 BFG KM2's, auto with Goerend Triple Disc, BD valve body ,torque-lok and pressure lok, banks twin ram, no plate, 4K GSK, Delivery Valves Clocked, No AFC Foot, BHAF, 6" miters
South Carolina Chapter Co-President Carolina Cummins Club
carolinarednek is offline   Reply With Quote
Old 02-15-2008, 10:36 AM   #7 (permalink)
Super Administrator
BBRam's Avatar
Moved to the General Tech Article forum.
