Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 10-22-2007, 02:26 AM   #1 (permalink)
Cummins Fan/ TECH SPECIALIST
LOGAN's Avatar
Compound Twins Explained For Non-Gearheads....
non-intercooled
intercooled
RED is the exhaust.
BLUE is the air.
air enters the atmosphere turbo (the larger of the two) and is fed into the engine mounted turbo (the smaller of the two), then directed into the engine or the intercooler if the truck is intercooled and then into the engine. the technical name for this setup is "compounded turbos", most people just call them twin turbos or just twins, its just easier.....
hope that helps some of the new "non-gearhead" guys with understanding how twins work.
i hope that picture works ok, i drawed it in paint....i didnt make all of it red so people could make sense of it, that is why i used pink for the turbo's and maroon for the exhaust piping, same with the blue.
1990 D250, RC LB, 2WD, 130,000 MILES, 727, NOT ENOUGH ROOM TO FIT MODS
ONE OF THE FEW, THE PROUD, AND THE VE POWERED
LOGAN is offline   Reply With Quote
Old 10-26-2007, 02:24 PM   #2 (permalink)
Super Administrator
BBRam's Avatar
Thank you Logan, another Fine Job. Moved to the General Tech Article forum. :thumbsup
03-3500, DRW, QC, 4x4, R850 BD Twins, BD IC Boots, BD Billet Flexplate, Full Billet DTT Trans, Lockup Switch, SMARTY TNT-R / TS MP-8, Wicked Diesels Eliminator Fuel System & Coolant Bypass, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, Mag-Hytec, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. (R/T .021, 60' 1.76, 1/4 ET 13.03 @ 102.05 mph)
July 2009 Cummins Forum ROTM Winner
95 1500 Sport 2wd Cummins Drag Truck under construction.
"In search of the Magic Dyno"
