Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 09-11-2007, 07:50 AM   #1 (permalink)
Guest
Posts: n/a
FASS fuel filters
I started a long thread on TDR about FASS filters a year or so ago..here is a list I researched...figured someone might find this useful...
Napa (made by Wix?)
FIL1274 - 10 micron @ 50%
FIL1202 - 5 micron @ 50%
Wix (same as Napa?)
51202 - 5 micron @ 50%
51274 - 10 micron @ 50%
Fleetguard (only the good ones)
HF6604 - 5 micron @ 99%, 1 micron @ 95%
HF6607 - 6 micron
Donaldson
P169392 - 1 or 2 micron @ 99% (IIRC)
Baldwin
BT372-10 - 10 micron @ 50%
BT372-MPG - 5 micron @ 50%
BT8509-MPG - 1 to 2 micron @ 98.6%
Cim-Tek
70032 - 10 micron
70213 - 3 micron
The screen is harder, only the FS1023 and maybe a Baldwin BF7760 work. There is a Napa screen (no drain) that is FIL3691.
These should be pretty easy to find for you guys locally...you can also have these crossed at local farm supply stores as I have seen reference to both JD and IH.
I think the HF6604 is about the best you can get at around $60 from Geno's Garage. The Baldwin BT8509 is around $50 from a Baldwin dealer. I carry a Wix 51202 for a roadside spare because they only cost $15 locally. These would be my choices, mainly because they are fairly easy to get...
Another thing that I see often is the question about change frequency...I change mine once a year (approximately 50K miles), probably change less often now that I have a pressure guage. If you have a pressure guage, you can see the onset of a plugged filter.
Also, make sure you frequently drain the water separator, especially in winter...
steved
Old 09-11-2007, 07:55 AM   #2 (permalink)
Super Administrator
BBRam's Avatar
Nice job Steve, Thank you.
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3.5 CP3, F1 Flux 3.8's, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GR 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
