Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 07-13-2007, 06:23 AM   #13 (permalink)
Super Administrator
BBRam's Avatar
Moved to the General Tech Articles forum.
Thank's Dad98.5
03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph)
Old 07-13-2007, 08:42 AM   #14 (permalink)
Dad
Administrator
Dad's Avatar
Originally Posted by 1-TON View Post
Well after reading what you say about the mechanical fuel pressure gauge I am wondering if my 2 inch air bubble is causing mine to read a wrong reading. Mine idles at 8psi and yours was 7psi. I have tried and tried to get that air bubble out but no luck.
If you're getting it to seal, the best way I found to get air bubbles out was to go to the lowest side, which is likely the isolator end, undue the connection. Stick a little syringe in the tube filled with anti-freeze. (You can also use water in your mouth if you have enough anti-freeze in there.)Have a helper on the gauge end loosen the fitting. Then with the syringe, push the fluid up the tube (and the air bubble out.) When the bubbles are gone, have your helper tighten the fitting. The vacuum should hold the fluid in there while you reconnect.
One word of caution: Over tightening compression fittings will result in leaking. Sometimes, even loosening and re-tightening will cause it to begin to leak.
High Rider: 98.5 Ram 2500 4x4, 5 Spd, SB 13", A3000 turbo, DDP Stage 3 sticks, studded, 4" TB,, AEM Intake, Gauges, FASS95, S-Chips Tune
Low Rider: '06 Chevy 1/2 Ton, Victory Red, 2/4 Drop, roll pan, sport mirrors, rollin on 20's
Dad is offline   Reply With Quote
Old 07-21-2007, 06:34 AM   #15 (permalink)
Ontario Chapter President
CumminThru's Avatar
UPDATE: I got myself what I consider to be a "proper" ferrule <sp?> and nut and re-attempted to seal up my guage side air leak, IT NOW WORKS FLAWLESSY.
Never did get to the copper tube experiment either. I'll get pics posted up of both the old (combo nut and ferulle) and new (seperate ferrule and nut) as soon as possible.
I redid the fluid with Dad98.5's suggestion above and it worked out better than me forcing it from the high side (guage) down to the isolater then capping it tight at the isolater!! Vacuum does suck....
Dan - Ontario Cummins Crew President Ontario Chapter
GONE but never forgotten - 2001.5 24V QC SLT Laramie 2wd 47RE/3.55, LB, ICEBOX w/4510, FBD 4" turbo back w 5x18 SS tip, silencer ring MIA, FASS 150, IIS HRVP, DiPricol 30 psi FP guage, 1 qt 2 stroke EVERY tank!! 16.5481 @83.29mph on 7/7/07
My new ride .... for now - 06 JEEP LIBERTY CRD. NO MODS, its a lease...
CumminThru is offline   Reply With Quote
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
