| General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING |
Brake Info - NP
I got this from KLM's forum. I think it was written by a Tech at ART brakes. I found it interesting and thought some here might also. A lot of owners think this "Brake Judder" is the results of "warped rotors" However, Its not. It's a condition where the friction faces are not the same thickness anymore. Now your asking "... how can this happen?" "How on earth could the both friction faces of a brake disc not be parallel, even after many miles?" Good question right? Well, Here's how; There are two basic types of brake pad friction mechanisms: abrasive friction and adherent friction. In general, all pads display a bit of each, with abrasive mechanisms dominating the lower temperature ranges while adherent mechanisms come more into play as pad temperature increases. Both mechanisms allow for friction or the conversion of kinetic energy to thermal energy, which is the function of a brake system, by the breaking of the molecular bonds in vastly different ways. The abrasive mechanism generates friction or energy conversion by the mechanical rubbing of the brake pad material directly on the rotor disc. In a crystalline sense, the weaker of the bonds in the two different materials is broken. This obviously results in mechanical wear of both the pad and the rotor. Consequently, both pads and rotors are replaced when they are physically worn to their limit and are too thin to endure further service. The adherent mechanism is altogether different. In an adherent system, a thin layer of brake pad material actually transfers and sticks (adheres) on to the rotor face. The layer of pad material, once evenly established on the rotor, is what actually rubs on the brake pad. The bonds that are broken, for the conversion of kinetic to thermal energy are formed instantaneously before being broken again. It is this brake pad-on-transferred brake pad material interaction at the molecular level that yields the conversion process. This is the mechanism we what to use in a street applications. The abrasive mechanism is used in racing applications. With the adherent mechanism there is much reduced rotor wear as compared to abrasive mechanism, but it’s not a free pass – pads now become the primary wear element in the braking system. And even though rotors are not mechanically worn down with adherent systems, they still will need to be replaced on a regular basis due to cracking reaching a point of failure if they are exposed to intense, repetitive thermal cycling. This is why race teams throw out rotors that are actually as thick as or thicker than when they were brand new. It’s due to the adherent brake pad transfer layer! Imagine the following scenario. You’re driving your truck a little too aggressively and the light changes on you. Dam! I’ve got to get this thing to stop before I reach the intersection…. You start applying heavy pressure to stop, right? You know what I’m talking about we’ve all been there before… Well you've got the hard part accomplished. Now, what's the first thing owners trend to do or, don't do while waiting on the light? 1) Roll down the window; 2) Change the radio station; 3) Ease up on the brakes and let the rig move slowly so as to avoid the brakes pads from resting in one place on these "hotter the hell rotors" in an effort to prevent pad imprinting. Pad imprinting? Correct. This is where most adherent friction or street brake problems start. What happens is the pad faces can bond to the friction faces of the rotors after this type of stop and when driven off, an uneven deposit of pad martial results. What's worse under braking now when the pad(s) encounter this un-even build-up of pad martial, local temperatures can reach 1200F to 1300F degrees. If this continues, iron which contains inclusions of silicon-iron carbides and high percentages of carbon can develop deposits of "Cementite" (Fe3C) in the rotor's iron matrix. Let’s use a metaphor here and say that the inclusion of silicon iron-carbides and the high content of carbon (30%-40%) in cast-iron is simply a recipe for the development of cementite. All we have to do for its development is locating a heat source and when working with brakes, this will not be a problem... Any guesses as to what the dark spots are? That right, cementite. Cementite is very hard, very brittle and a poor heat-sink. Because of this, the softer iron areas wear at a deferent rate than the harder cementite deposits. It is these deposits that cause peaks and valleys in the rotors friction faces that the brake pad(s) encounter(s) that cause this classic "judder" under breaking that vehicle owners believe is "warped rotors". To combat the onset of cementite in iron takes the knowledge of a controlled stable state of "Martensite" or a "Metastability" of a "Martensitic Transformation" from "Austenite". Austenite is a metallic, non-magnetic solid solution of carbon and iron than exist in metals. Above critical temperatures Austenite's face centered cubic. (FCC) structure allows it to hold a high proportion of carbon in solution. As it cools, this structure either breaks down into a mixture of ferrite and cementite, or undergoes a slight pattern distortion. At ART we employ a process where-by we manage a "Martensitic Transformation". Martensite is a class of tough plate-shaped crystals. These crystals are face-centered tetragonal (FCT) and result from cooling of austenite. The rate of cooling determines the relative proportions of these materials and therefore the mechanical properties of the metal. ART has spend a lot of time in the research of cryo-treating and heat tempering of martensite in iron to induce a martensitic transformations from retained austenite. It is these processes where we believe the durability of our products have such a big following on internet truck forums. What does all this mean to you? Well, depending on the time frame of when you started to experience this "Brake Judder" you may be able to head it off. I would like you to consider the following: 1) You can remove the rotors and check the friction faces for signs of pad imprinting then using "Garnet paper" not sand paper, rough up both surfaces of the rotors. During the re-installation you may want to consider replacing the pads with new pads. It all depends on how much of the pads are still usable. After re-installing re-bed the brake pads again using our bedding procedure. I have enclosed a copy of our bedding procedure herein. Review it closely before heading out to re-bed your brake pads. 2) If the above fails or you just opt for having the rotors refaced, see if you can be present when the shop machines them. Note the tone that the cutter(s) makes during the cut(s). What you're listening for is a consentience sounding cut or does the cutter(s) seem to encounter harder deposits randomly. If so, you will hear this change in the tone of the cut. If you do discern this it is the onset of cementite development and you might want to consider a new set of brake discs. But, on the other hand, you and the shop hear nothing re-install the rotors and then re-bed the pads. You should be good to go.
1999 2500 Quad Cab, 5spd, 4X4, 3.55 LSD, 152K miles, Buckstop w/9K winch, Torque King M/S, K&N FI Perf Kit, 275HP Inj., TST PM3/Smarty stack, PDR boots, Wabro/Areomotive and 1/2" line, PAC Brake w/SWAC, Summit Turbo back 4" pipe, EZ drain, silencer ring MIA, pyro/boost/FP gauges, SBC Con OFE w/HD Adj Hyd, Brite Box, DSS, Centramatics, BFG LT285/75R16/E |
#2 (permalink) |
Listening to Learn
Isn't that interesting. Good reading.
Bobby 2003, 2500 SLT, 5.9L 24V ISB 250 SO, TST PMCR37, SMARTY TNT-NR, Wicked Eliminator LP, A-Pillar Autometer Pyro - Boost - Fuel Pressure Gages, Quadzilla Rail Pressure Gage, 4" Straight w/5" Tip, 4 SPD 48RE Auto Trans w/Goerend Triple Disk & Valve Body, Billit Input Shaft & Flex Plate, 3.73 Ratio 4X4, Crew Cab, LWB, Prodigy Brake Controler ![]() |
#3 (permalink) |
Colorado Chapter Pres
Great article Thanks John
99, QC short bed running the best of the best and proven to perform. A daily driver that gets 19+MPG and runs a 12.86 @ 104 mph 1/4Holland Court Diesel Your one stop Diesel SUPER SHOP 720-542-9104 Give us a call for the best of the best no cheap or budget imitations here just quality brand names with service you can trust all backed by nation wide warranties. Pureflow, Valair, BD power, DDP, HTT, Industrial injection, Dipricol, Quadzilla, S&B, Snow performance, Icebox, Edge, Diamond eye, MBRP, Hamilton cam and more. We install what we sell
#4 (permalink) |
good reading, couldn't locate the re-bedding procedure, would appriciate having it posted too! thanks for the info.
BLACK 02 4*4 SPORT 3500 DUALLY QC, 6 SPEED, LEATHER, SIRRIUS W/GB CUSTOM MOUNT,GB CUSTOM CELL PONE MOUNT,GB CUSTOM CUPHOLDER,BHAF W/ HEATSHIELD,AMSOIL THROUGH OUT INCLUDING BYPASS FILTER W/ GB CUSTOM MOUNT,B&W GOOSE NECK HITCH, FASS2 w/GB CUSTOM MOUNT, AUTOMETER GAUGES,FP,PYRO,BOOST,A PILLAR POD,MBRP S/S 4",EDGE COMP WIRE TAPPED,BOOST ELBOW,BREATHER VENT MOD, JUST STARTING TO SEE THE POSSIBILITIES COMING SOON ?, SB CLUTCH,STICKS, BD EXAUST BRAKE This post reflects my thoughts & opinions .It does not reflect the thoughts or opinions of my horse, my dog ,my truck ,or my computer .All rights reserved .Subject to change without notice .Void where prohibited. No warranties expressed or implied. User assumes all liabilities. Not liable for damages due to misuse. Quality may vary .Keep away from direct sunlight. Other restrictions may apply. Your mileage may vary .If a rash, redness, irritation, or swelling develops, consult your physician "...you sound like one of those people who have been educated well beyond their inteligence. ponder that." - reddman |
#5 (permalink) | |
fill
#6 (permalink) | |
Warning: This next step is CRITICAL to properly “break-in” your new pads and rotors. This is an excerpt from the ART Installation Notes. Pad and Rotor Bedding Procedure for Street Performance Pads After installing rotors and pads on a vehicle, a bedding or bed-in procedure must be performed on the brake system. There are two objectives for bedding-in performance brakes. First, heating up the brake rotors and pads in a recommended manner, so as to promote the transfer of an even or uniform layer of pad material onto the new rotor discs; and the maturing the pad material, so that the resins used to bind and form them during manufacturing are ‘cooked-off’ the pads. The first objective is achieved by performing a series of stops, so that the brake rotor discs and pads are heated steadily to a temperature that promotes the transfer of pad material onto the brake rotor’s friction surfaces. It should be noted here that there is one pitfall in this process, which must be avoided. The rotor and, therefore, the vehicle should not be brought to a complete stop, with the brakes still applied, as this risks the non-uniform transfer of pad material onto the friction surfaces. This uneven transfer is sometimes known as “pad-imprinting”. The second objective is achieved by performing another set of braking events whereby the bonding resins are “cooked-off” relatively slowly to avoid both fade and uneven deposits or thickness variations (TV) onto the rotor discs. The bed-in process is not complete until both sets of stops have been performed. Plan where and when you do this procedure with care and concern for others’ safety and yourself. After the last stop, the system should be allowed to cool to ambient temperature. If you come to a complete stop before the break-in process is completed there is the chance for non-uniform pad material transfer or pad imprinting to take place and the results will be what the whole process is trying to avoid. 1. Perform five partial braking actions, from 55-60mph down to 10mph. Each event should achieve a moderate-to-high deceleration. In terms of stopping force or severity to use depends on the vehicle. If the vehicle is equipped with an ABS system and the stopping forces exceeds approximately 0.9G’s, the ABS system will typically intervene. What you want to accomplish is stopping at a rate below the ABS system triggering or around 0.7G’s and these events should be made one after the other, without allowing the brakes to cool other than under normal acceleration in between each stop. Remember, this is not a race so, take your time. Depending on the composition of the pad material, the brake friction will seem to gain slightly in performance, and will then lose or fade somewhat by around the fifth stop. You may begin to smell the pads at around the 4th to 5th stop. This odor is green fade, and is characteristic of immature or ‘green’ pads, in which the resins still need to be “cooked-off” the pad material. This odor should diminish before the last stop. These first sets of stops, in the bed-in process, are only complete when all stops have been performed - not before. 2. After the first bed-in procedure, allow the brakes to cool by driving the vehicle at a safe speed for the conditions, without bringing the vehicle to a complete stop. After cooling, a second set of partial braking events should be performed, followed by another cooling exercise. In some situations, a third set is beneficial, but two are normally sufficient. Again, these final sets of braking events are used to mature the pads. Close inspection of properly bedded pads will show an area about 1/8" deep of a powdery gray area becoming visible on the edges of the pad’s friction face. This is where the paint and resins are cooking-off. Depending on the pad compound, easy use of the brakes for an extended period of time may also lead to the removal of the bedded transfer layers on the discs by the ordinary abrasive action of the pads. Exercising the brake systems with a partial re-bedding will prevent uneven pick-up when a vehicle has seen easy braking use for a while. After the “break-in” is complete, you should verify that the wheel lug nuts are still torqued to 90 ft. lbs.
