Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 11-15-2005, 09:35 PM   #1 (permalink)
Guest
Posts: n/a
*Acronym definitions
Tech articles are in the process of being restored, please bear with us during this process
Cummins Forum Staff
Old 11-15-2005, 09:53 PM   #2 (permalink)
Guest
Posts: n/a
VP44 = the name of the injection pump on a 24V cummins years 1998.5 - 2002 Has the tendousy of failure due to neglect of not having a fuel pressure gauge to notice the problematic Lift Pump failing
A 24V Cummins with out a fuel Pressure gauge = Ticking Time Bomb !!!
DM
Old 11-17-2005, 09:19 PM   #3 (permalink)
Guest
Posts: n/a
B.H.A.F. Big Honkin Air Filter. an after market filter known to allow massive air flows, cheap and easy to do.
Old 11-18-2005, 04:52 PM   #4 (permalink)
Guest
Posts: n/a
WASTEGATE = A valve used to bypass exhaust around the turbine section of a turbocharger to control the speed of the turbine shaft to prevent excess boost pressure. This allows the turbocharger to speed up quicker to achieve maximum boost pressure without exceeding the safe maximum.
Old 11-18-2005, 04:55 PM   #5 (permalink)
2001shrtbedcummins
Posts: n/a
47RE: Automatic transmission put in from 94-2002. This transmission has many problems including valve body, torque converter, and cooling problems.
48RE: Four speed automatic transmission put in from 2003-to now. Not a half bad transmission. Seems that DCX fixed it. Still only has four gears while ford has five and chebby has six
Old 11-18-2005, 07:16 PM   #6 (permalink)
Guest
Posts: n/a
ETH DEE, Chrysler code on build sheet
ETH- high output motor
DEE- 6 speed manual tranny
Old 11-18-2005, 07:22 PM   #7 (permalink)
Guest
Posts: n/a
TURBINE - That portion of a turbocharger where engine exhaust spins a set of blades to turn a shaft that drives the turbo compressor.
COMPRESSOR WHEEL - The impeller wheel in a turbocharger that spins to compress air, creating boost pressure.
Old 11-18-2005, 07:26 PM   #8 (permalink)
Guest
Posts: n/a
Good en DM, I might add that the exhaust pinwheel and the charger pinwheel are connected thru a common shaft..............ofcourse everybody knows that
Old 11-18-2005, 07:34 PM   #9 (permalink)
2001shrtbedcummins
Posts: n/a
We're missing one of the most common ones...egt. Egt stands for exhaust gas temperature. That is exactly what it says it is. It's the temperature of the exhaust gasses going into the turbo charger. You can mount a probe in the exhaust manifold and moniter it with gauges in the cab.
Old 11-18-2005, 07:37 PM   #10 (permalink)
2fishornot2fish's Avatar
NV4500- 5 speed manual transmission found in Dodge ram trucks 1994 and newer
NV5600- 6 speed manual transmisson. Came out in 1998. In 2001 and newer the (H.O) High Output diesel was available only with the NV5600
01.5, 6 speed manual, 3/4 ton, Linex, 4" Rip Rock 4", tinted windows, Isspro:EGT, Boost, Fuel gauge, AFE Stage I, 3:55 gears, SMARTY
2fishornot2fish is offline   Reply With Quote
Old 11-19-2005, 08:29 AM   #11 (permalink)
Guest
Posts: n/a
CaTCHer! (Clutch and Traction CHallenger)
The CaTCHer is an OEM Dodge/Cummins Engine Control Module (ECM) with custom software that takes control of the engine fueling away from the engine computer and returns it to the driver. It IS the ECM, it is not an add on box that plays "smoke and mirrors" with your fuel injection pump.
The CaTCHer is year and model specific. Each CaTCHer is custom programmed to your requirements.
Old 11-19-2005, 08:55 AM   #12 (permalink)
Guest
Posts: n/a
Sticks- Terminology used for injectors, other terms used are
Sticks
nozzles
showerheads
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
