| General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING |
#37 (permalink) |
has anyone put KDP Killer dowel pin Chris
1998 2500 12 Valve QC Goerend trans, long bed 4x4 Red 115k Boost, EGT and Trans gauge, #100 Plate, 4" exhaust, BHAF, 4K GSK, 60lb valve springs, 16* timing, 3rd Gen wheels with 305/70/17s yeah they rub a little. 97 2500 with some stuff SOLD 98.5 3500 sold |
#38 (permalink) | |
Posts: n/a
Killer Dowel Pin In the back of the timing gear case, there is an assembly alignment pin pressed into a hole. The pin is there to align the timing case to the block. Some holes do not fit tightly around the pin and the pin can vibrate out of the hole and fall into the gear train. The pin is then rattled around by the timing gears until it either falls into the oil pan, gets kicked out through the side of the timing case, or passes through gear train bending the camshaft and ruining the gears and case. This pertains to the 94-98.5 engines. There are some reports of this occuring on some of the early ISB engines |
