Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 11-21-2005, 09:01 PM   #25 (permalink)
Guest
Posts: n/a
ASD -Auto Shut Down: relay control system used to shut down engine
Old 11-21-2005, 09:06 PM   #26 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
LSD - Limited-slip Differential
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline   Reply With Quote
Old 11-21-2005, 09:07 PM   #27 (permalink)
Tech Specialist
GVWR - Gross Vehicle Weight Rating - maximum weight of truck plus load.
Old 11-21-2005, 09:12 PM   #28 (permalink)
Guest
Posts: n/a
AFC Air Fuel Control: used on 94 - 98 diesels to control fuel rate at low boost
Old 11-21-2005, 09:14 PM   #29 (permalink)
Guest
Posts: n/a
BDC Bottom dead center - the lowest position of a piston in the cylinder occurs when the crank pin is at bottom dead center
Old 11-21-2005, 09:40 PM   #30 (permalink)
Super Moderator
WOT- Wide Open Throttle
CHMSL- Center High Mounted Stop Light: 3rd brake light at top of truck cab
ECM- Engine Control Module pre 24 valve do not have a ECM but rather a PCM- Powertrain Control Module, 24 valves also have a PCM
CPS- Crank Position Sensor
VSS - Vehicle Speed Sensor
ESS - Engine Speed Sensor
Old 11-21-2005, 09:44 PM   #31 (permalink)
Guest
Posts: n/a
ANEROID - A device which limits the smoke of a diesel engine during acceleration by temporarily limiting the amount of fuel injected into the engine cylinders during speed and/or load transients below the steady-state limit.
Old 11-22-2005, 08:34 PM   #32 (permalink)
Guest
Posts: n/a
TDC -Top Dead Center: the highest position of a piston in the cylinder occurs when the crank pin is at top dead center
Old 11-22-2005, 08:54 PM   #33 (permalink)
Super Moderator
If you want a ton of automotive acronyms try this
http://www.aa1car.com/library/acronyms.htm
Old 11-25-2005, 10:23 AM   #34 (permalink)
Free spirit
R-N-R's Avatar
Ecd
Bombaholics acronym: ECD - Excessive Compulsive Disorder
'02 2500, 2WD, 4.10, QC LB Cap, Bilstein, Gauges
DTT, AFE, PDR Boots ARP, B1-2, MagnaFlow, GRAND ROCK, Drag Comp, Regulated Fuel Delivery, IIS HRVP, M4.5, HTT
28' 6500# Sunline TT, Hensley, Prodigy
R-N-R is offline   Reply With Quote
Old 11-25-2005, 10:26 AM   #35 (permalink)
Guest
Posts: n/a
LMAO- Laugh My A$$ off
IMHO-In My Honest Oppinion
ROTFLMAO- Roll On The Floor Laugh My A$$ Off
Old 11-25-2005, 10:30 AM   #36 (permalink)
Guest
Posts: n/a
Here's some more :
http://www.dodgedieseldatabase.com/terms.htm
DM
