Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 11-19-2005, 08:45 PM   #13 (permalink)
Guest
Posts: n/a
ISB-Interact System B,The ISB is a 24 valve engine (4 per cyl), the earlier engines were 12 valve.
Old 11-19-2005, 08:47 PM   #14 (permalink)
Guest
Posts: n/a
We are forgetting a good on
WOT-Wide Open Throttle
Old 11-20-2005, 05:07 PM   #15 (permalink)
Wyoming Chapter President
PCMCIA - People Can't Memorize Computer Industry Acronyms.
(one for us geeks)
'98 12 valve QC SB 5 speed Laramie SLT 4x4. PDR 11 plate, 3k GSK, 4" Pac Brake, SBC, II Phat Shaft 62/80, Rip's 4" exh.
TPCDrafting is offline   Reply With Quote
Old 11-20-2005, 05:08 PM   #16 (permalink)
GSK - Governor Spring Kit
If you have a 12 valve, you need one of these. :p
Old 11-20-2005, 05:17 PM   #17 (permalink)
Guest
Posts: n/a
SUPPLY PUMP / Lift Pump / LP - A pump for transferring the fuel from the tank and delivering it to the injection pump.
DM
Old 11-20-2005, 05:47 PM   #18 (permalink)
Guest
Posts: n/a
ABS- Anti-lock Brake System: Modulates braking pressure to control wheel lockup
Old 11-20-2005, 05:50 PM   #19 (permalink)
2001shrtbedcummins
Posts: n/a
Tps-throttle position sensor.
Old 11-20-2005, 05:55 PM   #20 (permalink)
Guest
Posts: n/a
On older models yes, the newer models it is called APPS (Accelerator Pedal Position Sensor) cant tell ya the years on this though
In the end same thing
Old 11-20-2005, 05:57 PM   #21 (permalink)
Guest
Posts: n/a
12V has TPS
24V has Apps
DM
Old 11-20-2005, 05:59 PM   #22 (permalink)
Guest
Posts: n/a
Only 12V cummins apply .....
DELIVERY VALVE ASSEMBLY
- A valve installed in a pump, interposed between the pumping chamber and outlet, to control residual line pressures and which may or may not have an unloading or retraction function.
DELIVERY VALVE HOLDER - A device which retains the delivery valve assembly within the pump.
Old 11-21-2005, 06:36 PM   #23 (permalink)
Guest
Posts: n/a
5.9L - (Five Point Nine Liter) Cummins 6-cylinder turbocharged diesel engine available as an option on Dodge Pickups, 1988 and up. Also known as the 6-BT engine in the Cummins engine family.
Old 11-21-2005, 06:43 PM   #24 (permalink)
Moderator
47RE: Automatic transmission put in from 94-2002. This transmission has many problems including valve body, torque converter, and cooling problems.
48RE: Four speed automatic transmission put in from 2003-to now. Not a half bad transmission. Seems that DCX fixed it. Still only has four gears while ford has five and chebby has six
Not quite
The 47RE (electronic) was used from '97 to '02
47RH (hydraulic) was used from '94-'96
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
