| General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING |
Tech Specialist
One of the best - and FIRST - to be learned when you have a question about your truck, is RTFM - which roughly translates "Read The F****** Manual"! The vehicle makers DO manage to get a lot of info in those manuals - and YOUR question MIGHT just have the answer as close as your glovebox! BUT, for the REST, here's a copy from another source that pretty well covers most abreviations you will find on boards like this one... ===== From DodgeRam.org: 2WD Two Wheel Drive 4WD Four Wheel Drive ABS Anti-lock Brake System: Modulates braking pressure to control wheel lockup ACM Airbag Controller Module: monitors sensors and deploys airbag(s) in the event of an accident AFC Air Fuel Control: used on 94 - 98 diesels to control fuel rate at low boost APPS Accelerator Pedal Position Sensor: used on ISB diesel for electronic throttle control ASD Auto Shut Down: relay control system used to shut down engine BDC Bottom dead center - the lowest position of a piston in the cylinder occurs when the crank pin is at bottom dead center BE model designation for the Quad Cab Ram pickup BFSC Brake Specific Fuel Consumption - pounds of diesel fuel consumed to produce 1 HP for 1 hour BHAF Big Honkin' Air Filter - oversized filter used by the diesel gang BR model designation for standard cab Ram pickup (and maybe the CC Pickup) more below CAB Controller Anti-lock Brake: CARB California Air Rescouces Board: environmental regulatory agency in CA CCD Chrysler Collision Detection: data bus system used by the airbag and the anti-lock brake systems CHMSL Center High Mounted Stop Light: 3rd brake light at top of truck cab CKP Crank Position Sensor: detects position and speed of engine crankshaft CMP Camshaft position sensor: detects position of camshaft CP3 Common Rail Injection Pump, 03 and up CPL Control Part List: listing of engine parts and timing specifications for a Cummins engine (Ram CPL numbers) CTD Cummins turbo diesel - used by many on mail lists and message boards CTM Central Timer Module: controls RKE, chime, courtesy lamps, Speed sensitive Intermittent wipers, enhanced accident response, VTSS DAB Driver Air Bag module: airbag and firing system mounted in the steering wheel center DC DC or D/C = DaimlerChrysler - used on mail lists and message boards DD1 DD1, DD2, DD3 = Diesel Dynamics Stage 1 (2 or 3) injectors DEE Order code for the NV5600 6 speed manual transmission DLC Data Link Connector: used to interface diagnostic equipment with vehicle electronics DRB scan tool used to obtain diagnostic trouble codes (DTC) from controller modules DRB III new generation scan tool used to obtain diagnostic trouble codes (DTC) DRW Dual Rear Wheel DTC Diagnostic Trouble Code: Fault code set by control module when sensor data is not as expected DTT Diesel Transmission Technologies - aftermarket auto trans upgrade specialist EBC 2 RWAL brake system EBC 325 four wheel anti-lock brake system ECM Engine Control Module: microprocessor based module that controls various engine functions ECT Engine Coolant Temperature Sensor EEPROM Electrically Erasable Programmable Read Only Memory: controller reprogrammable memory EGR Exhaust Gas Recirculation: used to reduce combustion temperature and pressure to control Oxides of Nitrogen emissions EGT Exhaust Gas Temperature: Important measurement for hard working diesel engines EMCC Electronically Modulated Converter Clutch: used for torque converter lockup control in the automatic transmission ETC Order code for diesel engine ETH 2001 Order code for the High Output diesel engine ETH/DEE Slang for the 2001 HO diesel with the NV5600 six speed EVA Electronic Vibration Analyzer - used to diagnose chassis, engine, and drivetrain vibrations EVR Electronic Voltage Regulator: circuitry in the PCM which controls battery charging and alternator functions FASS Aftermarket Fuel Pump FCA Fuel Control Accuator: 03+ Common Rail engines FP Fuel Pressure FPCM Fuel injection Pump Control Module: controls injection pump on 98+ diesel engines GAWR Gross Axle Weight Rating: maximum safe load capacity of an axle measured at the ground. GCW Gross Combined Weight: total weight of equipped truck, payload, trailer, water, and equipment. GCWR Gross Combined Weight Rating: maximum allowable GCW GVW Gross Vehicle Weight: total curb weight of the truck and payload. GVWR Gross Vehicle Weight Rating: maximum allowable GVW HCU Hydraulic Control Unit: modulates the brake pressure for ABS HX35 Holset turbocharger used for most 94+ diesel Rams. HX40 Holset turbocharger intended for C engines, but used by some performance enthusiasts on the Ram's B engine HY35 Holset turbocharger used on 2000+ diesel Rams with the automatic transmission IAT Intake Air Temperature Sensor IAC Idle Air Control valve: used for emissions control on gasoline engines IP Instrument Panel ISB Interact System B: Cummins designation for the 24 Valve "B" series diesel introduced to the 1998 Ram JTEC Jeep, Truck Engine Control: Combined engine and transmission control module K&N Aftermarket filter and intake system manufacturer KDP Killer dowel pin inside the timing gear case on 94-98 12 valve diesels. If this pin falls out of its blind hole, the repair is expensive. The two preventative repairs are the Washer Tab and Drill Jig/Bolt LDP Leak Detection Pump: used in the 4 wheel ABS valve assembly LED Light Emitting Diode: semiconductor lamp used for displays and warning lamps LP Lift Pump LSD limited slip differential LWB long wheelbase (or LB, for long box or long bed) MAP Maximum Absolute Pressure sensor: used for emission control MDS(2) Mopar Diagnostic System: diagnostic computer system for service departments MIC Mechanical Instrument Cluster: Instrument cluster controller and display system MIL Malfunction Indicator Light: used by engine control system to indicate a problem to the driver MTV Manifold Tuning Valve: used to vary the manifold runners for engine performance and emission control O2S Oxygen Sensor: measures oxygen content of exhaust stream. Used to modify air to fuel ratio for emission control OBD On Board Diagnostics: Ram engine and powertrain self diagnostic system OBD II On Board Diagnostics II: enhanced diagnostic system to meet 1997 EPA requirements P7100 Fuel injection pump used with 1994 - 1998 Ram 12 valve diesel engines PAB Passenger Air Bag module: airbag and firing mechanism on the passenger side PADS Passenger Airbag Disarm Switch: Override switch to disable PAB when children are riding in front seat PCI Programmable Communications Interface PCM Powertrain Control Module: microprocessor based module that controls engine and drivetrain functions PCV Positive Crankcase Ventilation: vacuum system used to control crankcase (blowby) emissions PDC Power Distribution Center: Fuse and relay power distribution center located under the hood. PEP Peripheral Expansion Port psi Pounds per Square Inch: pressure measurement RAM Random Access Memory: read and write memory used by controllers for data storage RKE Remote Keyless Entry: remote operated door lock system RPM Revolutions Per Minute: the speed of a turning shaft or rotor ROM Read Only Memory: controller "hard" memory that is permanently written - EEPROM may be reprogrammed with appropriate diagnostic tools RWAL Rear Wheel Anti Lock brakes: SBEC Single Board Engine Controller SCI Serial Communications Interface: Used by the PCM for diagnostics and for communication with other controller modules SCTM Seatbelt Timer Control Module: inertia latching seatbelt controller built into Quad Cab Models SKIM Sentry Key Imobilizer Module: disables engine start until Secret Key is entered using DRB scan tool !!! Required when a new PCM is installed in a vehicle SRW Single Rear Wheel SWB (or SB, for short box or short bed) TCC Torque Converter Clutch TCM Transmission Control Module: May not be used on Ram trucks TDC Top Dead Center: the highest position of a piston in the cylinder occurs when the crank pin is at top dead center TDR Turbo Diesel Register - club for Ram diesel owners - with a website, magazine, and rallys TPS Throttle Position Sensor TRS Transmission Range Sensor TSB Technical Service Bulletin: repair and technical information bulletins to assist service departments TST Diesel engine power enhancement company run by Mark Chapple VB Valve body - auto trans VE Bosch Distributor type injection pump used on 89-93 Ram diesel engines VP44 Bosch electronic fuel injection pump used on 1998+ Ram diesel engines VIN Vehicle Identification Number: unique serial number assigned to each vehicle VSS Vehicle Speed Sensor/Signal VTSS Vehicle Theft Security System: anti theft system with engine disable, alarm, and door lock features WIF Water In Fuel sensor: detection system for water in fuel filter on 1994+ diesel engines WOT Wide Open Throttle: maximum throttle position
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er. Last edited by BBRam : 09-15-2008 at 12:01 PM. Reason: Addition's |
