Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 01-16-2009, 08:30 PM   #13 (permalink)
I was looking into this and the body shops are telling me that there is too much silicone in the plastic for the paint to stay on (for a long time anyways). Thought on this?
2008 SILVER QC SPORT W/SPORT KIT & SRT HOOD, 6.7L 68RFE Volant w/ scoop, Edge w/Att, MP-8, DPF & EGR DELETES, 3.5" intercooler tube, 5" Polished SS Magnaflow dual muffler w/Areoturbine 5050XL. 20" V-Drives, 6000K HID's, Katskins, Alpine W505
bumbo is offline   Reply With Quote
Old 01-16-2009, 08:32 PM   #14 (permalink)
Oh, by the way, RedRum, it makes your truck look even more awesome!
Old 01-16-2009, 08:41 PM   #15 (permalink)
jetfuel394's Avatar
if u use the adhesion promoter and etch primer like he did it will b fine. the body shops dont like 2 do b cause if it does chip u will want it fixed. they dont want 2 doit 4 free. the way he did it it will maybe outlast the factory finish! BTW very nice looking job!!!
04.5 2500 Q/C edge hot juice w/att. 100hp sticks rips billet trans,a/d150,stg1cp3 s/ 64turbo w/5"t/back straight pipe,afe cai,8" lift,37 coopers on helo wheels,traction bars,s/s st.support,nav/vid w/surround. thx to rip at source diesel.
jetfuel394 is offline   Reply With Quote
Old 01-16-2009, 08:46 PM   #16 (permalink)
Black Smoke Addict
RedRum's Avatar
Time will tell how it lasts, but the guy I bought my supplies from said there shouldn't be a problem as long as I scuffed the plastic and put a good coat of adhesion promotor down. Not to toot my own horn, but it came out really well....better than I thought it woud. I am not worried about chipping/flaking any more than I am on the rest of the factory finished paint.
I think that the reason the body shop doesn't want to do it is because, as jetfuel said, they don't want to warrenty it.
2007 3500 QCLB, 5.9, ISSPRO, AFE Stage 2, AF1 intake horn, Smarty, SB 3600#, Straight Piped with 6" Mitres, 6" lift, Bilstein 5100s/dual steering stabs., trac bars 37" BFG M/Ts, CUMMINS FORUM STICKER!May 2009 ROTM-Thanks to James @ RSD for stepping up!
2006 3500 QC Bighorn, 6 speed, No silencer ring, B&W turnover, other than that, stock
"I Caught that diesel thing, now it stings when I pee"
RedRum is offline   Reply With Quote
Old 01-16-2009, 09:14 PM   #17 (permalink)
You can keep the change.
bkjeffrey's Avatar
Adhesion promoter for plastics. Etching for bare metals.
Look, as long as you give it a good sanding and a really good cleaning automotive paints will stick! I would wash with a scrub brush and Dawn OXY dish soap. Then you MUST RINSE RINSE RINSE! HOT HOT water. Once dry, do not handle with bare hands. You must use a powder free latex or nitrile glove. Do not set the parts down on anything other than clean work surfaces. Hang them and then you should give a good through cleaning with Acetone and a new sponge while hanging. Once that is dry you can do the next step which I recommend from experience. Heat gun the entire part. Get it warm enough to open up the pores of the plastic and singe any lint or sponge flakes that you may not be able to see. DO NOT get the plastic hot enough to become shiney or smooth looking. Then liberally pour acetone over the pieces to rinse them again. Wait for them to dry, about an hour, acetone evaps really fast.
Now, using a hair dryer to preheat the part to warm to the touch you can begin applying your adhesion promoter. Just a light misting that gives full even coverage is all that is needed. Do not go over board here.
Follow directions on product for dry time, Then apply paint.
Paint should be about two to three coats. Go with your paint manufacturers directions from here on out.
Do this and I assure you that your paint will last as long as the paint on your rig! Remember that paint is just that. It will scratch and fade over time depending on how you take care of it. Good luck!
04-4x4-BD billet flexplate-billet triple disc converter-billet tranny-Edge Poop W/ a sense of humor-Arson CP3-BD lift Pump-Stainless big lines-AFE Pro dry-4" TB stainless steel exhaust-7" stack-Propane Injection-NOS-Made by me air horn-GDP grid delete-City Diesel intercooler-FS2500-mystery switch-5 gal. ViAir on-board air system-Optima blue tops-
WE ARE BEHIND ENEMY LINES!
bkjeffrey is offline   Reply With Quote
Old 01-16-2009, 10:54 PM   #18 (permalink)
Thanks guys. I'm going to go ahead with this as I am doing some fender flares and interior pieces. Might as well do it all at once.
RedRum & bkjeffrey, thank so much for all your help.
Old 01-16-2009, 11:30 PM   #19 (permalink)
Black Smoke Addict
RedRum's Avatar
You bet!, thats what this forum is all about
