Go Back   Dodge Cummins Diesel Forum > Technical Articles - Writeups - Guides Section > General Tech Articles
General Tech Articles Common Technical articles/writeups pretaining to all vintages of our beloved Dodge/Cummins trucks...NO ADVERTISING
Old 01-31-2007, 06:07 PM   #25 (permalink)
Supporting Vendor
Duluth Diesel's Avatar
Looks like you and I have come to an easy agreement after all these debates, eh Gary? LOL
Proud Cummins Forum Sponsor since 2006
Specializing in AMSOIL everything
Change your thinking, not your oil.
Duluth Diesel is offline   Reply With Quote
Old 01-31-2007, 07:41 PM   #26 (permalink)
Tech Specialist
Gary - K7GLD's Avatar
AHhh - never WAS a disagreement - I still figure the TP filters like mine are superior, but for guys wanting something easier and faster to service, the Amsoil ones are fine. Main thing is, for guys planning on long-term ownership and high miles on their Cummins, a decent bypass filter is a BIG plus!
(But my FRANTZ is STILL best!)
White '02 Quad cab, NV5600, GAUGES! Comp, Walbro, DTT SS intake, Rip's 4 in. exhaust, Don M's 1.6's, DSS, Frantz oil bypass & fuel filters, Amsoil air filter, MOBILE Ham Radio-IC-706, 600 watt amp, '88 Kit 24 ft. 5er, 418 HP/978 Tq., 24 ft KIT 5er.
Gary - K7GLD is offline   Reply With Quote
Old 04-05-2007, 01:15 PM   #27 (permalink)
Tech Specialist
I did a cut and paste on much of the pics and text in this thread, bringing it over from the TDR where it was originally posted by me. That was a much longer thread, and one issue covered there, but not here, was the oil return I use thru the oil fill cap:
I modded mine with a short length of added copper tubing to extend drain-back deeper into the valve chamber - and also to make the swivel fitting easier to install into the Stant cap.
The Amsoil swivel seen is part # is BP-89 - and Wayne Owen (Amsoilman) can fix you up with one if you don't have another source - I switched over to the same STANT #11111 oil fill cap he uses with that swivel fitting because it wouldn't fit properly to the stock one on the Cummins - the Stant works great, and is available at many auto parts stores.
Some have tried to drill/modify the stock filler cap for oil return, but sometimes that causes leakage due to internal structure of the OEM cap - so use of the solid Stant works much better - and safer! :thumbsup
Old 01-19-2008, 05:21 PM   #28 (permalink)
Tech Specialist
I was exchanging email with Deb at wefilterit.com, and she mentioned a special she has going on now for the Frantz setups - just in case anyone is interested.
