Old 11-16-2008, 03:57 AM   #1 (permalink)
headgasket
help me out here guys,based on my sig should i be worried about my headgasket??? someone on here said that with my mods if i dont take serious precautions to minimize airflow and drive pressure it will let go.What does that mean??especially the drive pressure??how do you know that it is high,and why minimize airflow dont you want more air??probably stupid questions but i am lost.All the help i can get would be great
1998.5 dodge ram 4x4 qc,lb,edge juice w/att hot,coaltrain 200's,headstuds,airdog 150,S&B air filter,ats arc flow,aurora 3000 turbo,4" exhaust,pacbrake,coolingmist water/meth injection,ATS trans w/ 5 star converter,manual lock-up switch
rayster is offline   Reply With Quote
Old 11-16-2008, 04:06 AM   #2 (permalink)
liberty's Avatar
usually guys will run stock headgaskets to 45-50 lbs of boost. u have an edgse w/attitude. look at ur boost gauge when u floor it. if it is only around 30lbs of boost then no prob, but any higher than 45 u should probably think about getting some head studs installed just to be safe,
2007 dodge 5.9 6" lift, 22" mazzi hulk's 37" kumho road ventures. smarty. afe intake, power puck, 8" stacks, sterling grille. 450 hp, 908ft lbs. 14.9 1/4 mile
liberty is offline   Reply With Quote
Old 11-16-2008, 04:11 AM   #3 (permalink)
ya,i dunno i heard that the edge only reads to 42 or 44 psi. And i see 44 psi on the edge all of the time,it has been like that for over a year now,so i dont know what i really have.Can you put in headstuds without pulling the head off??and what is the deal,do the stock studs stretch??and what is drive pressure and how do you know if it is high??
Old 11-16-2008, 04:24 AM   #4 (permalink)
liberty's Avatar
if its been like that for a year now i wouldnt worry much about it, and yes i believe u can do head studs without pulling the head, doing em one by one. but i have never done em. and im not exactly sure what drive pressure is, mabye someone will chime in
Old 11-16-2008, 04:43 AM   #5 (permalink)
ya,but the reason im aking is i havnt put the 200hp sticks in that my sig shows,ive been running 100hp sticks.im going to put the 200's in next weekend,do you know if my boost will increase even more with the bigger sticks or will it stay the same???
Old 11-16-2008, 04:58 AM   #6 (permalink)
anyone????????
Old 11-16-2008, 05:03 AM   #7 (permalink)
Blue01Cummins's Avatar
it you put to much fuel it will put out the fire
2001 Dodge Ram 2500, 6 speed, Gauges pyro and boost, Holley Blue, K&N, 4" downpipe to a single 5" stack, Edge comp, and a little juice for fun.
http://www.myspace.com/trperformance
Blue01Cummins is offline   Reply With Quote
Old 11-16-2008, 05:07 AM   #8 (permalink)
What do you mean??do you think that i will have too much fuel and therefore lose power???
Old 11-16-2008, 05:10 AM   #9 (permalink)
you could lose power but i guess you will be ok with the 3000
heres the drive pressure hopefully this helps Drive pressure
Old 11-16-2008, 05:10 AM   #10 (permalink)
i would get a bigger pump than that holley blue
Old 11-16-2008, 05:15 AM   #11 (permalink)
Super Moderator
dieseltracks's Avatar
More fuel=More boost.
You're probably goin to be pushin it when you put in the 200's on a stock headgasket and head bolts. You won't "put out the fire", it'll just smoke like a b!tch.
I don't know the specs on ur A3000, so it may not.
Drive pressure is the pressure created in the exhuast housing part of the turbo. If your exhaust housing is to small then it creates a restriction in the outflowing exhaust pressure coming from the cylinders. If the flow is restricted to much then it will "back up" into to the cylinders and cause excessive pressures in the cylinders, which could cause a headgasket to blow.
Dave
02 2500 QC Longbed 4x4--Goerend Triple Disk TC/VB/Flexplate/Billet input--VA/TST PM3--FTE 100hp injectors--BD 3-pc ported manifold--HX35--95gph HPFP--4" exhaust with a 7" blowhole
BE SURE TO CHECK OUT OUR CF SITE SPONSORS FOR ALL YOUR PARTS NEEDS!!
dieseltracks is offline   Reply With Quote
Old 11-16-2008, 05:48 AM   #12 (permalink)
im not sure on the specs but it flows 10ppm more than a super b and 4 ppm less than a super b special,dont know where that puts me as far as smoke output,i dont care a whole lot for massive amounts of smoke.
