i was wondering in details how i can flush all the old coolant out of my system so i can put in all new stuff? do i need a flushing kit? use garden hose? and also how much coolant does the system hold? and would cat elc premixed coolant be ok to use?
2005 Dodge Ram 3500 SRW 4x4 -2" leveling, 35 Nitto trail grapplers, Heavy Hauler trans, BHAF, Smarty TNT, FBD 5", ADII, Arson III, Flux 2 injectors, BD Killer B
to flush it undo your top rad hose and keep a water hose filling your rad let it run til it comes out clear turn off water let it pump remaining water out and top it off with premix or mix it yourself to your likings.
08 3500 QC 4x4 6.7 6spd, 5" exhaust into 5" aussies, afe m/c, MP-8, Smarty S67, A/D 150, AM phantom's, 120 nozzles, PPE twin kit and Floor It STGIII CP3's, 3850 DD, new I/C, Twinned with S480THANKS TO WALLY, NICK AND DAN!!
so when i shut the hose off will it keep pumping out all the water that is in the system or will there still be some in there? if not how do i get it all out? arnt you suppose to mix the antifreeze with distilled water? if so then what is left in the system is not distilled. and should i buy premixed coolant or stuff i got to mix? would cat coolant be ok to run?
Most of the non-distilled water should drain out if you give it time. I wouldn't think that what little non-distilled water is left in there would be a problem. As far as the reserve tank, you have to suck it out with a siphon or something similar.
__________________ '03 2500 QCSB 48RE
Special Thanks to FTE Diesel (216) 496-3600
Have a question? SEARCH!
after i flushed the system twice with water i can only seem to get 18 liters of antifreeze in? how much water would be left in the block after the flush? what about the reserve tank? how do you fill that? hot or cold?
