Engine codes
5.6K views 7 replies 4 participants last post by  MATRIX
Well - I have a question about codes. An 07 5.9 Mega... I was trying to retreave my hour meter but could not remeber how i did it before. In the process I held the odometer button in and turned on the ignition. (I had tried to have the ingintion on and hold the odometer to get hour meter and it didn't) So I held the button turned on ignition and got some sort of test pattern - three sets of numbers - first with two dashes (on above the other) and the number 33, then, space with the number 44 then a C with 541 .... what are these numbers - and how do I get my hour meter.....?? As it cycles through, the tack speedo and other gauge needles bounce to different positions as well.....
#5 ·
page 183 of the owners manual....
NOTE: There is also an engine hour function. This
indicates the total number of hours the engine has been
running. To display the engine hours perform the following:
Place the ignition in RUN, but do not start the
engine. With the odometer value displayed, hold the trip
button down for a period of 6 seconds. The odometer will
change to trip value first, then it will display the engine
hour value. The engine hours will be displayed for a
period of 30 seconds until the ignition is turned off or the
engine is started.
THANK YOU - I went through that stupid book a dozen times and kept missing it..... Though I still WONDER (Not Worry) about those numbers that came up on the cluster test cycle??
#8 ·
01 Cargo lamp LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
02 Cargo lamp LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
03 Door ajar LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
04 Door ajar LED output circuit overload/ short to battery. Refer to the appropriate diagnostic
information.
05 ETC LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
06 ETC LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
07 Seatbelt LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
08 Seatbelt LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
09 Air Bag LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
0A Air Bag LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
0B BTSI output circuit shorted or open. Refer to the appropriate diagnostic
information.
DR/DH
INSTRUMENT CLUSTER -SERVICE INFORMATION 8J - 109
INSTRUMENT CLUSTER FAILURE MESSAGE
FAULT
CODE
DESCRIPTION CORRECTION
0C PRNDL switch input circuit low. Refer to the appropriate diagnostic
information.
0D PRNDL switch input circuit high. Refer to the appropriate diagnostic
information.
0E DTCM switch input circuit low. Refer to the appropriate diagnostic
information.
0F DTCM switch input circuit high. Refer to the appropriate diagnostic
information.
20 Panel dimmer input circuit low. Refer to the appropriate diagnostic
information.
21 Panel dimmer input circuit high. Refer to the appropriate diagnostic
information.
22 Headlamp switch input circuit shorted. Refer to the appropriate diagnostic
information.
23 Headlamp switch input circuit open. Refer to the appropriate diagnostic
information.
24 Turn hazard switch input circuit shorted. Refer to the appropriate diagnostic
information.
25 Turn hazard swiitch inpot circuit open. Refer to the appropriate diagnostic
information.
26 Panel illumination output circuit low/high fault. Refer to the appropriate diagnostic
information.
27 Courtesy/dome output circuit shorted or open. Refer to the appropriate diagnostic
information.
28 Glovebox/map lamp output circuit shorted or open. Refer to the appropriate diagnostic
information.
29 Cargo lamp output circuit shorted or open. Refer to the appropriate diagnostic
information.
2B High Beam LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
2C High Beam LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
2D Brake LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
2E Brake LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
2F Check Gages LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
30 Check Gages LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
31 ABS LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
32 ABS LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
33 MIL LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
34 MIL LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
8J - 110 INSTRUMENT CLUSTER -SERVICE INFORMATION
DR/DH
FAULT
CODE
35 Water in Fuel LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
36 Water in Fuel LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
37 Wait to Start LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
38 Wait to Start LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
39 Trans Temp LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
3A Trans Temp LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
3B Low Fuel LED output circuit open load/short to ground. Refer to the appropriate diagnostic
information.
3C Low Fuel LED output circuit overload/short to battery. Refer to the appropriate diagnostic
information.
3D BTSI output circuit high fault. Refer to the appropriate diagnostic
information.
40 Wiper switch input circuit shorted. Refer to the appropriate diagnostic
information.
41 Wiper switch input circuit open. Refer to the appropriate diagnostic
information.
42 Wash/beam input circuit shorted. Refer to the appropriate diagnostic
information.
60 Passenger door lock switch input circuit shorted. Refer to the appropriate diagnostic
information.
61 Passenger door lock switch input circuit open. Refer to the appropriate diagnostic
information.
62 Passenger door lock switch input circuit stuck. Refer to the appropriate diagnostic
information.
63 Driver door lock switch input circuit shorted. Refer to the appropriate diagnostic
information.
64 Driver door lock switch input circuit open. Refer to the appropriate diagnostic
information.
65 Driver door lock switch input circuit stuck. Refer to the appropriate diagnostic
information.
66 All door lock output circuit shorted to ground or voltage. Refer to the appropriate diagnostic
information.
67 All door unlock output circuit shorted to ground or voltage. Refer to the appropriate diagnostic
information.
68 Driver door unlock output circuit shorted to ground or voltage. Refer to the appropriate diagnostic
information.
6C Driver cylinder lock switch input circuit shorted. Refer to the appropriate diagnostic
information.
6E Driver cylinder lock switch input circuit stuck. Refer to the appropriate diagnostic
information.
80 Incorrect odometer value found. Refer to the appropriate diagnostic
information.
DR/DH
INSTRUMENT CLUSTER -SERVICE INFORMATION 8J - 111
FAULT
CODE
81 Remote radio switch input circuit high. Refer to the appropriate diagnostic
information.
82 Remote radio switch stuck. Refer to the appropriate diagnostic
information.
A0 Internal module FLASH memory checksum failure. Refer to the appropriate diagnostic
information.
A1 Internal module bootloader failure. Refer to the appropriate diagnostic
information.
A3 Battery voltage open. Refer to the appropriate diagnostic
information.
A4 Ignition Run/Start circuit rationality. Refer to the appropriate diagnostic
information.
A5 TCCM messages not received. Refer to the appropriate diagnostic
information.
A6 Ignition Unlock circuit rationality. Refer to the appropriate diagnostic
information.
A7 VIN checksum error. Refer to the appropriate diagnostic
information.
A8 VIN previously stored. Refer to the appropriate diagnostic
information.
A9 PCI bus internal failure. Refer to the appropriate diagnostic
information.
AA PCM messages not received. Refer to the appropriate diagnostic
information.
AB TCM messages not received. Refer to the appropriate diagnostic
information.
AC ABS messages not received. Refer to the appropriate diagnostic
information.
AD FCM messages not received. Refer to the appropriate diagnostic
information.
AE ACM messages not received. Refer to the appropriate diagnostic
information.
AF SKIM messages not received. Refer to the appropriate diagnostic
information.
B0 RKE fob batteries low. Refer to the appropriate diagnostic
information.
B1 RKE module communication link. Refer to the appropriate diagnostic
information.
B2 Left Turn LED open circuit. Refer to the appropriate diagnostic
information.
B3 Left Turn LED short circuit/overtemp condition. Refer to the appropriate diagnostic
information.
B4 Right Turn LED open circuit. Refer to the appropriate diagnostic
information.
B5 Right Turn LED sshort circuit/overtemp condition. Refer to the appropriate diagnostic
information.
B6 Panel illumination open circuit. Refer to the appropriate diagnostic
information.
8J - 112 INSTRUMENT CLUSTER -SERVICE INFORMATION
DR/DH
FAULT
CODE
B7 Dome lamp open circuit. Refer to the appropriate diagnostic
information.
B8 Cargo lamp open circuit. Refer to the appropriate diagnostic
information.
B9 Door Unlock to Lock all shorted to ground. Refer to the appropriate diagnostic
information.
00 Done All Diagnostic Trouble Codes (DTC)
have been displayed.
