Old 10-09-2008, 11:20 PM   #1 (permalink)
DemonMaestro's Avatar
Chevy 1972 cummins swap?
Well a couple of question would a cummins 5.9L 24 valve fit and also would it twist the frame? and would i have to do any modifications?
here is a couple of pics
Let me know.
1972 Chevy Super Cheyenne with a 350 engine! Its a classic weekend joy rider!
2001 Ferd ranger 4 banger manual... I love making that thing...
Comming soon 2003 or 2004 dodge 3500 CUMMINS.!!!!!!!!!!
DemonMaestro is offline   Reply With Quote
Old 10-09-2008, 11:34 PM   #2 (permalink)
SPEAKSUP's Avatar
It should fit Theres one with a 12 valve as far as the frame well shouldn't But if you want some added strength Box the frame.
2003 P PUMP OHIO COAL ROLLERS
SPEAKSUP is offline   Reply With Quote
Old 10-10-2008, 01:10 PM   #3 (permalink)
o come on only one person?
Old 10-10-2008, 02:24 PM   #4 (permalink)
FOverRebuiltDodge's Avatar
you should try putting this in the conversion area, there are more peolpe there that may be willing to help you with this one. you may want to go ahead and box the frame to start with, seeing as how it looks to be a 1/2 ton. I dont see why it wouldnt fit, however if it wont, just get a really big hammer then it will go in with no problems. the frame rails on my truck is are really close together, only like 34", and i've got lots of room. good luck.
78 Ford F250, 24 valve from a 2001, NV4500 Trans, NP241dhd Transfer, 6” lift, 35” tires, 4" exhaust, holley blue fuel pump, homemade fuel filter setup, relocated apps inside of cab, a ton of money, and more to come.
FOverRebuiltDodge is offline   Reply With Quote
Old 10-10-2008, 04:18 PM   #5 (permalink)
2321.41 miles from BBram
dezl's Avatar
the mods took the day off its friday......
But to answer your question yes it will fit although I cant see the badges but it looks like a 2 wheel drive 1/2 ton. So as stated I would start by boxing the frame and then I would worry about the suspension after. These cummins are heavy!
Then I would throw a d60 under the front and coil it....sorry tangent.
94 f350 w/ 95 6bt, Nv4500, Valair clutch, 370 Hp Marine Injectors, #4 fuel plate, dodgezilla hybrid turbo, 18* of timing, lazer cuts, 4k GSK, 60lbs springs and a lot more!
dezl is online now   Reply With Quote
Old 10-10-2008, 05:00 PM   #6 (permalink)
texasfireman's Avatar
thats a clean truck, orig. or resto? 12 valve will fit, get big block springs and box the frame up front.
01 cummins quad cab short bed 2wd 5sp. Edge comp, Edge Jammer 75 horse Injectors, BHAF, MBRP 4in turbo back,to a 5 1/2 in single stack, Silencer Ring? What Silencer Ring? And a Smoke Switch for fun.
texasfireman is offline   Reply With Quote
Old 10-13-2008, 11:08 PM   #7 (permalink)
the truck is still orig. but i just want a diesel under the hood.... But i just dont want to twist the frame... what about the rear end? and would the 12valve tranny work?
Old 10-14-2008, 06:20 AM   #8 (permalink)
Can somebody please give me the width/height/length of the 12valve engine and then the same for the tranny?
Old 10-14-2008, 06:38 AM   #9 (permalink)
lobsterman04's Avatar
for the trans you need to find a p30 bread truck with the 4bt. behind that 4bt is all the hardware to bolt up a turbo400, including the t400. as for twist. don't go power crazy and for rear axle, corporation 14 bolt or dana 70hd. Good luck!!!
99 2500hd quad cab long bed,4.10, white n grey 2tone. BHAF, 4in custom stack with rain cap and heat shield, boost guage,airdog150, 150sticks, Adrenaline!. soon an s300! THANKS TO COAL TRAIN DIESEL PERFORMANCE
lobsterman04 is offline   Reply With Quote
Old 10-14-2008, 02:06 PM   #10 (permalink)
about how much weight does the motor and tranny weight
Old 10-14-2008, 03:49 PM   #11 (permalink)
TOMTOM's Avatar
Somebody Got Da Fever!!!!
A 12v is around 1000lb.
Don't worry about that frame. This would be a sweet swap.
O and thanks 4 posting the burnout vid.
TOMMY
93 SRW D2500 X-CAB SHORT BED LE CTD AUTO BHAF P7100 PUMP PUMP MODS 4000 GSK 60# SPRINGS A1 STUDS FULL MANUAL 47RE BILLET INPUT SHAFT SUNCOAST TRIPLE DISC 440/967 13.31@101mph 0N #2
TOMTOM is offline   Reply With Quote
Old 10-14-2008, 11:04 PM   #12 (permalink)
TOMMY
Of course.! I thought its was bad :booty: that you tryed and did well...
can somebody tell me what kind of auto tranny is in a 1994 - 1997 dodge cummins. I am thinking about putting that in. should i worrie about the rear end?
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
