12 or 24 valve cummins - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 12-28-2005, 02:46 AM Thread Starter
Ok I'm new here, and I'm looking for a new/used 3/4 ton 4WD and besides the obvious what is the difference between 12 and 24 valve cummins engine
snowman is offline
post #2 of 19 (permalink) Old 12-28-2005, 09:26 AM
The 12v is properly valved. :thumbsup The 12v is generally cheaper to bomb than the 24v. The 24v is more of a "plug and play" type for bombing. The 24v is more prone to having LP problems and also more electrical problems. The VP is also a known issue.
Tom
Contact me at:
Tom05 is offline
post #3 of 19 (permalink) Old 12-28-2005, 10:49 AM
Guest
Guest
Posts: n/a
Dont even concider this Snowman
1998 12V 5 Speed
Trust me if you dont get this someday you will wish you would of.
DM
post #4 of 19 (permalink) Old 12-28-2005, 11:05 AM
Welcome snowman, I,m new here also. I don't know much about 12v but I just got a new 24v, on the new trucks watch the payload the book the dealers give you says the payload on a 2500 is over 2000lbs and three different salesmen at different dealers all told me different numbers above 2000lbs. But after getting confused at this I called dodge. The payload for a 2500 quad cab 4x4 with ctd is 1,880lbs, so I went with the 3500 it has a payload of 2,710 still on the low side for a 1 ton. Just FYI.....
happy shoppin
'06 atlantic blue cummins 3500 laramie quad cab LWB,G56,4x4,3.73,anti-spin,nerf bars,bed liner,prodigy,prxb pacbrake,weathertech floor mats and side window deflectors, snugtop hi-liner,Westach high boost combo on srt-10 pillar
AtHomeDale is offline
post #5 of 19 (permalink) Old 12-28-2005, 11:12 AM
post #6 of 19 (permalink) Old 12-28-2005, 12:12 PM
Tech Specialist
AZBLACKSMOKE's Avatar
My brother has a fleet of 24v's and he likes them. I personally prefer 12v because I am always broke and 12v are easier to bomb and tinker with.
2001 GMC 2500HD, crewcab,LB, 4x4, duramax, ZF6, Southbend SD, organic, hypertech.
1989 C3500 reg cab flatbed, 6.2, GM4 turbo, Was TH400, process of installing NV4500.
I LOVE the CTD...I just dont like the shipping container it comes in.
AZBLACKSMOKE is offline
post #7 of 19 (permalink) Old 12-28-2005, 01:11 PM
underpsi's Avatar
I like 12 vavles much more cuz I hate all the stupid computer crap and sensors and blah blah blah! don't get me wrong I like the 24v cummins its just I don't like to rely on computers and such, plus i feel the power isn't the same as the mechnicals.
1989 D250 5spd, Hurst shifter, 20in Eagle Alloys, .020 over head gasket, O-rings, Extensive port/polish, ARP head studs, 16cm housing, PODs, Pump turned up, AFC lever delete, Stock exh straight piped, AFE Mega cannon filter, Isspro EV series Pyro, Boost, and Fuel Pressure.
underpsi is offline
post #8 of 19 (permalink) Old 12-28-2005, 06:15 PM
Guest
Guest
Posts: n/a
All great points given ,,, the 24V starts up easier and the extra 12 valves are great !! however between Apps , ECM , VP44 , LP , and all the Electronic BS I would perfer the 12V ..
IF/When my Vp dies P pump here I come
Should be able to do that for well under 3 G's
DM
post #9 of 19 (permalink) Old 12-30-2005, 02:31 AM Thread Starter
1998 12V 5 Speed
DM
So are you saying this is the way to go or not? I had a 93 3/4 ton and it was fine had to get rid of it though, I'm looking for something that can tow something around 5k maybe more on occasion and a daily driver dependability is more important than anything else also what is "Bombing" ? Does the 12 valve have mech injectors and the 24 valve not? thanks
snowman is offline
post #10 of 19 (permalink) Old 12-30-2005, 09:35 AM
Both engines have mechanical injectors. The 12v have a mechanical fuel pump (P7100) that is concidered pretty much "bullet proof". The 24v has an electronicly controlled fuel pump (VP44) that has, shall we say, "some issues"? Actually, it is quicker to get more power out of the electronics since they are 'plug and play'. The 12v is generally cheaper to get more out of though.
Tom
Contact me at:
Tom05 is offline
post #11 of 19 (permalink) Old 12-30-2005, 10:31 AM
Guest
Guest
Posts: n/a
12V all the way !!
Cheaper to Bomb and can really do some cool things with them
DM
post #12 of 19 (permalink) Old 12-31-2005, 12:22 AM Thread Starter
Great thanks for all the info. Snowman
snowman is offline
