Shift Points 5 Speed - Dodge Cummins Diesel Forum
Old 09-04-2008, 08:04 AM   #1 (permalink)
CumminforCummins's Avatar
-When is the best time to shift...?
-When do you gear down or just use brakes?
-How do you avoid clutch burnout etc?....
AKA how to drive your cummins!
(conservatively not rollin coal...)
Just bought my new 5 speed and I just wanna take care of her!
CumminforCummins is offline   Reply With Quote
Old 09-04-2008, 08:12 AM   #2 (permalink)
GA CUMMINS CREW PREZ & Captain of the USS FAILBOAT!
SOUTHERN SMOKE's Avatar
shift points on a 5 speed, around 2k-2200, downshift around 1700, never ever lug it lower than 1500, and never pull in 5th unless pure flat with no stress, up hill, heavy loads, slow down and gear down, and keep a check on dope in the tranny, this will extend the life alot....:thumbsup
2011 3500, stock, 2003 QCSB 4X4 5.9 6spd, Smarty, Valair, K&N, ARP, Topgun, Autometer, 5" Stacks, Smoked Recons, KMC wheels, Cooper 35X12.50's, With enough get up and go to piss off your granny! Blacked Out And Engineered By Southern Smoke, And Dark Side Diesel!
CLICK -------> GEORGIA CUMMINS CREW
SOUTHERN SMOKE is offline   Reply With Quote
Old 09-04-2008, 11:17 AM   #3 (permalink)
terminaltsi's Avatar
i shift mine at 1800 if i'mjust cruising around. i shift down most of the time to start slowing. when i take off from a stop i just slowly let the clutch out, no need for throttle unless you do a 2nd gear start.
'99 5 speed, 4x4, gauges,Quadzilla ADR, Smarty, BHAF, 100s, 5" turboback, water/meth inj. 315/75/16 maxxis bighorns, Airdog,13" Valair,4300k HID's, HID off road lights, 2 Low kit, LED interior lights,alpine/cerwin-vega/mmats audio, Viair onboard air.
terminaltsi is offline   Reply With Quote
Old 09-04-2008, 01:11 PM   #4 (permalink)
thanks guys i'm just trying to get opionons from everyone around here. The truck has 225k with the clutch from the factory. It just keeps going and going..... does bogging the motor burn your clutch out or hurt anything?
Old 09-04-2008, 01:41 PM   #5 (permalink)
TECH SPECIALIST
DodgeCummins98's Avatar
I shift mine at 2k or even a little before. I'll let it get down to about 1000-1100 rpm before I downshift if I'm just driving along pretty easy in town or something.
Now with 5th gear I don't shift to 5th until at least 2k and I downshift at no less than 1500 rpm.
98.5 2500 4x4 Reg Cab, 6" GrandRock's, SBC DD 3250, Adrenaline w/ Pulse, FASS 150, Isspro gauges, Auto to NV4500 swap, Leveled on 315's - GONE
07.5 3500 6.7L G56 Manual 4x4 Quad Cab Dually, Bone Stock
DodgeCummins98 is offline   Reply With Quote
Old 09-04-2008, 06:36 PM   #6 (permalink)
RamThisCummins's Avatar
well you don't have to start in first unless towing...
And I don't know if double clutching/ mid gas to slow down is necessary, will it save the clutch better??? no idea... My dad taught me a couple months ago.....
2001 Dodge 2500 cummins, Firepunk Diesel, my momma said I couldn't handle the v8 so I bought a cummins instead
RamThisCummins is offline   Reply With Quote
Old 09-04-2008, 06:49 PM   #7 (permalink)
upinsmoke53020's Avatar
Imagine driving barefoot, with thumbtacs on your throttle pedal. Thats how a cummins is meant to be driven! Nice and easy, very low power band. Don't need to run 3k to make power.:thumbsup
99 Dodge Ram 2500, 5-speed, Edge Hot Juice w/attitude, RV275's, 4" turbo back exhaust, BHAF, Pro Comp M/T 33X12.50R17, Leveled, AIRDOG 150, Boost, Pyro pillar guages.
upinsmoke53020 is offline   Reply With Quote
Old 09-04-2008, 07:40 PM   #8 (permalink)
J REED '98 6BT's Avatar
if you want to take care of her, in my opinion dont ever downshift to slow down(empty no load), with a stop ahead. when i am rollin around and see a stop light or sign i grab the clutch and put it in N! then as traffic patterns allow i will select the gear for the given speed. from a stop use 2(unless huge hill or loaded). the 3 rd gear is fairly tall but if i am slowing down from 40-50 mph to turn on my side street , i brake, clutch, then gently slip into 3rd (You can feel the syncros work) and take off again at 20 ish mph . she lugs a little at first, but will not hurt anything in the 5.96bt. Just the way I learned how to drive a handshaker. brakes are cheap, easy to replace and the tranny/clutch is expensive to replace and burnup. also dont lug under 1600 rpm in 5th and never idle at a stop with your clutch depressed, it will wear out your throw out bearing fast! the beauty of the manual is you can decide what gear/speed is best for your application/speed. I think my truck likes a combination of being driven like old granma would and puttin the hammer to the floor. just my two cents. peelout
11/97 2500 Club Cab 4WD NV 4500 3.55's # 11 Plate, 16* timing , 285/75/16 , 220,XXX miles...
J REED '98 6BT is offline   Reply With Quote
Old 09-04-2008, 11:46 PM   #9 (permalink)
got some good opinions here! Thanks.... keep em coming!
2004 QUAD CAB SHORTBED NV5600
Old 09-05-2008, 08:53 AM   #10 (permalink)
renopker's Avatar
Thats funny in 40 years of driving with clutchs Ive never had a throw out bearing were out.
A stupid man's report of what a clever man says is never accurate because he unconsciously translates what he hears into something he can understand
renopker is offline   Reply With Quote
Old 09-06-2008, 04:10 PM   #11 (permalink)
trucks like this are amazing...
Old 09-06-2008, 07:12 PM   #12 (permalink)
Big Smoky's Avatar
The reason for not lugging it in 5th is because it's hard on the 5th gear nuit and helps it back off with will lead to you not having 5th gear. But, sometimes it happens anyway like it did to me.
Truckless
Burned in wildfires...R.I.P.: '95 3500, Reg. Cab, 4x4
Eric
Big Smoky is offline   Reply With Quote
