Got my juice w/ attitude! any tips on installation?
kinda new at this and my feet are getting the cold sweat getting ready to put this in any tips or advise to help me along the way? thanks.
dodgin_bullets 2001 ram, 2500, 4x4, cummins 24v, reg cab, long box, white, straight piped, 5" inch tip, line x bed liner, so on and so forth :thumbsup
Edge's instructions are pretty straight forward. I would purchase a staelth cover for the VP44 to have a more secure connection to the pump.
Also, just take your time drilling the manifold for the pyro, use plently of grease and be sure to use a magnet to clean the inside of the drilled hole to catch any metal shavings.
oh yeah you could just tap it for now and get the cover a bit later i guess
I dropped my turbo and drilled then cleaned out by starting the truck with out the turbo, piece of cake took me like 30 min. The cover isn't needed if your not worried about warranty. It does connect a little better. If you took your time you can take things apart and tap into the right wire on your vp 44 and sodder it in there. I would recomend a fass pump or something similar cuase the stock lift pump wont last long and you dont want that to go. It will take out your vp 44. Then you could tap into the new pump on the bench if that happend. Keep an eye on fuel psi and all your other temps. your tranny will slip and go out if you don't have any mods if you use the higher settings. If you have or get an after market pump such as fass you need to put in a tee for your fuel psi sensor on your edge. :thumbsup Hope some of this helped.
If you don't have it, get the pillar mount for your Attitude monitor. It is worth the money and makes for a real professional looking install. I love mine.
:thumbsup
2001.5 White 2500 Reg-cab • 4x4 • NV4500 • 4.10 • BHAF • WALBRO GSL392 • Edge Juice + Attitude • VALAIR HD OFE • Scangauge II • 315 Cooper S/T's • Optimas • custom black grille & blue graphics • ** Diesel Fuel Treatment is here **
how long will my pump last if i dont drive it like a retard
