Old 08-14-2008, 09:15 PM   #1 (permalink)
rough idle when warm
I have a 95 12valve. Runs grest when cold then develops a rough idle and sounds like it might be missing. 180 K
Recent injectors, new fuel filter and air filter.
Any ideas?
mpieper is offline   Reply With Quote
Old 08-15-2008, 09:32 AM   #2 (permalink)
You may have the idle set too low. It should be 850 with the trans in gear (if auto) and the AC on. Look here for fuel system info: Joe G's fuel system writeup
You should fill out your signature with truck info so we can answer questions better.
KDP tab fix info and fuel system article jgeorge1@suddenlink.net '95 2500 CC auto 4X4,3.54,Combo EGT/boost guage,PacBrake,TST #5,370 injectors,DTT TC/VB, Cummins chrome kit.
Joe G. is offline   Reply With Quote
Old 08-15-2008, 09:34 AM   #3 (permalink)
Calling All 12v Guys
GOING THROUGH THE SAME STUFF MAN.
95 12v one ton 5 spd. custom 5x14 injectors.66mm hx50 timing 17.5. 4k gv springs, marine head gasket, 12 mm studs 191 dv's. single 7 in stack.
421/ 893 ON OLD TUNE UP. guages of corse. POWER PARTS ENGINEERING DD clutch. FOR SALE.
chevy791979 is offline   Reply With Quote
Old 08-15-2008, 09:42 AM   #4 (permalink)
I.B. Cummin's Avatar
is 65 or 7 too low with ac on?
(looking 4 injectors) '98 12v 2wd 5sp man:#100 plate ff,4k gsk w/hd springs,aem HD,4"exh, ring-heat grid-cat-muff all gone, kdp tabed, etc. and an 04.5 HO qdcb(stock)
I.B. Cummin is offline   Reply With Quote
Old 08-15-2008, 09:44 AM   #5 (permalink)
If you mean 650 or 700, the answer is yes.
Old 08-15-2008, 09:48 AM   #6 (permalink)
with ac on and sitting still im below 700, i guess its time for a lil adjust. do u recommend 850 or 900 or 1000?
Old 08-15-2008, 09:50 AM   #7 (permalink)
850 works well for me, but I have an auto. Maybe some guys with manuals will chime in if 850 is too much or too little for a manual.
Old 08-15-2008, 05:13 PM   #8 (permalink)
Mine in a manual, what is the correct idle for it ? It now idles at about 650.
Thanks
Old 08-15-2008, 07:52 PM   #9 (permalink)
650 is way too low.
Old 08-16-2008, 06:08 PM   #10 (permalink)
Yesterday the truck idle was very smooth, not sure if it was just the cool air temp all day (max 63 degrees) or what.
We will see what happens when it gets hot again.
What effect might temp have on the way the truck idles?
95 12 valve, stage 1 pump modification, 4 " exhaust,
5 speed
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
