Old 07-25-2008, 10:02 PM   #1 (permalink)
dieselrider23's Avatar
Is this a good run for what I got?
I went to the track with cumminalong (Rich) and ran the truck. The fastest time I ran was a 10.00, and that was on the 1/8 mile. The video is in my sig. Im the red truck.
Yeah I know............cumminalong's truck is faster then mine.
2001,Auto,Sport, 4x4, with Edge Juice w/Attitude "HOT", AEM Brute force Air intake, MBRP turbo back 4" straight pipe, Airdog 150 ,Silencer ring MIA, Homemade J Hook,BD Performance Flexplate, Hansen Trans, AMSOIL, Recon Cab Lights, CFM+
9.87 @ 71.23 MPH in the 1/8
http://www.youtube.com/watch?v=G-1VmEgrFCc
dieselrider23 is offline   Reply With Quote
Old 07-26-2008, 09:01 PM   #2 (permalink)
anybody..................
Old 07-26-2008, 09:31 PM   #3 (permalink)
West Virginia Chapter President.
Chris Mallett's Avatar
Looks pretty good to me...
2005 QC LB Dually, 4x4, F1 Helix 2 Cam, Sportsman springs, Fluidampnr, Edge Juice w/Attitude, Smarty, S&B Cold air intake, Needing tranny goodies badly.
Check out the West Virginia Cummins Crew
Chris Mallett is offline   Reply With Quote
Old 07-27-2008, 11:54 AM   #4 (permalink)
Performance's Avatar
Seems about right. I honestly think your truck should run high 9s easy.
To give you something to compare it to, I ran a 10.17 at 70.73mph in the 1/8th with my truck a couple weeks ago. Thats with a 6sp, stock clutch, and 22.5s which are heavy. Also with the small amount of mods in my sig. So I think your truck should be a little faster, but it's very, very, respectable right now.
2006 DODGE RAM 3500 - Silver, Reg. Cab, 4x4, Dually, 6spd, Quadzilla X2 Race Module, CFM+ Intake, AEM Workhorse Intake, Banks Monster Dual Exhaust, MBRP Cat. Delete Pipe, Isspro Gauges, Air Horns, ReadyLift Leveling Kit, 22.5" Alcoas, 255/70 Sumitomos.
Performance is offline   Reply With Quote
Old 07-27-2008, 12:19 PM   #5 (permalink)
NE Chapter President
Rollin Coal's Avatar
10 flat is only a 15.6 1/4, i think you should be low 9's easy
Thanks to Diesel Auto Power ...... '01 - 2500 53 Block ...... 600+ HP Build Up Thread
Traction Bars|AirDog 150|Edge Juice with Attitude HOT|285/60-18's|Tailgate Spoiler|Black Projector Headlights|Roll Pan|S&B 70-5044|Stock Head Bolts at 125lb/ft|Grid Heater Deleted|Industrial Injection 66/71/14|8x.012" Injectors|Autometer 100psi Boost Gauge|.093" Connector Tubes|Some Suspension Work|Non-intercooled|4" Turbo-back|7" Black Miters|48gph of Water/Meth|Junk 47re|Autometer 150psi Meth Gauge
Rollin Coal is online now   Reply With Quote
Old 07-27-2008, 04:47 PM   #6 (permalink)
All those runs were on setting 5 on the edge. I wonder if it might have been defueling because of egts. next time im going to run it on 4 or maybe 3 to test it out. But I thought it should be in the 9s atleast.
Old 07-27-2008, 04:54 PM   #7 (permalink)
cumminalong's Avatar
Ray,
My first runs there were mid 9's in my truck. After some tweeks with the Smarty and adjusting the Edge DOWN, I've dropped over a second, almost a second and a half.
My first runs were with the Smarty on Revo 6 and Edge 4. It was hitting the defuel points too quick and my times were high.
Once I backed it off a bit, to #2 on the Edge and loaded the TNT program, my times started dropping.
Where I really picked up the most time was when I used the Smarty to get rid of the stock Tq Management. That set the launches up a lot harder. I also added a bit of timing and rail pressure in with the Smarty and it's help keep the EGT's manageable.
The times will drop. Just need to make a few more runs.......that's why it's called Test and Tune.
'06 Ram 2500 CTD, SRT-6, QC, 4X4, Full Sun Coast Tranny, ATS Aurora Compounds, PPE Dual CP3's, ATS Intercooler, DDP 90's, Waterboy (3 Stage), ARP Head Studs, FASS 150, Edge Hot Juice, Smarty TNT, CFM+, BD Boost Tube, 5" Magnaflow Black Duals
cumminalong is offline   Reply With Quote
Old 07-27-2008, 05:20 PM   #8 (permalink)
run the edge on 5 if you have the stock hy35, run the low end fueling on 1 or 2 for stock boost (21ish). see what your egts are. also, set the defuel for the egt's at 1400. how much boost are you making with the j hook. i ran my edge on 5x5 with 26 psi and stayed at about 1350 for egt's.
you can also display if fuel is getting cut, in the display options there is "backdown %". i use it for tuning all the time, 0% is full fuel cut, 100% is no fuel
Old 07-27-2008, 06:34 PM   #9 (permalink)
with the j hook im getting right at 30 psi. I might tighten it a little more to try and get some more out of it.
im going to try and go next friday and mess with it some more and see if i can get it in the 9s
Old 07-27-2008, 07:09 PM   #10 (permalink)
28-30 is about it for the hy30, you're prolly hurting performance. try dropping down to 26-28 and run on 5x5 or 6x3.... 6x5 and i get pretty hot with the hx40
Old 08-15-2008, 08:32 PM   #11 (permalink)
well i put it in the 9s tonight, I ran a 9.93
Old 08-16-2008, 07:49 AM   #12 (permalink)
What? You ain't gonna tell us about your first run???
BWAHAHAHAHA!!!
  • AutoForums.com
  • Truck
  • European
  • Import
  • Domestic
  • Manufacturer
Visit AutoForums.com today.
