CumminsForum.com is the premier Dodge Cummins forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 08-09-2006, 03:12 PM   #1 (permalink)
boosted12's Avatar
hurt turbo
hey, one of my buddies was gonna do a pyro on his 2003 cummins 6spd with a bully dog power pup, so i told him to drill it right in front of the turbo, and it drilled it right in the top of the turbo!! so he tried to start it and oil came pouring out, so he tapped it and put a bolt in it, but now, he said he has no power anymore!! will he need a new turbo now, because wont that sieze the turbo without oil flowing through it?
1998 Cummins 12 valve
#100 Fuel plate slid forward, AFC full forward, dynomax exh., starwheel fully turned, green air cleaner, washer GSK mod,fully built tranny, triple disk TQ, autometer pyro
boosted12 is offline   Reply With Quote
Old 08-09-2006, 03:43 PM   #2 (permalink)
CTD610's Avatar
Oh crap!!!! I don't know, but I think your buddy might be in a world of hurt. Sounds like an expensive boo-boo to me.....:fist:
2006 RAM 2500 QC SLT 4X4 - THUNDER ROAD PKG - CTD - 6spd - AEM Brute Force CAI-HURST T Handle
Old Truck: 2001 Silverado 2500 HD 4X4 Duramax/Allison
IBEW 1600
.................................................. .....................................[SIGPIC][/SIGPIC]
CTD610 is offline   Reply With Quote
Old 08-09-2006, 04:28 PM   #3 (permalink)
#1 Thread Derailer
BBRam's Avatar
iTrader Score: 7 reviews
UT OH, That ain't good.
03-3500, DRW, QC, 4X4, DTT, HTT, FTE, S&B, FLO PRO, Motorsport Diesel, FloorIt, ARP, Fluidampr, DDP, Dipricol, Smarty, Edge EZ, MagHytec, ATS, Dynatrac
95 1500 Sport 2wd Cummins Drag Truck under construction.
Special Thanks to Garys Chassis & Fabrication
Old 08-09-2006, 05:50 PM   #4 (permalink)
cody@nl'sCTD's Avatar
i would think that it would seize the turbo but im not 100% sure. definately a costly mistake
cody@nl'sCTD is offline   Reply With Quote
Old 08-09-2006, 07:27 PM   #5 (permalink)
Dumb question, but is it possible the bolt is to long and is against the shaft holding it from turning? Have your buddy pull the intake off the turbo and back off the bolt a little and see if it spins.
Tom
Tom05 is offline   Reply With Quote
Old 08-09-2006, 10:36 PM   #6 (permalink)
RDyson's Avatar
I would think the shavings from the drill & tap in the housing might not be a good thing either. But they are in the bottom of the pan now!
03 SO/Auto, QC/4X4, TST/Smarty/Puck, Boost/Fuel/Pyro/Rail Pressure, SPS-62, Goerend, Airdog, Arson Kit, GDP Power-Flo, , Fuel Tank Vent Mod, Donaldson 51", Wicked 50's, ARP, 613/1171, 13.16@108.2
RDyson is offline   Reply With Quote
Old 08-09-2006, 11:26 PM   #7 (permalink)
Cummins - No excuses
CumminAtcha's Avatar
Man, when you don't know what you're doing it can really be costly!! Good time for a phat shaft or something.....lol
Adam - MySpace
03 3500 QC/SB 48re sold....
03 2500 NV4500 525hp/996tq 4/14/07 Totaled 12/15/07
99 F250 7.3 PSD sold early 06
CumminAtcha is offline   Reply With Quote
Old 08-10-2006, 03:42 PM   #8 (permalink)
Looks like a new turbo is in his future...
surfbeetle is offline   Reply With Quote
Old 08-10-2006, 04:09 PM   #9 (permalink)
Tech Specialist
AK RAM's Avatar
Ditto that. Any shavings from drilling probably dropped right into the top of the bearing housing. Tolerances are tight in there and I would imaging the bearings were shot the first time he spun that turbo up. Definitely gonna be a costly boo boo. He could probably pick up a used stock turbo for just a couple hundred bucks on e-bay. Also check the classifieds on all the diesel forums. There are usually a few used ones to be had at any given time if you look around.
03, 4X4, QUAD, LWB, Standard Output, 47RE, 3.73, ATS TC/VB, DTT Trans/Billet, Flex Plate, TorqLoc, RAD, Twins, Snow, Helix2, TST, Hot Cp3, Injectors, 315s, 8,200 lbs wet.
12.32 @ 109mph Videos: Vid 1 & Vid 2
AK RAM is offline   Reply With Quote
Old 08-11-2006, 04:51 PM   #10 (permalink)
Got any pics?
02 QC SB 5spd, Drag Comp, 4" straight, BHAF, EGT/BOOST/FP gauges, 285 revo's. Walbro 392.
yarddog is offline   Reply With Quote
Old 08-11-2006, 05:10 PM   #11 (permalink)
boosted12's Avatar
just looked at it, its directly off the manifold, part of teh turbo, but its still running
Powered by vBulletin® Version 3.8.5
