Old 08-05-2006, 04:12 PM   #1 (permalink)
powerstroke_this_ford_boy's Avatar
Bhaf
Where do i get one of these and what do i call it at the counter. if i say " i want a BHAF" i doubt anyone will know what im talkin about. THANKS
2002 Cummins SLT laramie. ex cab LB 4x4.Cat and muffler delete,Custom crank case vent,D*pricol gauges. 60lb boost,30lb fuel psi, and pyrometer. BD lift pump and BD pusher pump .Diamond plate bed rails, 6" mitre cut grandrocks stacks,MADS smarty, K&n torque tube and heat sheild with BHAF & scilencer ring MIA and some tranny work :thumbsup
powerstroke_this_ford_boy is offline   Reply With Quote
Old 08-05-2006, 05:27 PM   #2 (permalink)
Super Moderator
TrueValue Truck's Avatar
I'll dig up the link for the bhaf and the outerwares for ya....its on here somewhere...you can get the filter cheaper on line than at the parts stores...
www.fleetfilter.com
Fleetguard AH19037
NAPA 2790
WIX 42790
Donaldson B105006
Baldwin PA2820
Hastings AF1012
AFE 20-40044
Carquest 87790
John Deere pmah19037
Big A 93790
Caterpillar 3i0005
Fleetrite ahr819037
Luber-finer laf2531
Fram ca6818
UNI 908
Outerwear cover wr3325-105
06 3500 SRW Mega Limo ,Smarty REVO TNT,Quad Commander,CFM Intake,Quad Monster Air COI,AFE Torque tube,II Silver 62/74/14,FASS 150 HPFP ,Straight Piped,BD Flex Plate,Goerend Triple Disc Converter and VB.Billet Input,Banks Power Brake with Smart lock
Ohio Coal Rollers
Cumminsforum.com
"The dogs hunger for the flesh of our enemies"
TrueValue Truck is offline   Reply With Quote
Old 08-05-2006, 06:37 PM   #3 (permalink)
thanks alot man. big help. can't wait to hear that turbo
Old 08-07-2006, 04:43 PM   #4 (permalink)
RJF
RJF's Avatar
Forget the 2790 filter, guys are running the new 4090 Amsoil universal filter and are liking them. They flow more air than a 2790 BHAF, are reusable with just a little bit of compressed air, and do NOT use oil like an AFE or K&N that doesn't filter the air well.
Plus, they are about the same price as a 2790 at the parts store and can be delivered to your door.
2006 3500srw Mega cab, laramie, Bully Dog PMT &RFI, 6" lift/35's.
2001.5 Ram 2500 4x4. Red Sport LB QC, black leather, billet everything. Edge HOT Juice/MBRP5"exhst/BHAF/Axiom &Suncoast trans, Amsoiled up
RJF is offline   Reply With Quote
Old 08-07-2006, 04:59 PM   #5 (permalink)
Talking
just ordered the 2790 and its in the mail as we speak:thumbsup can't wait till it gets here. since i removed my scilencer ring and straight piped my truck will i be able to hear the turbo alot better???? is there anything special i need to do to the stock tube to make the this filter fit?
Old 08-07-2006, 05:02 PM   #6 (permalink)
Moderator
Monster Truck's Avatar
are they as big as the BHAF? can we still utilize the heat shield and stock intake tube?
95 Ext Cab SLT, Loaded, built 5spd with hurst, 3.54s, Leveled 4'' Lift 35'' Toyos, optima redtops, 4'' Straight into a 5'' bed kit with 6'' Mitres, Protech, Super B 57/66/14, Stage 2 Sticks, 3GSK, #60 Valve Springs, Stage 2 clutch, BHAF, Plateless, Boost and EGT on the pillar fuel pressure on the colum.
Monster Truck is offline   Reply With Quote
Old 08-07-2006, 10:08 PM   #7 (permalink)
RJF
RJF's Avatar
Base OD 6", Flange ID 4", flange length 1.75", media heigth 9", top OD 5". It's pretty darned big, but not as big around as a 2790. You should be able to use your existing heat shield and your intake tube will work fine.
Old 08-08-2006, 12:46 AM   #8 (permalink)
Tech Specialist
You better give us flow and filtration efficiency numbers before you start making claims like its a big as a BHAF...
In Cummins we trust.
'99 Ford Superduty CC with 05 Cummins 325/600, BHAF, Donalson M090544 and ZF6 transmission. Tone ring mod.
Walbro 392 lift pump. 2 micron fuel filter on engine with filter lid pressure gauge.
I've been running a Walbro 392 since 2000. How long did your fuel pump last ?
My diesel blog:
http://common-sense-diesel.blogspot.com/
Superduty is offline   Reply With Quote
Old 08-08-2006, 01:35 AM   #9 (permalink)
RJF
RJF's Avatar
For one I never said it was physically as large as a 2790, infact I clearly state that it isn't, and beyond that posted it's exact size.
The 2790 only flows about 680cfm, thats not really all that much air. I will have flow and efficiency numbers tommorrow. I will call tech support in the morning.
Old 08-08-2006, 02:15 AM   #10 (permalink)
Tech Specialist
Be sure to get the pressure for which those flow ratings are for too. A flow number without a corresponding pressure is USELESS.
My diesel blog:
Old 08-08-2006, 12:40 PM   #11 (permalink)
RJF
RJF's Avatar
Unfortunately, Amsoil has not released air flow specs yet. The line of filters has just been released and test results are still in process. Sorry for the lack of data, but it should be available soon as more filters are out there and Amsoil gets further along with testing.
We are testing a few ourselves. I have sold a few, and we are testing them after replacing the 2790. I will post results.
Old 08-08-2006, 09:04 PM   #12 (permalink)
Tech Specialist
I don't mean to dis your product, but in air filters, larger is generally better, larger giving more air flow and more dust holding ability. Never the less, I will keep an open mind and await your numbers.
My diesel blog:
