07 5.9 how much oil in engine - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 04-15-2008, 07:22 PM Thread Starter
I didnt get a owners book how much oil does the engine hold ? i put 3 gallons in and its at the first mark below the safe side on the stick
Racer111 is offline
post #2 of 11 (permalink) Old 04-15-2008, 07:28 PM
smokedrail's Avatar
iTrader Score: 4 reviews
12 quarts with a filter change
06 cummins
96 cummins
95 cummins dump
smokedrail is offline
post #3 of 11 (permalink) Old 04-15-2008, 10:01 PM
LinemanTater's Avatar
Ditto:thumbsup
2013, 2500 Megacab Laramie G56 (Manual 6spd) 4wd, PPEI EFI Live.
2007 5.9 mega Dually
1998 24v
LinemanTater is offline
post #4 of 11 (permalink) Old 04-15-2008, 10:33 PM
Yep, 12 qts with filter change.
98 Ram 3500(SRW Convert) 4x4 Quadcab,HP215 IP(15.5*,4K GSK,60lb springs),DAP 5x.016 SAC injectors,AFE Filter, BD Twin Turbos, 4" exhaust, gauges,47re stage 5 billit in/out shafts,dunrite VB,727DD pan,ATS 5-star TC,Borgeson gear box/shaft,3.54 gears.
FlaCracker is offline
post #5 of 11 (permalink) Old 04-15-2008, 10:54 PM
rufushusky's Avatar
Bingo.:thumbsup
2002 Ford F-350 ECLB 7.3 4R100 4X4, 6637 intake, 203* T-stat, 08 diff cover, HPX, Stancor Relay, 6.0 trans cooler
Gone:
04.5 Ram 2500 Reg Cab 48re 205k miles
rufushusky is offline
post #6 of 11 (permalink) Old 04-15-2008, 11:06 PM
turbodiesel5's Avatar
3 Gal. unless there is a bypass filter system on it? then it would hold a little more.
2012 crew cab short box
turbodiesel5 is offline
post #7 of 11 (permalink) Old 04-15-2008, 11:35 PM
rufushusky's Avatar
yeah like a 1.5 to 2 quarts depending on how big the filter is..
Gone:
post #8 of 11 (permalink) Old 04-16-2008, 08:03 PM Thread Starter
Its all stock but 3 gallons puts the oil level at the first mark below the safe area ?
Racer111 is offline
post #9 of 11 (permalink) Old 04-16-2008, 08:12 PM
Diesel Head's Avatar
you got enoulf..
"I love the smell of burnt diesel in the morning , it smells like victory" USMC 73-76
2009 1500 5.7 HEMI Crew Cab, 4x4, 5 speed auto, 3.55
Diesel Head is offline
post #10 of 11 (permalink) Old 04-16-2008, 08:15 PM
josh brown's Avatar
3 gallons is what it takes but it is odd your dipstick is reading low, maybe it is an aftermarket stick?
josh brown is offline
post #11 of 11 (permalink) Old 04-16-2008, 08:51 PM
Harley27's Avatar
drive it for a while, then check after an hour or so. Mine does the same thing but after I drive around the block and park when I come to check it later its perfect.
sold
2006 Ram 2500 QC SB 6 Speed 4X4
Smarty, High Ram intake, Silverline turbo back, AEM Workhorse, Auto Meter Fuel, Boost, EGT, South Bend DD, Fluidamper, Kore HP. Airdog 150.
1992 W-250 mostly stock
Harley27 is offline
