What about a receiver hitch mount I have both front and rear on my truck
1998 CTD 24v,DTT trans billet in and out,Edge EZ, exhaust brake, 4" turbo back exhaust, 275 injectors, Mag-tech trans and diff pan/cover, piller gages, digital fuel psi, 4door, shortbed, larger turbo.Air Dog fuel pump/filter/air water separator
If the front is a good hitch. Those would work for a winch just pickup a slide in class 3 mount. Then you set other than running heavy power cable to both ends of the truck.
Some of those bigger winches are pretty heavy, and your not going to be able to move them around that easy. So before you buy one you might want to look at the weight. I have a 12,000 gorrila winch and It's almost 100 lbs.
09 Dodge Ram 2500, egr and dpf delete, external wastegate, 5" turbo back exhaust, Smarty Catcher ME, Valair 800 hp sfi dd clutch, shibby stage 2 intake horn, throttle valve delete, Volant cold air intake, airdog 2 165 gph. Dynoed 470 hp at 1042 ft/lbs.
There's a front reciever you can buy that mounts to the front of your pick up, then there is a mounting plate you can buy that the winch will bolt to, and that mounting plate allowes you to move the winch to the front or to the back of your pick up.
yes, if your not interested in installing a new bumper you can do the receiver method.
Their are a few aftermarket sources out there that sell receiver winch mount plates (basically a 2" receiver tube with a flat plate to mount your winch to).
Of course this means that you would have to install a receiver hitch on the front or youll be limited to rear pull only!
Like mentioned, a winch big enough to be useful on these pigs is f'n HEAVY!!! mind you a small winch will get you out of a pinch, but youll likely be snatchblocking it every time
2007 Laramie 3500, 4.5" RevTek, 35x12.5 ProComp MTRs, buckstop front+rear, bullydog TD, BD RFI intake, Lightforce 140s in the bumper, 240HIDs up top
1997 SLT 2500, 5.5" fabtech, 36x13.5 IROKs, 5x12s, s300, 4kgsk, inj pump FUBAR
