| General Diesel Discussion Discuss General Topics related to the Cummins , Dodge Rams , Other Diesels Ect....NO ADVERTISING |
#314 (permalink) | |
05 2500 crew cab 33s ultra wheels smarty revo. Dr.perfomance preditor Volant cold air. Autometer Phantoms. A/C delete, Banks high ram and intercooler, ATS manifold .II silver 66 big brother combo NADP Race Trans big sticks its in the 11s 1/4 mile two 5 inch stacks
#315 (permalink) | |||
Congrats on the new trucks!
![]() Quote:
I will recommend you get the fuel pressure gauge. While your CP3 is not as easily harmed by lack of fuel, it can still be damaged by it. If nothing else it will help you tell when your lift pump is bad or the fuel filter is clogged. The .5 that a lot of guys put on the year of their trucks is just to narrow down the specific changes on their truck. Seems that about every 6 months or so, Dodge changes a lot of things on these trucks. Take for instance the '07. Early '07s came with a 5.9L. Later in the year they came with the new 6.7L. Usually the changes are pretty small, sometimes they are bigger. Quote:
06 3500 4x4 SLT 48RE Mega sized, Plus 2 micron fuel filter, Twin Frantz oil filters, Rokk CPS, BHAF, ARE shell, Well, it's up to 14+ MPG and of course there's a list of wants!73 1210 2x4 Int'l - patiently waiting to become a Cummins! 76 Scout - looking for a 4BT! |
#316 (permalink) |
Got my first diesel. All the reading I have been doing is confussing me. I have a 92 IC CTD 4x4. What/where is the starting point? Is there a better oil to run? How about oil filters? I saw something about BHAF (air filter, so you know I know what it means) and a good place to order it, but now can't seem to find it. Gauges pryo boost fuel pressure? What is the dowel pin? I keep reading on changing the dowel pin and can't seem to find out what it is. I just located a FSM for the truck and I figure it will have so of the info I am looking for. Any info would be greatly appriciated. Thanks Chris
92 CTD intercooled 4x4 getrag swapped to ? (have not really looked to figure out what) BONE STOCK dualy |
#317 (permalink) |
hey everyone, newbie as of yesterday, seems i over looked this thread and feel that i should help fix my mistake. i posted this thread yesterday about getting a more clear picture on of these compound turbo setups you all use. Hey everyone! newbie looking to learn! just trying to make sure the concept i have running in my head is correct or not and if anyone with build pics could post a few that show your compounds in detail. |
#318 (permalink) | |
i like to go with WIX oil filters, go to any NAPA store, the NAPA brand filters are all made by WIX. WIX oil filters have all metal internals rather then most other brand which have a cardboard filler as the filtering piece. WIX also designs their filters to be performance specific, whether it be daily street using conventional oils, mid performance for those with mildly upgraded engines and running on lighter weight oils and then a gold line for those running legendary name holding engines running light weight full synthetic oils. though it doesn't matter if the engine is performance based or not or what type of oil you are using, each type of filter can be used regardless. each type just has different flow rates, the higher the grade, the higher the flow rate. then again, i don't know about diesels. but i will say, when i changed over to WIX filters, it took about 3 oil changes and my oil stayed so clean that i sometimes actually have to use sun light to see the glare of the oil just to check it's level... bad stuff goes in the filter, and it doesn't come out p-e-r-i-o-d...
#319 (permalink) | ||
You could get a BHAF from fleetfilters.com for a good price. Those gauges look good unless you don't have a stick anymore; then you need a tranny temp gauge. You refer to the Killer Dowel Pin fix. It is just putting a home made tab over the thing so it can't come out and damage your timing gears and housing. If you want to do it yourself, I can PM you some directions I got from another guy..... Any more questions, just fire away. Quote:
Dan
#321 (permalink) | |
Super Administrator
![]() 03-3500, DRW, QC, 4x4, DTT Trans, Mag-Hytec, R700 BD Twins, BD IC Boots, BD Billet Flexplate, Lockup Switch, SMARTY TNT-R BETA/TS MP-8, Eliminator Fuel System, Floor It Stage 3 CP3 & Rail Cap, BIG Stix's by FTE, ARP Head Stud's, Springs, Fluidampr, ATS ARC-FLOW, AFE, Boost, Drive Pressure, Pyro, Fuel Pressure, Tran's Temp, Rail Pressure Gauge, GDP Ladder Bars, GrandRock 7" Miters. Old #'s (R/T .021, 60' 1.76, 1/4 ET 13.14 @ 100.45 mph) |
#323 (permalink) | |
First one is right here on our own site.... Air Filtration Results with Various Aftermarket Filters - A This next one is a pretty good test. It is more 'scientific' than what AK Ram did; but what he did is still very valid and informative. There are those that may say what he did leaves too many variables open to alter his findings. I think the way he did it is what you would find in the 'real' world..... Anyway, here is the next one: ISO 5011 Duramax Air Filter Test Report You will also find some tests similar to what I have noticed on my own on a site called ' bobistheoilguy.com '. They aren't as 'scientific'; but, none the less, they do show how different filters can let more dirt in than others. I'm not 'bashing' K & N by any means. They do let more air into your engine usually. I also still have at least two of their filters in use on different rigs that I currently own. I just figure the Cummins deserves better air filtration than what the K & N can give. While what oil and what filters a guy uses is a personal choice, I feel it should be made based on as much information and fact as possible and not on emotions or advertisements. Ever notice how they all have 'the best filtration'? That simply can't be true! It stands to reason as well that to get more air flow through the factory air box, you have to let more of everything pass as well. I have removed my right side battery and am looking into finding the largest BHAF that I can physically fit in there. I currently have the BHAF that everyone usually uses. I seem to get about half of the dirt accumulation at the inlet to my turbo that I got with the factory air box and filter. My filter minder still trips most of the way with about half throttle, so I would like to get a bigger element and see if I notice any improvement. HTH,
